Which one? Sofirn SP32A vs Sp32a v2.0 vs Convoy S2+
23 posts / 0 new
Yorick
Last seen: 2 days 3 hours ago
I’ve been lurking for a long time on this forum but finally decided to create an account and join in. I’ve always loved flashlights even though I only had a crappy c8 Xm-l T6. Recently bought a Sofirn sp10a v2 and I’m absolutely hooked!
Love the fact that this forum is not snobbish at all! On a lot of forums people judge by price really.
I’m looking for something to replace the c8 and am quite impressed with the quality of my sofirn sp10a.
So my question is which one should I buy? The SP32A, the V2.0 or the S2+?
I’m a bit hesitant with the convoy lights because of reports of fake ones.
What is the major difference anyway between the sp32a and the v2.0? Is it just the switch or is the output different as well?
Edited by: Yorick on 12/10/2018 - 11:54
wstrachan
Last seen: 1 week 6 days ago
Convoys are great lights and bought from a reputable source, they can be a great companion. If you are looking for a light to replace the C8, the throw and CD is not there with any of the smaller ones you mentioned.
If a smaller EDC size is what you are wanting, the Sofirn SP32A is the ticket. It is very bright, well made and dual switches is a positive.
Also look at the Nitefox UT20. If you message Nitefox on the forum, they will usually provide a coupon for about $21. These lights have dual switches like the Sofirn but also feature on-board charging. They are quite nice pieces:
https://www.amazon.com/Rechargeable-Flashlights-Tactical-Flashlight-UT20...
light addict....yeah I've got the bug.
Atrolux MF02_O2S
Imalent DT70
Emissar (All Models)
Lumintop ODL20C
Wuben A21 & T70
thrunite tn32 ut
acebeam k60
many, many others...
Yorick
Thanks for that! I’ll have a look into that one.
I can’t remember the sp32a having a double switch?
wstrachan
Sorry, you’re right, it’s a single front switch light on the SP32A. After awhile if you have enough lights they all run together…
The nitefox is dual switch for sure…
Atrolux MF02_O2S
Imalent DT70
Lumintop ODL20C
Wuben A21 & T70
thrunite tn32 ut
acebeam k60
Yorick
I definitely want an edc/ compact light. I’m just not bothered with a light that doesn’t fit in my pocket. I’m definitely leaning towards the sofirn.
I’m just curious what the difference is with the v2 version.
Streamer
Streamer's picture
Last seen: 2 years 3 weeks ago
The V2 has lighted battery conditon monitor behind the side switch. It has selectable interface between 2 mode groups (ramping or standard serial clicks). It also has automatic temp regulation which means it auto-steps down from Turbo to prevent overheating.
I have original Sp32 and just received the GOLD v2 model.  Love them both!
I'd go for the new Gold again, if I had to choose between the two.
Yorick
Thanks a lot for that! Looks like I’ll be ordering the V2
pc_light
pc_light's picture
Last seen: 4 days 8 hours ago
Hello Yorick and welcome to BLF.
I have both the SP32A and SP32A V2 and been meaning to wrtite something about the difference so the timing of question is fortuitous. I feel, the SP32A V2 is less of a successor to the SP32A and more of an alternative version.
There actually appear to be additional versions even amongst the SP32A’s that are not numbered.
  • On my version the SP32A full ramping from the Lowest level to brightest takes about 3-seconds (which I didn’t find to be too fast.)
  • Whereas the V2 takes 5-secs to ramp across the range. (From what I understand others have experienced different times in their copy.)
  • The SP32A has Max (Turbo 1550 lumens or 5A draw) accessed via a double-click and the top of the normal ramping range is 1300 lumens.
  • Whereas the V2 has it’s Max (1300 lumnes or 3A draw) as part of the main ramping range. On the V2 a Double-click during ramping still takes you Max but that level is the same 1300 lumen Max.
  • The SP32A has a slight pause somewhere in the middle of it’s ramping range; I consider it a de facto Medium setting.
  • Whereas the V2 ramps pretty much straight through with no noticeable pauses. Apparently some people were bothered by the slight pause, I use it as a mid-setting.
There were some tint differences between my two with the V2 having a slightly cooler tint, but still nice. Also the V2 driver side is no longer spring by-passed as delivered. Those are the main differences I recall.
I don’t think you can go wrong with either… but if I had to choose only one, I actually prefer the SP32A over the V2.
Ditto what Streamer indicated, I’d forgotten about the lighted switch.
(There, now I don’t feel so bad about not having wrtitten this in a full review.)
edited: To reflect my preferences and correct #‘s
Seeking the light.
pennzy
pennzy's picture
Last seen: 9 hours 17 min ago
There were 3 models if I remember, 32, 32A, 32A V2. I have the 32 A. It has both ramping and mode groups. The V2 has better ramping, indicator light, better step down but slightly less max lumens. Mine has an impressive beam and it will hold high quite long. V2 should also. Sofirn is a great choice. I have a lot with a SP33 on the way and the new C8F in the future.
Yorick
You guys are not making it easier for me. Big Smile
I like the extra lumens, but better ramping sounds good as well.
Muto
Last seen: 8 hours 9 min ago
Have both, the 32A has lower low for sure and higher max but also has that weird yellow dot in the center of the spot if you are white wall hunting.
V2 of my gold one has slightly nicer beam and just a hair warmer but both are great tints from the factory.
