[♛ FreemeGB] Fireflies PL47 Gen II 4*XP-L/ Nichia/ SST20 Hi CRI 21700 Right Angle Flashlight - ENDED
Yep, I wouldn’t be surprised if yours is here by the end of the week. :+1:
ROFL :smiley:
Got mine last week
headband needed to fix fixed up with a bit of tape, holds it solid now, also had to unstich the top part of the headband to make it longer, i have just stapled it for now but will join it properly at some point.
I also like my Woodford Reserve “neat” lol
So which after market headbands for sure fit the tube of this light? Imma get one on order with the hopes that it’ll be here before the light. I’ve got 4 zebralight headbands but not sure they’re big enough.
Just had some Woodford Reserve a couple of weeks ago. Also had some Knob Creek Rye. Liked them both very much.
got my lights today.
the button is a bit squishy soft for my liking :frowning:
@freeme can you ask please with Fireflies why the 18.11. PL47 are not trackable. They are not recognized in the system at 17 track. Thank you.
Dude, you are a psychic. My tracking updated this morning and now it says my light is at my local post office. I think the tracking may be missing a few steps along the journey, but at least it’s almost here.
Got mine today.
The threads Are the smoothest Ive ever felt I think. So that’s awesome.
But the anodizing had some dings in it and a few bumps in the material itself.
I’m going to use it for work, so it will get more dings and bumps.
It almost Looked to me like the cause of this is rough handling.
Anyone else had this problem?
The light works fine and everything, but still. A new flashlight shouldn’t have dings in it even though it was cheap, right?
New vendor added.
I just received my 2 nichia PL47’s. One works fine with a Liitokala 21700 4000mah, but the other one the battery won’t even fit. I measured the internal diameter of the battery tubes and the black one measures 21.8mm and the champagne one measure 21.4mm. Kinda strange that the battery tube diameters are different. I was under the impression the liitokala was a pretty standard size battery too. I even tried removing the battery tube to get rid of the airlock, but it still won’t slide in. Also, not a huge deal but it did dent the positive end of the 21700 some on the black tube it did fit into width wise. Kinda disappointed on the fitment issues. Obviously you cant expect it to fit every kind of battery but it should fit standard 21700 cells with no issues if that’s what it is marketed for. I wouldn’t expect it to dent a battery with an advertised length of 70.4mm and would expect it to fit a battery with advertised width of 21.2mm. Maybe ill try and get some 50E’s and see if they fit better. The liitokala’s were cheap.
Still waiting for my PL47 to arrive, but I measured some of my 21700 cells.
Sofirn 4000mAh= 21.7mm
Shockli 4000mAh=21.7mm
Samsung INR21700-50E= 21.1mm
Samsung IMR21700-30T=21.2mm
Rofis RF21700=21.8mm
Edit- I got the Samsungs from Illumn and they are still on sale there.
Hahaha. I just figured we both live in the States and both had the same ship date.
50E’s need to be tightened down really tight to make contact. 48G have been confirmed to fit by earlier poster.
Both showed up today. Sanyo 15A NCR20700B 4250. Fitment perfect.
Mine finally arrived. Tube is 21.4 mm, so only my Samsung cells fit. Max output is 1800 lumens at start and it drops rapidly. Push button requires a lot of force to operate and doesn’t always respond- I feel the click, but nothing happens. Maybe that’s good for those who want to carry this in their pocket; there’s no way this light could turn on accidentally.
I’m glad I didn’t jump on the E07 bandwagon. Fireflies is nowhere near as good as Emisar.
Got my xpl-hi pl47 last week but my sst-20 unit has not arrived. Ordered them about 2 hours apart. Hope it comes in this week.
May I ask which model you received?
Champagne yellow Nichia 219B-V1 R9080
That was using the Samsung cells I mentioned above. Those cells give me around 2500 lumens in my Sofirn C8F.
