Isn’t it fairly easy to swap the led to whatever color you want?
I was goofing around with some junk leds so I decided to swap their mcpcb. I used my cheap hot air station. It was much easier than I thought. Now I can do reflows.
She says they had success in finding the 5350-5700K leds. I don’t know if it will delay anything or not. She sounded like they got lucky and found a supplier in Hong Kong.
The 21700 should fit “unofficially”. The manual will only say 18650 and 26650, though.
It is too late to add a retaining ring to the design. The first batch (for us at BLF) will not have any glue on the driver. I don’t know about later batches. Maybe eventually they will glue in the drivers.
I’m wondering if it might be better if later batches only used a tiny bit of weak glue on the battery tube with nothing on the driver. This should secure the driver in place, but might be easier for the enthusiast to loosen. IDK, just a thought.
Wish convoy was building this light, we would have tint choices up the wazoo! Anything over 5k is poop, 4k perfect. My sofirn Q8 is great for showing off, the oringin BLFQ8 is far superior in tint and real useage. Any humidity in the air renders the Sofirn Q8 as useless.
yeah i agree, its awful quiet on the convoy front, we have got an updated c8+ but still no l6+ wonder why… guess the l6 sells still and is good enough for most people looking for a budget friendly light that does over 3000+ lumens on turbo and not breaking your wallet.
This is nothing more than your opinion & preference.
Here is mine…. 4000K sux. Most anything under 4700K is pure crap…
………yeah pure crap, as far as I am concerned.
And again, this is nothing more than my preference & opinion.
But the CCT of this light was decided months ago to be between 5350K & 5700K.
To gripe & whine about that now is nothing less than stupid.
And the builder of this light, Sofirn; was decided from the start.
To gripe & whine about that now is worse than stupid.
Don’t like it, don’t buy it. Plenty of people will……
Convoy made XHP70.2 version L6 with SMO reflector on Aliexpress. I think driver is the same or a little boosted. Factory claims 4300 lumens. I hope this SP70 will be much brighter
I would just say to swap in whatever tint you want. If your very particular about tints, then this is probably a common mod to do. The L6 uses the xhp70, btw. Most folks might end up swapping it for a xhp70.2, anyway. Assuming they want higher output, of course.
I thought everyone knew this was a FET driver. Maybe some people are just joining the thread?
The driver and tail spring is supposed to be BlueSwordM’s beryllium copper spring for high conductance. No bypass needed there. I believe they are double springs. This is something BSM arranged with Sofirn, so I don’t know all the details.