On the 32A with the bypass springs you probably could cook the LED if using a Samsung 30Q and abusing it, mine will pull over 7 amps like nothing if you feed it the right cell. Those purple low ohm cells from a while back or the LG HE2 makes it scream.
So the V2 probably was a smart choice for Sofirn warranty wise.
As far as the ramping differences pretty much what everyone has said. Rarely change to ramp mode as the presets work better for my applications.
Get the Gold one and don’t look back, it’s a very nice flashlight for little money.
HTH
Later,
Keith
The difference between Hoarding and Collecting is the illusion of Organization
.“I will get one of flashlight from patrol car”
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
Streamer
Streamer's picture
Get the GOLD./..I’ll be posting some pics of it soon.   I would recommend that Sofirn  should have called it “Chameleon” instead of “Gold”.   I tell you the Color is Great !   It seems to change in each surrounding you put it in   A true Camo- Chameleon.  LOL  True.   Pics to come as I learn my new file types on this Windows contraption.
edit to add: http://budgetlightforum.com/node/64107
polarweis
polarweis's picture
Last seen: 1 week 4 days ago
if got the gold one as well. its very nice. im think about swapping leds with my sp31 v2. i like the single button more but the sp31 has a nicer hotspot with more throw.
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
wstrachan
Other than the ramping UI, The V1 version is pushed harder than than the V2 (reliability reasons is what I was told by Sofirn). 1500 lumen for the first version, 1300 for V2.
Between the two in side by side comparison, V1 gets hot faster and is slightly brighter. Obvious reasons…
Atrolux MF02_O2S
Imalent DT70
Lumintop ODL20C
Wuben A21 & T70
thrunite tn32 ut
acebeam k60
d_t_a
Last seen: 9 hours 36 min ago
I’ll just cover the beam pattern for the SP32A v1.0, SP32A v2.0 and the Convoy S2+ with XM-L2 and Convoy S2+ XPL-Hi (note that Convoys are available in different color temperature “tints” and also power level) (Sofirn’s LEDs have a range of 5350-5750K so there may be some slight variation between samples)
The shots are taken with the same camera setting (shutter speed: 1/10th second, ISO:800, aperture: f/2.8 and white balance: ‘daylight’)
Batteries used were fully charged (they should be at least 4.10v) and shots taken within the first several seconds of powering up the flashlight (before any thermal stepdown..)
Sofirn SP32A v1 (XP-L2)
Sofirn SP32A v2 (XP-L2)
Convoy S2+ (XM-L2 1A cool-white)
Convoy S2+ (XP-L Hi 4C warm-white)
Astrolux S1 (XPL-HD 3D neutral-white)
the above 5 as an animated GIF:
Both SP32A v1 and v2.0 use SMO (smooth reflectors), however I find theI find the v2.0’s SMO reflector even smoother than v1’s, the effect seems to be that the yellowish corona is more visible on the v2.0 (both use the same XP-L2, but from my observation, the yellow corona from v2.0 is more visible than for v1…)
polarweis
polarweis's picture
s2+ with xpl hi has a great hotspot for a tube light.
TheIntruder
Last seen: 1 day 5 hours ago
There are actually two versions of the 32A. Like with the C8F 21700, Sofirn updated the driver during production to improve the ramping speed, but those being sold now probably have the newer, faster driver.
As for the choice between the 32A and 32A v2.0, Sofirn’s goal was to make it a more usable and reliable light.
In addition to niceties like three color choices, the charge indicator, CR123A compatibility, and faster ramping, ATR was added, and the modes were tweaked.
Turbo lost a couple hundred lumens, but added a minute (50%) of run time. The High mode lost even more, but is actually usable for three hours, instead of three minutes.
Yes, the High mode on the older model also had its own stepdown timer (see the Turbo thread where people are arguing over bad automotive analogies), which effectively eliminated two of the five modes.
The v2.0 lost the electronic lockout, but that’s a small sacrifice compared to all the other updates. Not as much of a hot rod, but also less of a toy. For an EDC light, it has the right priorities in mind.
eas
eas's picture
Last seen: 1 year 11 months ago
FWIW, the SP32a v2 also has a regulated buck driver and can run off two CR123s, if need be.
Lightbringer
Lightbringer's picture
Last seen: 1 hour 31 min ago
You will get all of them. I command it.
The ‘32Av2 has some nice tek, DTP, active thermal stepdown, battery-status indicator, lots of good stuff.
The UT20 has the dual switch (lets you do momentary-on), and batstat, and usb charging.
The S2+ is hella moddable, takes any 20mm TIR lens, triples, shorties, you name it.
Lightbringer
Don’t think we should even mention the TO46R, E2L, F1, or other tubelights…
Yorick
Wow thanks so much for all these answers! Especially d_t_a for all the pictures!
I still haven’t made my mind up completely but I’m 99% sure it’ll be the V2. (in black I’m afraid)
teacher
teacher's picture
Last seen: 2 years 5 months ago
You won’t go wrong with the Sofirn SP32A V2.0! I really like the ramping, and like Streamer said… the Gold color is great! I am loving mine…… Thumbs Up
pennzy
pennzy's picture
I keep hearing the regulated lights are better. Could you please educate me on this a little. Do you actually get more run time vs a non regulated light or just a even output until battery is depleted? Seems like getting something for nothing.
