I would prefer something between 4500-5000 K.
I don’t like blue light
Still wondering why most people seem to love harsh blue Cold White light
Nickel, iron an cobalt are the magnetic metals I have learned. Hmm, a cobalt flashlight, I read that cobalt-chrome alloys have good features…
Tracy says they can NOT glue the drivers, but it won’t have a retaining ring. The battery tube will screw in and tighten against it. So under normal circumstances where you only unscrew the tailcap to install batteries, things will be fine. If you unscrew the battery tube, the driver might be a bit loose.
I am okay with this. Anything is better than fighting glue.
We don’t even have a clue when the light will be finished as is. So it doesn’t really matter if we wait a bit longer?
Nobody is talking about “harsh blue Cold White”. Your eyes may be more sensitive to the color blue, than most people.
Wonder why not have driver retain ring ?
Nah but on a serious note as Jason has said as far as we know the light is going ahead as planned which includes a driver retaining ring
I really do not think “most people seem to love harsh blue Cold White light” or even really like it. Most people do not like the urine yellow of Warm White light either.
So make it as close to True Neutral Whitetm as possible. Adding little tint either warm or cool.
They already designed the CNC cutting programs and set the battery tube length, etc… to not have a retaining ring. Prototypes have been made. I’m guessing they don’t want to have to redesign everything just to add a retaining ring.
Did you see post 1362, quoted below??
Nope i missed it i probably skimmed past that part. This sucks big time!
I don’t think I have seen a 6000-6500 light that I wouldn’t describe as having angry blue, or even purple elements.
Likewise anything I have seen below about 4500 seems to make everything white look like it is stained yellow.
We all perceive things differently, but to me at least it is clear that the closer to 5000 the more true the colours look, below that things appear warmer and maybe more relaxing, above that things appear fresher, but with visible blue tints. Nothing else I have comes close to my D4 5000K Nichia high CRI in side-by-side comparisons.
We found, as stated earlier, the most popular tint requested on BLF is ~5000K, though I personally prefer 4000K. As previously stated, the 4750-5000K 3D in the Q8 has been very popular, and what was voted for - middle of the road.
5500K is cooler than BLF ideal. Anyone who has seen an XPL HI 5D (3750-4000K) would not think it's yellow though. Indoor house lighting ranges from 2200K (candlelight, campfire yellowish) to 2700K (typical warmer) to 3000K (typical cooler). 5000K in house lighting to me looks awful.
Of course Kelvin temp alone is not the full story. You must consider where it lies on the chart. The 3D, 4D, or 5D's allows you to drop K degrees and still be acceptable to many because the lack of greens/yellows.
A 6500K light made for BLF, with no warmer options, is a light not made for BLF - no other way of putting it.
really a let down to see sudden change in tint choice when it says clearly in OP 5000kish tint… yeah why listen to BLF when u not gonna follow whats been agreed long ago ? yeah there is a reason blf q8 is one of the most popular lights and very few complain of the stock tint, its perfection.
count me out on this light, i´ll stick with my good old l6.
You should remove BLF special from the thread title. With the exception of a few fins nothing about this light is consistent with other BLF lights. Not 1 piece head, not SMO, not BLF firmware, no retaining ring, no popular LED choices.
It doesnt beat a modded L6 even with a bigger footprint only matches it. Too many concessions and shortcuts and people are just coming up with excuses on their behalf. Let them release their own light since they wont use any feedback anyways.
Below is an exact copy & paste of the latest update, on 14 August 2018; of Post #1. This was supposedly decided over 4 months ago, with no indication of change until an offhand comment about LED choice a couple of days ago.
Item #3 clearly states: “3. LED: one XHP70.2, 5350-5700K emitter”
Not 5000K, not 4500K, not 4000K, not 6000K, or not 6500K.
5350K - 5700K is what was agreed upon & listed over 4 months ago. Hopefully that…. will be what we get.
Note also that #2 states a ’Smooth Reflector’. However, it was indicated weeks ago & has been discussed at length that this may be changed to a ’slight/mild Orange Peel’ Reflector.
As far as I can tell the LED tint change away from 5350K - 5700K has just come out of the blue completely. No discussion, no prior notice, no nothing….
Why were LED’s not sourced months ago??
My official opinion, ymmv.
Once again to confirm other information. It’s much appreciated if anyone could help optimize for better reading.
1. size: 9cm big head, aluminum bezel
2. Smooth reflector, AR coated lens
4. 2*26650 long tube(sleeve for 21700),
5. tactical ring
6. Switch: tail forward clicky switch + side switch (with indicator as Q8)
7. Overheating Protection. Low Voltage Protection.
8. UI:
Tail switch to power on / cut off
Nothing bad to say about Jason either. You did what you could and invested a lot of time. They should be listening to your expertise since they clearly wanted the feedback at the start.
Going with the usual 5300-5700k from Sofirn would be great.
While I do not like much that tint, I still prefer it over cool white 6000-6500k of the Sofirn SP33.
So much blue.
+1…. Exactly & well said. :+1: .
You can lead a horse to water, but you can’t make him drink.
Jason appears to have done a stellar job.
