I probably “diced” it when I sliced the dome off, when I do a vertical cut to remove phosphor from the substrate around the die I call it dicing, as it’s reminiscent of dicing onions or whatever.
I don’t remember ever having bought a Luxeon V though. I know I got my first mtnelectronics 20mm stars not all that long ago (ok, could have been a year or even two, my memory, you know, but I don’t think Richard has had his own MCPCB’s that long…. I could be wrong about that too.)
At any rate, this emitter being on an mtnelectronics star kind of dates it… to some degree.
I thought the substrate would give it away, need to look through the multitudes of emitters that CRX has documented I guess…
Wow! I watched some of the vid but not sure of your Java script problem. I haven't done much in Java, yet alone Java scripting. I've done some mods but never full development. Java scripting though is usually easier/simpler than the full implementation. I work in C# every day and Java and C# have a lot in common, least the language but the package/support stuff is vastly different.
C followed B of course! Actually, B and BCPL were predecessors to the C language, as defined in the gospel of C: the K&R book, or the Book of K&R, and written by the prophets.
Yeah, yeah, I know... 40 years in programming and you would be a little off the wall too
Thanks for the direction guys, looks like that X5 did indeed have a Samsung LH351D emitter, when I diced the sides off it removed the wavy look that identifies it for me.
I replaced it with a Black Flat and it makes 95.75Kcd in the little aspheric X5. (AHorton aspheric, Bistro through a 14500)
case "tapping":
F = tool.getThreadPitch() * rpmFormat.getResultingValue(spindleSpeed);
if (properties.useRigidTapping != "no")
writeBlock(mFormat.format(29), sOutput.format(spindleSpeed));
writeBlock(
gRetractModal.format(98),
gAbsIncModal.format(90),
gCycleModal.format((tool.type == TOOL_TAP_LEFT_HAND) ? 74 : 88),
getCommonCycle(x, y, z, cycle.retract), "P" + secFormat.format(P),
feedOutput.format(F)
Interesting, unfortunately I'm not so adept in machinery lingo. I suppose the writeBlock() guy is sending the commands/data out to the machine, but some of those codes they use like 28, 98, 90, etc. I have no clue about.
CRX DQG Ti XP-L HD v6 3D - FET 15 - 14250 - Rv Clicky Sw - 750lm. Keyring Flashlight.Titanium body (can use 14500 cell with extra extension piece) Cree XP-L HD v6 3D on DTP MCPCB Mule MTN FET 15+1 driver (GuppyDrv3) Reverse clicky tail switch Green GITD bezel Hand made copper pill & switch enclosures
