As for repeating their ideas: Thanks for the warning. I view myself as experienced enough to know what is a good idea and what is just a pain in the rear. (ECE education + >5 yr electronics + embedded systems experience)
Pins can be located at thin edge - solder bubble is usually much bigger and way more close to the center.
Pins can be angled - i.e. you can move connection outside the pcb border.
Pins can have isolated base.
If pcb diameter is too small and reflector base is too big, I see only one decision. You extra thin pcb, soldered with hot air face to face to main pcb. In most cases it can be little bigger than stock pcb. Also you can use flat metal strips with thin heatsink instead of wires (power tool batteries can carry 10amps trough nickel strips but I think copper is better).
Pins might be a great suggestion, but where are the single LED MCPCBs with pins? If they exist I’d love to try them, if not, then it’s back to modding. How would you suggest adding these pins to single LED MCPCBs?
I’ve been filing down reflector edges and using kapton tape. It works but it’s ugly. I guess flat copper straps could work too but holes are a much nicer solution so if I have to do it myself I prefer to drill holes. It just would be nice to not even have to do that.
Success at adding pins or soldering wires to MCPCBs? I have a normal soldering station and tweezers. Sure, I can solder wires to MCPCBs, but still have to file down reflector if it’s too big.
Still interested in Kiriba-ru’s pin solution for single LED MCPCBs. Care to share?
Edit: This is thread hijack… I’ll start this discussion elsewhere. I can at least gather from here that there won’t be any Led4Power MCPCBs with holes.
I would like to purchase some of your product to make my flashlight, but i’m not sure which to buy. What is the main difference between LD-B4 and LD-A4, and which driver are compatible with which of your LED PCB? Is it correct that B4 driver need MOSFET MCPCB, but A4 do not? Thank you.
New 3030 DTP boards in 16mm and 20mm size, made specially for Osram white flat LEDs, but Osram has some other high power LEDs in that size too.
Reason for these boards over XP/3535 boards is that with XP boards white flat LED like to slide on one corner during reflow causing off-centered LED if it's not re-centered during reflow with tweezers.
For small qty this may be ok, but for me it was a PITA. With new 3030 boards there is no such problem since footprint is exact like it should be and LED is always nicely centered.
These PCBs have factory lapped bottom surface and they are fully gold plated, so price is little bit higher than nickel plated PCBs. Also PCBs in panel are separated by double V-cut for nicer and cleaner cut without notches, this also adds ~10-15% cost.
From now on I will only have white flat LEDs soldered on 3030 PCBs, I already changed listing for 20mm white flat 1 and 2, and will do the same for 16mm after few last pcs soldered on XP16 PCBs are sold.
Man how I wish you got the FA1, FA4, FD1, or FD4 tint bin. I would have bought a bunch presoldered on your mighty mcpcbs for sure. Too bad the FC1 tint is above the BBL and I can’t get used to any emitter with greenish tints.
