The fireflies one is the FA3 tint bin, which is at or below the BBL. But sometimes the tint bins are not exactly reliable as can be seen with the Samsung LH351D where the DUV is much higher than what the tint bin suggests. Will need the FA1, FA4, FD1, or FD4 tint bin to provide a slightly rosy tint similar to the Cree 5A/5D
Also I find it interesting that Hank sourced the exact same tint bins available at KD but one flux bin up. The 3000k should be marvelous.
If you follow the datasheet, the lowest bin for the 5000K SST-20 should be the L3 bin.
But mouser is selling a L2 bin…
And to be honest, the difference in flux bins is +30 to +25 lm @ 1500mA, or in other words, +5% on the low end and +4% on the high end.
But you could still be unlucky and get both a 560lm L2 and L3 bin at the same time.
Can anyone give me a hand trying to flash anduril firmware to my D4S? I have the USBASP programmer hooked up and the wires attached. This is what happens anytime I try to flash
avrdude: Device signature = 0x1e930b (probably t85)
avrdude: NOTE: “flash” memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: reading input file “anduril.2018-11-11.EMISAR_D4S_219C.hex”
avrdude: input file anduril.2018-11-11.EMISAR_D4S_219C.hex auto detected as Intel Hex
avrdude: writing flash (7296 bytes):
I’m not even getting a connection now, I’ve checked all the wires too.
avrdude: error: program enable: target doesn’t answer. 1
avrdude: initialization failed, rc=–1
Double check connections and try again, or use -F to override
this check.
What gauge wire are you using from the programmer to your D4S? I tried using these Amazon.com wires but the pins were too big to fit into the holes on the light, the pins kept bending when I tried. Then I found some small solid wires around the house, they fit in the holes but they move around a bit. I’m not sure if I’m not getting a good connection, if I bricked the chip on the light or if this programmer is just bad.
I will look for some other wire to test with. What part of the holes actually make the connection, do the wires need to touch the bottom of each hole or is the metal around the outside of the holes? It looks like most of the metal is off the SC and V+ holes, so maybe that's my issue.
Uncertain its the sides or in the holes. I just had the tiny wire put in there until i felt resistance. I found it fiddly to be sure, put a wire in, wire pops out, put it back, put in a wire, pops out…etc…
My wires just shoved in…they were “loose ish” so assuming it was more of a connection IN the holes than just from touching the holes.
If I got lucky and every wire touched the sides of the holes and THAT is what made the connection I got lucky then…cuz that wasn’t what I was going for…
I suspect the wires pass through the holes to the chip legs…
When I flash a D4S, I make sure the wires are sticking through the holes, and there is some sideways pressure on them to keep them in contact. I set it up so I don’t have to touch it during the flashing process, to make sure it won’t move and break contact. Then when it’s physically stable, I run the flashing command.
Been testing some cells and found that a Gold Golisi 26650 at 4300mAh capacity yields 19.22A in my D4S equipped with LH351D W6 5000K emitters. This is better than the 15.06A from a Shockli 5500mAh 26650 and a pair of new Sony’s I just received (one cell at a time of course in the D4S), which make 15.46A although they are only 2600mAh cells and considered to be “vintage”.
Use efest instead ? probably better then any golisi or is there something special about them? im gonna use efest or liitokala when i get my grey Warm White - SST20 3000K 95CRI on my way now, very excited to have a warm white d4s tint.
Thanks to Alchemi who sent me the Ledil-Angie 2287 optic for my testing, I tried using the optic on the D4S Nichia 219C and D4S XPL-Hi 5000K, these are the beamshots:
I like the original, but Im digging the slightly smoother 2286 too. 2287 might be too floody for my tastes unless dedicated for indoors. It would be great on a dedicated candle/night D4S.
