sorry for nothing new comment from me, but my little baby need all my attention, he is a very heartquake
he have a very strong batteries cell inside
first of all THANKS to all for the suggestion. i purchased the charger (LiitoKala) and the battries (Samsung 30Q) and i am still waiting for the delivery from Banggood, i hope to receive all the item before Christmas.
about the batteries, there is some particular suggestion to follow?
at the first use i need to charge the cells? or they are FULL 100% when delivered?
from the suggestion of BlueSwordM, about the ON/OFF switch button, when it light RED i have to charge the batteries (or step down the lumen)… reading the user manual i see also that when button is completely OFF (no light) the Voltage is under 5.8
in this case the batteries are again safe and i can charge the cells normally?
and again, about the batteries, i find the Sony / Murata Konion US18650VTC6 3120mAh - 30A button top
these cells are better respect the Samsung 30Q?
and last, where i can find the “strap loop” (not sure of my english, please see the photo)
forgot the o-ring inside the package, i have to placed these o-ring to the light? or these are “spare” o-ring?
thanks again to all.
P.S. i read that many users of led light buy a Voltage Tester… i need for this item?
1. Since 18650s are not fully charged when shipped, you will have to charge them to get full power for the light.
2. If the button is red, that means that you should lower the brightness of the light, or recharge the 18650s.
If the button does not illuminate at all, you have to charge the 18650s to get the light working again, as it protects 18650s from full discharge. So, it is perfectly ok to charge 18650s when switch light is not on.
3. Not really. 30Qs are about as good as Sony VTC6 in almost all lights. There is no good difference, especially for higher Sony VTC6 cost.
4. The lanyard should be included in the box.
You can just tie it around the tripod loop.
5. These are replacement O-rings.
6. A multimeter is a useful tool. You should get one. Even a cheap one works:
seems that the MF-01 does not have the hook (i see other review for comparison)
surfing the net i find also another news about this light… it’s the same product of the MATEMINCO MT18… same design, same LED, same lumen… it’s a perfect clone… why???
what are the GENUINE light, Astrolux or Mateminco???
googled for your HAIKELITE light, it’s a very good product. congratulation
these brand of light look very good, i find Haikelite with delay (find it after purchasing my MF-01), probably i buy the Q30 if find it before the Astrolux.
suddenly I have a doubt (fear???): the batteries… the Samsung 30Q are UNprotected… i have read carefully all the suggestion to prevent some danger/explosion BUT yesterday i read some (very BAD) adventure of user of UNprotected cells…
i am little worried… probably follow step by step the user guide for handle the batteries is a right way… but if i want to use PROTECT cells inside this torch? i can? or need a modify?
I doubt that protected button tops will fit. With the plastic protection pieces in the battery carrier, you’ll most likely need button tops and the extra length of the protection circuit will make them too long. I use unprotected button tops in mine and they are a tight squeeze.
dont use protected cells in this light, that much lumens need unprotected batteries, if u are scared using this light with this combination then perhaps this light isnt for you maybe? there is no danger really if u are using quality cells and know what you are doing a little bit of knowledge handling this lights is good to have, the light is designed to drain alot of power thats why high drain unprotected batteries needed, protected will not work very good in this kind of light…
Only unprotected (flat and button top) 18650 are supported in Astrolux MF-series. Battery carrier does come with reverse polarity protection (plastic insulators near pin contacts) against batteries being loaded in wrong orientation. I would advise to add extra markings to your batteries, to help you identify the (+) and (-) poles if you are worried.
As long as it has auto off, beep for continuity and a bag/pouch of some kind to carry everything in, I’m not too picky. I have a VC97+. Two of them actually.
i am still waiting for the charger for the samsung battery… very long delivery time…
in the meantime (and with delay, because i am out for vacancy) i have check the battery received from banggood… i do no see nothing of interest, all look good… BUT… there is one cell that have a little swelling (i hope this is the right word)
looked whit eye is not visible, but when i touch the battery with my hand i feel the difference… i have grabbed a photos, i hope that the protuberance is visible…
what you think? i have to contact banggood and ask for change the single cell? or it’s normal?
if the multimeter (waiting for delivery) show good parameter for the cell, i am ok?
and last, seems that the IMALENT battery can be used inside the MF-01 (apparently the battery are the SAMSUNG re-wrapped)… also (and if i read/remember well) the MF-02 accept PROTECTED battery… it’s correct?
and again, i read that i can made a light with two head: MF-01 and MF-02… it’s possible? trow and flood at the same time…
