I haven’t touched this light since. I really need to get a TIR in mine!
-Garry
-Garry
Mtn electronics has them.
I saw this some time ago and bought one. since, I have bought 3 more. This really is a good headlamp for around $11! I just tried to find a couple more for friends and can hardly find them anywhere.
Does anyone know where to get them other than Aliexpress?
Banggood seems to sell a version of this Boruit EHL0628 but is known as the Xanes D10 headlamp. I haven’t tried ordering from BG so I’m not sure if it’s exactly the same or they just look the same (based on the item description and usage operation and the pictures posted). I got the EHL0628 from their official store in AliExpress.
Do u have the specs for a boruit rj3000 headlamp
I finally got around to changing the LED and optics in my EHL0628 (XP-L ON 16mm copper and TIR).
I didn’t want to solder an extension to the wire so I took off the driver and soldered longer wires directly to it. I took the chance to shoot some photos.
Note that this is the old version bought almost a year ago, the new version has a new UI (with stepless dimming).
[Edit: Sorry, no new version and no new UI. I misunderstood the phrase “stepless dimming” (I’m not a native English speaker)]
Looks like two TP4057 chips in parallel.
A quick guess would be that the unmarked SO-8 IC is an MCU that is providing PWM to switch two transistors (SOT-23-3 chips) through current limiting resistors (the 3 1ohms in parallel).
The two boards are separated by a plastic spacer (sorry about the quality, took this one with my phone’s camera):
New UI? Stepless dimming? When?Where?
This D10 has only had one UI as far as I remember.
Stepless dimming = 5 steps - LOL
Well, all the places that sell this headlamp now say it has stepless dimming. Some examples:
http://www.aliexpress.com/item//32826991825.html
http://www.aliexpress.com/item//32824362452.html
http://www.aliexpress.com/item//32836243713.html
Guys, do you think that there is no new UI? You think the sellers just misinterpreted “stepless dimming”?
Because if that is the case, I’d like to edit my post to reflect this, as not to mislead people.
Well it has “stepless dimming”, but that is via press-n-hold, while the “normal operation” (simple click and let go) goes through two modes. Is this how yours operates?
-Garry
Mine works exactly like yours.
But I thought “stepless dimming” means that the PWM can be ramped, E.G. like the Boruit RJ-02.
5 steps via press-and-hold are still steps, aren’t they?
Now I’m confused…
“Stepless dimming” is literally the 5 different brightness levels. It is not like ramping or like the RJ02. It’s misleading, but no big deal.
Thanks to both of you for clarifying, I edited my post.
Yes the stepless dimming is NOT what you think it is . It's a pure poor translation on their part and has confused everyone who ever entered this thread .
It isn't a bad User interface and it's pretty simple to use .
Thanks, Boaz!
I got my D10s direct from Boruit just this week. It’s a fantastic little light. I got a few as spares for modding and I’ll be putting an order in with MTN today for a TIR 60.
I’d like to grab a few warm LEDs on 20mm boards. Should I go with the Nichia 219C or LH351D? Will the stock driver be capable of driving both? Thanks for the input.
@CarbonCrew, if you want more flood/a bit more lumens than the 219C, get the LH351D.
If you want more throw and even better color rendition, I would advise buying the SST-20 4000k from Kaidomain.
@blueswordm Perfect. I think I’ll an SST-20 as well. 3000k with 95+ cri sounds great.
Can anyone advise me on removing the driver? I’ve got the threaded retaining ring out and have exposed the driver. I’m afraid to mash on it too hard. Does it thread in?
Why are you removing the driver? There’s no need to.
I’ve been experimenting with my D10’ with TIR’s. I tried the LH351D 4000K 95cri and I thought it was a bit too yellow for my tastes. The LH351D in 5000K was pretty darn nice. Nicer than the 219C in 5000K. Yesterday I tried a 319AT 5000K, wow it’s nice. I’m going to guess it was below the BBL because there was no green or yellow at all. It might have a tiny bit of pink or rosiness to it. Color rendition is the best I’ve seen. Anyway, I just thought I’d mention it.
