i sent but without respond
Hi Andrey,
What are the chances to get some LH351D 5.000K 70CRI with better bin than W6 and/or some LH351D 5.700K 70CRI?
Thank you for the measurement. This result is resembling to a Nichia 219C of the same CCT regarding Ra (R9 could be a bit better, R2, R3, R13, R14 seems to be marginally weaker, R12 is marginally better) - which is a good result considering, that LH351D has better efficacy, than 219C.
What current did you use for the measurement?
Sent two message without your respond.
I decided to give up buying from you.
I’m sorry I was on a business trip then I was sick.
2.5A
Hi, Thomas
As always it necessary to order 800pcs)
(I just noticed SPHWHTL3DA0GF4PQR6 is listed but it is out of stock , may be it will be available in near future.)
Thanks! not bad for 80cri level)
LEDs that are curruntly in stock:
1)351D 5000K 90cri tint F2R1S2 300pcs 1.7$
2)351D 4000K 90cri tint F2T7R2 20pcs 1.7$
3)351B 3000K 90cri tint D2V7H1 60pcs 0.55$
4)351B 3000K 90cri tint D2VAJ1 20pcs 0.55$
payment sent!
Answer in PM .
I will be offline till 09 January . All payed orders are shipped , I will PM numbers today.
Are the LH351D 4000k still available?
If he is out I still have some that I ended up not using I could sell.
Which batch are yours from?
I have not kept up with them, I am not sure how many batches there were. I think they are from the 2nd batch? But it might be 3rd?
If you search this thread you should be able to see when I ordered them.
The first batch I really liked but not sure I want to take a chance on another bin I haven’t seen. I’ll prob wait a bit longer to source more
Same thing.
The first batch was a tint binned T6, so a chance to get a below BBL LED, and a slightly above BBL LED.
Looks like the model I got was the the F2T6Q2 bin. No idea which batch that was from.
1st batch I'd say, 2nd batch was F2T7Q2 if I do recall correctly.
Thanks Texas_Ace, PM sent.
Thanks, I order so many LED’s for testing in hopes of finding that perfect LED I can’t keep track of exactly what I have. I just know I have a shoebox sized box full of LED’s I will never be able to use lol.
