Yeah… I have gotten PM’s from three different people on that account. Which does not bother me, they all were very helpful.
But in this thread, judging from different answers given; it does seem a bit as if the left hand does not know what the right is doing. . I’m sure it will get sorted out though.
The metal strips to make battery packs for tools are nickel.
Steel is horrible as conductor. I have never read what kind of material they are. I could be a coating.
Without doubt the can of a cell is steel, magnetic in other words. The top cap, or positive contact surface, is also magnetic so it too is steel regardless of whether or not it has a coating on it to prevent rust or tarnish from developing. Use magnetic lead chargers and you find out really quick which cells have non-steel base plates covering the protection circuit and such.
Use flat tops in a series light and stick a magnet on the positive cap, it also sticks to the negative end of the cell and they come out of the light together, like a stick. Steel. Otherwise the magnet would not attach.
NW is the way to go its a better overall option for all the none modders out there. Should around the same output but arguably be a more usable beam to most.
I am going to slice my dome so cold white is best for me but i will take one for the team lol
I think that is well established. I don’t remember on which project it was done, but polls showed clearly that the meat of the bell curve in terms of BLF CCT choice was in the 4500-5500 range. For many the 3D bin of the original Q8 is just about perfect. Those who prefer the cool tints of 6000 and above are a minority, but significant enough that it makes sense to offer that as an option, especially as the wider (uninitiated) public tend to go for the cooler varieties, probably due to disappointment with warm white lightbulbs, which tend to be far too warm and seem dim by comparison to cool white.
To be more specific, do most people here prefer the 5350-5700K tint even though it may push back the production schedule?
I don’t know how much time it may add, a couple weeks minimum I would guess. Anything less would not be a big deal. It could be 4 to 6 weeks, though. If the demand for 5350-5700K is strong enough, I would say it’s worth the delay. Especially if it results in higher sales.
I’ll ask Tracy if she knows how much of a delay it will add.
Tracy says they can NOT glue the drivers, but it won’t have a retaining ring. The battery tube will screw in and tighten against it. So under normal circumstances where you only unscrew the tailcap to install batteries, things will be fine. If you unscrew the battery tube, the driver might be a bit loose.
I am okay with this. Anything is better than fighting glue.
