I had to rebuild my DBC05 today, the XHP-70.2’s were starting to fail so I removed them and put in MT-G2’s. It was a bear getting the 20mm SinkPAD’s heated up enough to break the bond on the Arctic Alumina Thermal Adhesive with them sitting on such a big chunk of copper, but perseverance paid off. I machined off the remaining adhesive and removed the rimmed opening on the triple reflector so the base of the reflector is completely flat now to sit on the MT-G2 substrate. Had to open the emitter openings with scissors, so yeah this swap involved some fairly extensive hand fitting.
Here’s the new emitters sitting in place before wiring it up… about 2 lbs of copper still sitting under these emitters.
And a frontal view after assembly…
A shot on the wall showing a 16x20 canvas of my son when he was little…
These are Q0 5000K MT-G2 in 6V variant, they’re pulling 27A on the 2S Samsung 30T freshly charged for 12,488 lumens at start… not a horrible loss and a big tint improvement so all in all I’m ok with it. At around 9A each the MT-G2’s should hold up well, they’re very tough emitters….
Edit: The DBC-05 is this light for those that don’t recall…
Completely scratch built it started with a 3.17 lb chunk of Tellurium Copper.
Not sure. They were running at less than 16A each, they made a lot of heat and saturated the big copper pill pretty quickly so I would have to think heat is a major factor. Could be I suck at re-flowing, but the 70.2 I stuck in an L6 at over 9000 lumens is still going strong so I don’t know. I usually try to use the 6V boards with these, as in the case of that one in the L6, but these were on 12V boards, maybe that had something to do with it? They were running at 6V, in parallel, off a single 20mm FET driver with Zener mod.
Not sure if this is going to be a problem or not but my bobbersphere looks like some kind of Christmas pokeball? I didn’t expect this much light to leak through…
Is the whole thing acting like a diffuser or do I need to make the inside more opaque somehow? I haven’t even attempted to calibrate it yet.
That is the prettiest integrating sphere that I have ever seen
My spheres “leak” light too. remind that every photon entering the sphere will either be absorbed at some point or will leave the sphere. If there is not much inside the sphere that will absorb photons eventually many will just end up through the wall to the outside. So that leaking light can be a sign of much light loss but can also be fine. What matters is how many times a foton that reaches the detector on average has bounced around before getting there, If that number is high, say 8, then the integration is good.
A misconception is that all light must be trapped. You need some trapping to get enough reflections for integration but just a fraction of the light will end up in the detector, the rest will go somewhere else.
Seeing lovely MT-G2 5000Ks in that beautiful light makes me all warm and fuzzy inside. I’ll bet you it was the light itself that spat out them XHPs, it knew it deserved the crème de la crème of LEDs.
Today i finally did the resistor mod for my L6, which has seen almost no use the last year.
I used a 1210 size (0,5W) R120 resistor which fits exactly over the two existing sensing resistors, and it worked out pretty nice.
I took out the whole driver to be able to get a nice solder joint and the result was very nice, it was a long time ago for me soldering these small parts.
Also i did file two small notches to get out the switch without having to disassemble and reassemble it (like the Q8)
Very happy with the result, and sometimes nice to see how satisfying those small mods can be!
I had this idea too but wanted to ask first if I need to solve the problem from the inside first. I don’t want my awesome bobber to look like every other Papier-mâché (thx wiki for spelling) foam sphere! However, I have a more elegant solution I will try… The cooler is double walled and when I cut the hole for the lux meter the two walls broke loose. I think I can fit foil in between the two layers of the cooler.
One was an Jaxman E2L that I took out my shaved SST-20 4000K and put in SST-20 3000K 95CRI, looked like too much star burst pattern with smooth narrow optic so I went with frosted narrow and it seems much nicer. I liked the tint better of the 4K shaved one LEDs but it was just too much current/heat for the output I was getting and the beam shape wasn’t great either. I will probably put one of those in a small reflector light or something (BLF 348?).
On to the more interesting mod. My first LED swap which didn’t require solder. In fact I only used a screwdriver, wire cutters, and tweezers:
I recently ordered some batteries from Shockli’s aliexpress store and they threw in some freebies with my order. One was this cheapo keychain light. It has a 5mm straw hat LED that is press to activate and has a tiny switch to “lock” it on.
I bent and trimmed the legs of my Yuji 95 CRI 3200K LED
We have light!
I just now am realizing it had 2 stacked CR2016 batteries so I am probably giving this thing way too much voltage? Maybe a 2032 battery would have been more appropriate, who knows. I guess if it dies i’m out 55 cents…
Ironically that would be also be modding it into a better cooler at the same time. It may suck as an integrating sphere but it will keep a 6 pack cold longer than anyone else’s.
Actually there is reason why you want to limit the amount of reflections that a photon undergoes. You need a certain amount of reflections to obtain a useful level of integration but not many more. If the reflecting surface does not have a flat reflectivity for the complete spectrum (no surface has that, and a DIY surface is worse), with every reflection the spectrum changes a bit. Too good reflectivity results in larger spectrum changes which lowers the accuracy of the measurement.
I have a small experimental sphere with my best BaSO4-PVD coating so far and that one warms up 5100K 95CRI light to 4500K, as measured in the exit hole.
My most used 46cm sphere warms up 5100K light to 4375K.
But if I enlarge the entrance hole from 30mm to 80mm (it has an insert), which makes the sphere loose more light and therefore decreases the average amount of reflections that a foton undergoes before hitting the detector, the warming up is 50K less, to 4425K. Integration is still more than fine.
But if it’s on the outside the light will pass through the sphere surface twice if it does get reflected, so it’s even more diffused than the light simply reflecting off the inside.
Obviously putting foil on the inside would be a bad idea, but on the outside it would just reduce the leakage.
Light that spoils good integration is direct light or light from the first reflection, they do not come to the detector from a random direction. Direct light from source to detector is blocked by a baffle, while light from the first reflection must be diluted by the light from all subsequent reflections. If the contribution of the light from the second and further reflections is enough to get the dilution done, there is no need to re-use that few percent that makes it through the wall.
That can very well be, and I’m really glad that the pipe thing works so well .
What I try to find out, build, and sometimes annoy you with, has little to do anymore with the practice of measuring and comparing flashlights, it is a personal nerdish obsession to get light measuring as correct as I can, which is quite off-topic for a flashlight forum actually.
Lol, yeah, I hear ya. My obsession is to see how far they can be pushed, irregardless of what color or how correct the light is.
But still, I bought the calibration lights from Maukka and they came in today. My light box reads 9.3% high according to these 2 calibration lights. Well within standard deviation of emitters, cells, lenses, springs, whatever.
Edit: While 9.3% doesn’t seem like much when looking at a BLF 348 56 lumen light, on the other end of the spectrum it looks horrible when subtracting it from a 17 emitter monster… like 2400 lumens of loss horrible! Of course, on the mainstream lights that we normally deal with it’s not such a big deal. lol (about 600 lumens on a Q8 out of the box, for example… if my .345 multiplier shows 5400 lumens then the correction factor reduces it to 4836) This could even be attributed to my charger pushing a 30Q to 4.21-4.22V compared to 4.19-4.20 at Maukka’s charger. I don’t know. Not a lot of difference though, 7 lumens on the BLF 348 and less than 30 on the S2. I used a brand new, never before charged 30Q fresh off the charger in the S2… used a brand new Duracell AAA as well as an Imedion LSD NiMH AAA to test the small light.
