Look Ma No Centering Ring! :cry: We having fun now…. :person_facepalming:
I bored the original shelf out, I was just too thin, and made a press fit copper pill with a seating ledge (for the reflector) and centering pocket (for the board) that centers the mcpcb and the reflector together, to get the canter out at the top of the reflector, I used a bit of Kapton tape. Never again… this is the last time I swap emitters out of this one…
Changed the Utorch UT02 from a boosted XHP-35 thrower to a totally different kind of light… built a Zener modified FET driver with 8.4V LVP and 7 modes with reversing action through the e-switch, stuck it in the UT02 with an MT-G2.
Edit: On a pair of 26350 cells fully charged it makes 3600+ lumens.
Edit II: Tail current shows 5.96A from the little fat half cells.
It’s an XP-L HI 75CRI 5000K…when I compare it to a V2 3A I guess I would say it’s about the same spot along the BBL but it’s slightly cooler white?
Anyways, got around 1,270lm and 108kcd… believe it or not my first C8 mod. The LED is nice but I probably wouldn’t spend $7.35 on it again cause the usual suspects seem good enough (V2 5D and V3 1A)
I was only mentioning the Olsons because of a recent post I saw of a D4 converted to them. The beamshots looked quite throwy for what it was. I just thought it may be interesting to have a small form factor tube light with two different optics and emitter options to give a potentially more versatile light depending on task.
Today I stacked a Convoy C8 driver up to 12x 7135 in total. Flashed with my modified Babka firmware and replaced XP-L HI led with Osram white flat 1mm2 led and Astrolux C8 smooth reflector because it is a tiny bit better than Convoy reflector. Focus almost perfect first time and it throws very well
Thanks! I solder at work every day for almost 14 years now. You can minus 3 years from that at another workplace so 11 years of soldering left. But I think I soldered first when I was 8-9 years old
For you modders, a battery test… I used the 458 Ham’r with it’s 17 emitters and 5 MOSFET’s to just find out what cell gives what… This is a single cell powering the Ham’r, 10 top cells, couple of surprises…
