Ok, l will check.
Edit: Dec. 12
In the drop-down selection for led tints, at the bottom of the list of led tints is the $3 21700 tube.
Ok, l will check.
Edit: Dec. 12
Any idea when these will start shipping?
Do you have the runtimes on high and turbo?
This Sunday.
Edit: All unshipped orders will be shipped out today, Friday.
NS22 SST20 3000k:
Ordered SST20 6500k
Thanks
Wow. Simply put, that is impressive throw for a 3000k 95CRI emitter.
Do you have a beamshot for the 4000k version? It would be awesome if you could take/have one.
anyone knows how this compares to the Astrolux C8? I know i can see at least 560m with the Astrolux with room for a little further
tatasal, howcome I don’t see that gray color option. I was thinking about replacing the emitter with the White Flat but seeing that beamshot with the 3000k SST-20, which is what I ordered, it’s making it a hard decision.
Also interested in a gray color, where are the options?
I’ve put a 95 CRI SST-20 in two different lights that originally had an XP-L HI. One was regulated, and the throw was the same. The other, an Astrolux SS has a FET driver, and both power consumption and throw increased. I get 434m (47 kcd). This light has a larger head and reflector, so I’d expect more throw.
1250lm is a fair bit more than I get from 5A, so I imagine those numbers are for low-CRI. I’d expect over 1000 lumens and over 500m from high-CRI though.
What sort of driver do the 3 volt versions use?
BLF A6, nw: ————————————————————————————— NIGHTWATCH Seeker NS22 3000k, 95cri:
The NS22 below the BLF A6:
Just ordered 1 XHP50.2 5000k, 1 SST40 and 2 21700 tubes.
Seeker NS22 3000k, 95cri ———————————————————————- Nitecore EA41 cool white
Received SST40 and XHP50.2 and 2 21700 tubes. Fast shipping, 8 days! Very nice lights. Just slightly smaller than a C8. Head OD is 3mm smaller. SST40 tint is nice, looks more white than blue to my eyes. Thanks for a great deal.
Dang, that was fast ! Still waitin on mine .
Can someone post a pic of the light with the 21700 tube on? Would it take the protected Rofis 21700 that is almost 75 milimeters?
No, the Rofis is too long. At 40T at 70mm fits
My one appears to only have three levels. Is there a special method of getting low?
Driver is 22mm. Retaining ring has right hand threads. Great lights!
