PayPal sent for a couple of sheets.
$20 WowTac A2 before and after. I used the film with white backing on this one.
Much improved the bouncy ball effect still has hot spot witch I like.
How does this material stick? Static type laminate or does it actually have an adhesive?
The other I tried had some light adhesive I think, still easy to remove. The white backed stuff I used about doesn’t. I am using the bezel to hold it down.
I just used the Wowtac above for a 3 block ally walk with the dogs. It made my experience, Less busy. Well worth it to me.
I have some of both adhesive and some thicker film without ..Just depends on what you want to use it for .
PM me for info on different film other than Dc-fix .
Hey Boaz. I have had the Wowtac on my head since the mod(minus a quick shower).
I did a driver swap and flashed it with Anduril earlier today. After the driver swap I used it in the basement to tear down another light, and in the garage looking for tools to tear down another light. Oh and I used it to look for my dc-fix. The wife is gone today so I have gotten to play.
I wasn’t sure I was going to keep this until I put the dc-fix on it and took a short walk, I am using it now at the computer.
The dc-fix turned this 5/10 light into a 9/10 light that just might stay.
I think I will dc-fix my NU30 before the wife gets home.
Nitecore NU30 before and after. Used the film that says dc-fix on the back. I think this has adhesive.
What might be hard to see in the before is the horrible squarish shape of the hotspot. It has be dc-fixed……
It helps a lot .
I have it on most of my floodier lights and I think a wider smoother beam reduces eye fatigue.
The tint mixing helps even on the best of the best of tints . I have it on a Lumintop tool with a 219B that I just love .It makes the tint noticeably nicer . When doing white wall "best of the best High CRI picks" I always look down and see it's the one with the dc-fix on the lens. If the runner up is 95% as good as my favorite it's enough of a difference that I can tell which one is better .I'm more than willing to dethrone it for something better... but that won't happen anytime soon .
Seems like it's usually just trying to figure out how bad of a tint I'm willing to live with ,or conversely if I like a light well enough to do an emitter swap on it .
Adding diffusion to a beam is one of the simplest ways to Fix it.
I would like to buy some , Are you still selling this?
I wouldn’t mind grabbing a couple sheets.
Bumptybump.
Sometime ago I put the DC-Fix on the Emisar D4 and never had a problem, even with it on turbo. Of course, I didn’t make “extensive” use of turbo many times or for a very long period of time. Still, it didn’t have any problem.
I also used it on my Amutorch AM30 (with XHP70.2) for some time on Max, and had no problem concerning temperature and material damage.
Only reason why I took it out was because this is a thrower and the DC-Fix made it floodier. Still, it made the beam even, annulling those yellowish rings on the flashlight (provoked by that led under a big SMO reflector)
Pm recieved , thanks.
So is anyone still actively selling DC fix? Needing a small portion for a Wowtac A2s headlamp. Any info let me know thx.
TxGoodfella did you see this post?
I am sure Boaz is still selling it.
Duh yea sry bout that, PM’ing now
I just linked the photo so you would have an idea how it worked on the Wowtac.
Its cheap enough to try others but be sure to get the DC. It seams to do the best all around.
Goodluck.
Along with his soul… :smiling_imp:
Yes I have become the very definition of a BLF shill :P
Believe me ....every penny earned is given back to the flashlight community. It all goes toward battery testing ,tint evaluation,light juggling,modern light art dance theory and shelf building.
Congrats Nev you won the last dc -fix giveaway .
Your fix is free
I’m jest yankin’ ya chain…
