Emisar D4S review
Yes, confirmed by Hank. To be more specific:
4000K: SST-20-W40H-A120-J4402(J5-VH-FB4)
3000K: SST-20-W30H-A120-J2302(J4-VH-HD2)
I wish the 4000K was a rosier bin too, but I can live with FB4 with a filter over it. I’ve put Zircon 804 over the 4000K from Kaidomain before and it’s nice.
Me too and soon!!!
Great info thanks. Zircon filter reduces output by almost 20% though, so that negates the 10% flux bin advantage over the J4 flux bin of the KD and Fireflies SST-20 4000k
@Jay, I think you are wrong.
The J4402 bin kit with J4 flux bin is actually the same as the Fireflies SST-20 and Kaidomain.
The J5 flux bin is actually the one that has higher output.
Speak of the Devil… that was fast…(Cancelled)D1S+, CSLNM1.TG LED, 850lm, 320kcd
Not sure what to tell you. All the part number info was just copy/pasted from email replies from Hank.
Strange then.
The J4402 bin kit specifies a J4 flux bin, not J5 flux bin.
He probably meant J5402 bin kit however. Makes more sense.
Can someone please tell me the binnings Hank uses for SST20 5000K and 6500K? Thanks!
I actually prefer the 70 CRI Samsung LH351D in 5000K, W6 binning… it’s the most powerful I have found and the color is closest to pure white I’ve seen, preferable to the 80 CRI 5000K in my opinion. My D4S has these and runs at 5834 lumens rested (start value)
[literally took it off the shelf and measured it right before posting]
Hank was so kind to tell me the bin codes for the SST-20 5.000K and 6.500K. I took the liberty to write down how to understand those bin codes. However, I also stumbled upon different flux and tint bins in the same overall bin code. Maybe someone with more experience can explain what that's supposed to mean.
D4S with SST-20 3.000K
► W30H: W = White, 30 = 3000K, H = 95CRI
► A120: Soldering Pad Type A, 120° viewing angle
► J2302: J2 = flux bin (min. 102 lm @ 350mA, 25°C), 302 = tint bin (HD2)
► VH = minimum Vf with 2.5V
D4S with SST-20 4.000K
► W40H: W = White, 40 = 3000K, H = 95CRI
► J4402: J4 = flux bin (min. 118 lm @ 350mA, 25°C), 402 = tint bin (FB4)
D4S with SST-20 5.000K
SST-20-WDS-A120-L2501(L3-VK-DA)
► WDS: W = White, D = Daylight White, S = 65CRI
► L2501: L2 = flux bin (min. 172 lm @ 350mA, 25°C), 501 = tint bin (DA)
► VK = minimum Vf with 2.9V
D4S with SST-20 6.500K
SST-20-WCS-A120-L3652(L3-VL-BA)
► WCS: W = White, C = Cool White, S = 65CRI
► L3652: L3 = flux bin (min. 180 lm @ 350mA, 25°C), 652 = tint bin (BA)
► VL = minimum Vf with 3.1V
Ah cool! Glad the 3000k SST20 I got lies below the BBL. It’s a shame nobody can source any 4000k variants that are below the BBL, because that is very much a goldilocks CCT I feel. It’s warm without being overly warm. The greenish tint is nothing a filter can’t fix though (especially since optics and ar glass probably add some green as well.)
If all goes well with the 3000k one, I’ll be ordering a second one for myself.
how different is the beam from sst20 to xpl ?
The fireflies one is the FA3 tint bin, which is at or below the BBL. But sometimes the tint bins are not exactly reliable as can be seen with the Samsung LH351D where the DUV is much higher than what the tint bin suggests. Will need the FA1, FA4, FD1, or FD4 tint bin to provide a slightly rosy tint similar to the Cree 5A/5D
Also I find it interesting that Hank sourced the exact same tint bins available at KD but one flux bin up. The 3000k should be marvelous.
Can anyone please explain what flux bin this is?
I feel a bit confused as this code states it is the L2 flux bin but the chromatic bin details state it is L3 flux bin.
That’s interesting.
If you follow the datasheet, the lowest bin for the 5000K SST-20 should be the L3 bin.
But mouser is selling a L2 bin…
And to be honest, the difference in flux bins is +30 to +25 lm @ 1500mA, or in other words, +5% on the low end and +4% on the high end.
But you could still be unlucky and get both a 560lm L2 and L3 bin at the same time.
Even at 3A, we’re talking 855 vs. 903 lm
Can anyone give me a hand trying to flash anduril firmware to my D4S? I have the USBASP programmer hooked up and the wires attached. This is what happens anytime I try to flash
\$ sudo avrdude -c usbasp -p t85 -u -Uflash:w:anduril.2018-11-11.EMISAR_D4S_219C.hex:a
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e930b (probably t85)
avrdude: NOTE: “flash” memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file “anduril.2018-11-11.EMISAR_D4S_219C.hex”
avrdude: input file anduril.2018-11-11.EMISAR_D4S_219C.hex auto detected as Intel Hex
avrdude: writing flash (7296 bytes):
Writing | ################################################## | 100% 5.20s
avrdude: 7296 bytes of flash written
avrdude: verifying flash memory against anduril.2018-11-11.EMISAR_D4S_219C.hex:
avrdude: load data flash data from input file anduril.2018-11-11.EMISAR_D4S_219C.hex:
avrdude: input file anduril.2018-11-11.EMISAR_D4S_219C.hex contains 7296 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 3.78s
avrdude: verifying …
avrdude: verification error, first mismatch at byte 0x0000
0x00 != 0xa4
avrdude: verification error; content mismatch
avrdude done. Thank you.
And now my light doesn’t work. I’ve tried flashing back to rampingiosv3.219c.2018-07-14.hex and I get the same verification error.
As a first measure, do you have another type of USB port to test? Preferred USB 3.0 directly on your Mainboard.
I tried both USB 2.0 and 3.0 on my laptop and on a desktop. I’ve tried both Windows and Linux as well. https://www.amazon.com/gp/product/B00AX4WQ00/ is the programmer I’m using.
try this command format…worked on mine…same usb programmer
avrdude -p attiny85 -c usbasp -Uflash:w:anduril.2018-09-07.EMISAR_D4S.hex:a
put your correct file name in of course…
not sure why it would matter, but safemode not disabled on the above command (-u)
let us know!
I’m not even getting a connection now, I’ve checked all the wires too.
avrdude: error: program enable: target doesn’t answer. 1 avrdude: initialization failed, rc=–1 Double check connections and try again, or use -F to override this check.
What gauge wire are you using from the programmer to your D4S? I tried using these Amazon.com wires but the pins were too big to fit into the holes on the light, the pins kept bending when I tried. Then I found some small solid wires around the house, they fit in the holes but they move around a bit. I’m not sure if I’m not getting a good connection, if I bricked the chip on the light or if this programmer is just bad.
