n10sivern
(n10sivern)
December 14, 2018, 6:40pm
854
I was informed to post here to ask about X6 heatsinks
Enderman
(Enderman)
December 14, 2018, 7:21pm
855
Get ready to order some 4040 PCBs for when the boost HX arrives
led4power
(led4power)
December 14, 2018, 8:28pm
856
Still need some time for release.
Jerommel
(Jerommel)
December 14, 2018, 8:40pm
857
Asking is free, so I’ll ask…
I am fed up with dealing with reflector shorts and thick wires on MCPCBs. I don’t quite understand why there aren’t any LED MCPCBs that have through holes/vias that are wire connection points instead of the slots for wires to pass through and solder on top.
I’d like something like this: An Unorthodox Way to Solder a wire to an MCPCB ~ ~ Low Profile Attachment (HD2010) but instead of having to drill new holes on the pill/shelf, have two of the existing slots for wires converted to holes for direct wire soldering. This would make things a lot easier. Is there a reason why these kind of MCPCBs don’t exist? Have you considered making MCPCBs like this? I’d only buy these if they existed.
Thanks for sharing the link to that old thread!
Indeed a very good idea. :+1:
Jerommel
(Jerommel)
December 14, 2018, 8:52pm
858
led4power:
https://led4power.com/product-category/mcpcbs-dtp-copper/3030-osram/
New 3030 DTP boards in 16mm and 20mm size, made specially for Osram white flat LEDs, but Osram has some other high power LEDs in that size too.
Reason for these boards over XP/3535 boards is that with XP boards white flat LED like to slide on one corner during reflow causing off-centered LED if it’s not re-centered during reflow with tweezers.
For small qty this may be ok, but for me it was a PITA. With new 3030 boards there is no such problem since footprint is exact like it should be and LED is always nicely centered.
These PCBs have factory lapped bottom surface and they are fully gold plated, so price is little bit higher than nickel plated PCBs. Also PCBs in panel are separated by double V-cut for nicer and cleaner cut without notches, this also adds ~10-15% cost.
From now on I will only have white flat LEDs soldered on 3030 PCBs, I already changed listing for 20mm white flat 1 and 2, and will do the same for 16mm after few last pcs soldered on XP16 PCBs are sold.
Hey that’s great!
I have a bunch of 1st generation Oslon squares that could use dedicated 3030 boards.
I will order some next time.
Nice! And Osram 850 and 940nm should be fine withe these
Sirius9
(Sirius9)
December 14, 2018, 9:44pm
860
I demand mcpcb with centrally positioned SFT solderting pad and will not move from this thread until I get what I want
SKV89
(SKV89)
December 17, 2018, 6:27pm
862
Man how I wish you got the FA1, FA4, FD1, or FD4 tint bin. I would have bought a bunch presoldered on your mighty mcpcbs for sure. Too bad the FC1 tint is above the BBL and I can’t get used to any emitter with greenish tints.
Wow...J5 bin, that’s good! FD1 instead of FC1 as tint bin would have been the icing on the cake. I‘m curious if there’s any green shift in those ones.
led4power
(led4power)
December 17, 2018, 9:17pm
864
Unfortunately, you can't choose tint bins so tightly, so it's pure lottery.
MascaratumB
(MascaratumB)
December 26, 2018, 10:17pm
865
Just saw your store L4P, the lighted tail switches are out of stock! Any idea when they’ll be back, mate?
Thanks!
led4power
(led4power)
December 27, 2018, 9:23am
866
I'm waiting for omten switches.
I’ve been hanging out waiting for the subzero switches Any late Xmas ideas on the way…?
MascaratumB
(MascaratumB)
December 27, 2018, 1:20pm
868
Thank you !!! I noticed the store is closed, so I’ll wait for the reopening and for the switches to arrive to order some things! :+1:
led4power
(led4power)
December 27, 2018, 1:25pm
869
Yes, store is now closed till 01/01/2019.
X31
(-X3-)
December 27, 2018, 8:30pm
871
Okay guys, I just installed an LD-B4 and a MOSX with Luxeon MZ in a C8…
It lights ON but I don’t understand how to switch modes, or config or whatever.
With the closed website I can’t access to the datasheet sooo… anyone knows how these work please ?
X31
(-X3-)
December 27, 2018, 9:16pm
873
Thank you very much, now everything makes sense !
That said :
- I don’t like the tint of the Luxeon MZ…either it’s too cool for me to appreciate the 90CRI, or the beam shape screws it too much…
- The beam shape is ugly in the SMO C8 reflector… well maybe I’ll try in an S2+ then
I’ve never felt a C8 getting hot that fast !
