Thanks for your help JasonWW. I will contact Haikelite and report here what they can offer.
I turned off blue led while off thinking it could be leaked from that part of circuit, but it is not helping. And leave it off all night didn’t help too. The very dim light actually is not stable like moon mode, they flicker a bit but never turn off.
The flickering is very odd indeed, it says that for some reason a cap somewhere must be discharging / recharging and this is causing the flicker.
It is possible a fake LDO could cause this I suppose, but pretty unlikely. I am not really sure what could cause this behavior to be honest. It is a very simple setup to avoid issues like this and as far as I know all the 100 lights I built are still working fine with no issues. So I know it is not the base design but sadly that is about all I know.
Thanks for insight of the potential rootcause.
One thing I don’t understand when I managed to get it to be completely off one time, it had tick tick sound like every 0.8s, I hold the light close to my ear to confirm, the sound didn’t want to stop at all. I wonder could it be something is either leaking as sound energy or light energy.
I can’t make it completely off anymore, so far it happened one time only. I give it some try from time to time but not able to see it off completely anymore. I remember it was after i double clicked to turbo and then switched off, and it got completely off. Then i heard ticking sound, i hold mt03 near to my ear and confirmed it’s from the light.
I will try to pull the driver out after talking to Haikelite for solutions.
Those drain numbers are not crazy high in my opinion.
The 360uA to 460uA is a little bit high. It’s still no where near as high as the Thorfire S70S which has a 4,430uA drain (4.43 milliamps). Now that is pretty bad.
So all 3 xhp70.2 in your MT03 are glowing slightly and the drain is only 460uA? I would have guessed it would be much higher. Wierd.
Do you happen to have a hot air station or just a soldering iron?
This was mentioned in the Zanflare T1 thread as well. I’ve encountered this problem a couple of days ago with my T1, where the light was off, but it showed a very dim flickering output. Just an hour ago things got worse, and there is no off position anymore; the dim flickering light is now a constant CW on. It appears to be like a dam breach where in the beginning there is just little water escaping, but after many hours and days the hole gets bigger and bigger until the structure completely fails.
This seems to be the case with DENGOH’s MT03 as well.
Ya, beside current consumption, it looks quite bad now as all four quads are quite evenly lit. When I reported this issue, two out of the four quads were much dimmer. So I decided to take out the battery.
I wonder what’s the standby current of good stock MT03 TA. I think we should compare the number of same light to see how bad my MT03 TA is.
I have solder iron, no hot air unless I ask my friend for help.
I am thinking could it be some output capacitors gone bad. The ticking sound could be from capacitors, no?
My knowledge of electronics is limited. I was thinking of how a capacitor is often used to filter AC ripple from a DC voltage line. When these caps go bad they can often create an internal short and cause current to flow. I don’t know if any capacitors are used in that manner on TA’s driver. From what I understand, you have the positive voltage going through the led and down to one side of the FETs and nothing is supposed to go through it unless the MCU signals the FET to allow it. This is why TA and myself think that one of the FETs might be bad and leaking current through.
IIRC, the new driver is a 2 channel. If the 2 FETS are working properly no voltage should be going through the light. Of course, the MCU gets its power bypassing the FETs. It goes through an LDO to drop the voltage to the MCU. Maybe there is some kind of short in this part of the circuit? A counterfeit ATiny85 leaking current? IDK, I can only speculate. I don’t have one of these lights.
Thanks to you and Texas_Ace for analyzing. Those are valuable info.
I wonder is there published circuit diagrams for this MT03 TA? Or maybe some generic circuit diagram that I can try to understand how it works.
Yes, it will help a lot if you can explain roughly how it works.
For example while measuring current consumption, it will draw about 7mA initially. And then it settled down to 360uA to 460uA. I wonder does the MCU in sleep mode after the initial 7mA.
Ya, I am suspecting the C3 and C4 too. What if one of them gone bad and becomes let’s say for example 500k ohm and will it causes very small current to flow through the LED?
I’ve made a big mess of the picture. Lol. The dark lines are the ground areas. The red lines are the positive areas.
U4 is the little FET.
U2 is the big FET.
U1 is the MCU.
The LDO is labeled.
The 5 orange circles are some of the potential leakage points.
Leakage from the MCU or LDO has to go through R5.
You might be able to unsolder the little FET, but the big one requires hot air. You can also try removing C3 and C4. You can remove R5 to cut all power beyond it which includes the LDO and MCU.
I’m not sure if the FETs can just be measured. I assume the positive and negative sides should be open.
You might also measure the caps resistance. I gave no idea what it should be. Super high resistance of some kind.
How often is the problem of new drivers HaikeLite FET TA in new MT09R and MT03?
Are there any corrections from the manufacturer or current purchases is a risk?
Unknown. I would say they are above average for having a problem.
I would say there is a risk.
I considered buying a used MT09R for $100, but decided against it. If it’s not the driver causing an issue it might be the tail cap pins breaking off or a bad connection/short in the tail cap.
If the issues pop up they can be fixed with a new driver from Lexel or some soldering, but I just decided to pass on the light. :weary:
