When a package leaves China, the EPacket tracking shows it was sent to the USA.
When it arrives in the USA, USPS tracking shows it arrived.
Neither of those 2 things have happened, so I have no reason to believe the package has left China yet.
I have had packages arrive without ever getting any tracking info. That’s usually from dishonest Aliexpress vendors giving me a bogus tracking number to extend their shipping deadline.
I need to do it over using a smd led. Parasitic drain is crazy high. I ordered some 3x3x2mm trim pots so I can easily adjust the brightness. I’ll post pictures when I redo it.
I noticed that sp33 has relatively short run time on high, less than the c8f and about the same as the sp32a. Is the XHP50 a less efficient emitter?This is from the Sofirn specs. (I know the 26650 an 18650 run times are reversed for the sp33 chart)
I never pay attention to factory run time charts. They rarely give all the details and are usually way off.
As far as efficiency (power used/lumens out) the xhp50.2 is pretty normal. Consider it’s using 4 x XPG2 (or XPG3?) at a fairly low current where their efficiency is better. The SP32A uses a single XPL at a much higher current where it’s efficiency is poor. The C8F uses 3 x xpl so it’s efficiency should be better, about the same as the xhp50.2. Then you have driver efficiency and the reflector/lens efficiency. They all factor in. Then the manufacturer lumen ratings might be off a little. The C8F uses a FET driver so it’s brightness level drops as battery voltage goes down. The SP33 v2 is a boost driver and mostly maintains the brightness levels. The SP32A I’m not sure what driver design it has. Etc… :weary:
This one is the orange-ish red led. It’s an led I had laying around and it seemed to run fine at 4.2v with no resistor. It was not even that bright. It lasted about 15 minutes. I guess it burned up. It drew a crazy 144mA. Not 144uA like you might expect, but 1000 times higher! Basically 144,000uA. No good at all.
Next I tried a white smd led and a 8k resistor. It was too dim. I tried a 2k resistor (850uA drain) and it was still too dim.
I decided to switch to a blue led (950uA drain) as well as elevate it up to the switch button tube to increase the brightness. It’s not as bright as I’d like, but we are limited by this switch design. This will get the job done.
Here is a guide. The best way is to push the wires down and out of the way. Then take a small diameter rod and tap lightly on the negative side hole. The positive side hole does have a few nearby components, so you have to feel around to make sure and avoid them.
Set the head on a vice or something solid. Something that will not absorb the energy of the hammer taps. Then do very light taps. The driver has to slide out evenly due to the vertical board. I did a few light taps on one side and then switched over to the other side. I went back and forth until it seemed like the glue had snapped loose. Then I was able to pull the driver out by the spring. I had to both pull and wiggle. You can also push the driver with a rod as you’re pulling. Just be careful not to get it crooked or it will jam up.
Thanks Jason for the run time explanation. I will have to just give mine a try and see how it lasts. It’s just odd that the 26650 SP33 doesn’t outlast the 18650s by a good margin on paper at least at about the1000 lumen mode.
Great light . Had mine out in a snow storm last night. I’m a NW fan so it took some time to adjust to CW. Not bad though. My MyBoxer IR reading was 071m ohm with the Sofirn battery. It reads about half this for the Schockli 5500 but I don’t put much faith in these readings. The UI is different from my other lights but ok. The beam is what is best, for me anyway. It fills the yard with even light with a little throw. This the kind of light I keep ready on the table for quick looks outside and walks. This is my third 26650 light and I like them all. They feel good in the hand and the extra capacity is nice. Good job Sofirn.
I tried yesterday, not by tapping but by pushing.
I applied heat too.
Didn’t work…
So apparently the glue has to ‘crack’ or the PCB has to be tapped loose from the glue or the head.
No problems on the left, but a little risky on the right…
When going to ML with long press, does this light turn on to the memorized mode (potentially destroying night vision) before it goes to ML like the C8F does? I can put up with a lot, but that might be one thing with which up I cannot put.
will dedoming the led give a tighter hotspot? even with the orange peel reflector? I asked sofirn to include a smooth reflector in my order. the old one was SMO so i hope i can just switch it out. Does anyone have the old and the new model?
