Using lottery numbers is not good, as they are usually listed in numerical order. In our case it means that persons with high numbers would suffer (since the sixth number is always the highest).
Using for example random.org is way better, but requires some trustworthy person to do the draw.
I think the lottery idea is a interesting idea since it's 100% random and isn't able to be cheated in any way ..But the down side is what do you do with any numbers that are above the number of participants . or what about participants over 49 in number .
Yes I agree it has a couple of issues, for the problem of numerical order I figured we could use the drawn order but I'm not sure how easy that is to look up. Also at the minute the 49 limit is not close to being a problem.
The random generator does seem like a good idea but really unfair if Vectrex does it and misses out
As for Admin doing it, think that's a lot to ask and infact maybe SB should be given a entry anyway, he has allowed this on his board and he appreciates knifes judging by the review of old-lumens(iirc) gift to him
Another edit: I could give another order number I used as SBs entry, obviously I only used my most recent order but I have several, 6522 is my next previous one according to my emails
take the closing value of the dow jones industrial average on a specified day. Remove the decimal amount. Use that number, the number of participants, and the modulus operator to pick the winner.
That’s a poor idea. The DOW will almost certainly start with a 1 and the next number will be a 3 or a 4 since it has been hovering around 13K. So that is not even close to random. I am surprised that you knew the meaning “modulus operator” but couldn’t see the glaring flaw in this idea.
Haven't heard from Mr.Admin (probably inbox flooded with more important stuff)... but old4570 offered to be a backup fairy... so we are all set. I am a little disappointed that not more people participate, we must have more silent readers than I imagined.
This generator from random.org will do the magic...
Step 1: The Sets
Generate 1 set with 5 unique random integer in each.
Each integer should have a value between 1 and 29 (both inclusive; limits ±1,000,000,000).
The total number of integers must be no greater than 10,000.
Step 2: Display Options
Each set will be printed on a separate line. You can choose from the following extra options:
Number the sets sequentially
Use commas to separate the set members
Sort the members of each set in ascending order
You can select the order in which the sets are printed:
Print the sets in the order they were generated
Order the sets by the values that occur in them (in this case, you should also consider sorting the members of each set)
Print the sets in random order
Step 3: Go!
Be patient! It may take a little while to generate your sets...
I have more than two orders on the list you posted (not gonna say how many orders or you'll think I'm crazy :crazy:). I'm sure there are also other people with more than one order on that list which reduces the number of participants a bit.
Ok seeing as there was no resistance to my suggestion for a complimentary entry for Admin, I shall enter it now. It will be clear enough, and I state now, other than using this board I have no association with them.
Jeansy, I have just seen your post... so old4570 pretty much has to do the drawing now... even if Mr. Admin would respond to my PM... a little very last minute... but it will work out.... I hope.... I am not a big fan of changing the rules along the way... a heads up would have been nice..
You have chosen to ignore several of my posts and it was posted whilst you were online last time, if you really don't like it delete my entry, I'm not that bothered but I entered in good faith rather than using 7% codes. I am not overly thrilled about trusting someone I don't know to do it, I assume you havebeen PMing old4570?
My lottery suggestion seems fairer and transparent but you also ignored this. I shall not partake next time don't worry...
Yeah, I PMed old4570 as a backup in case Mr.Admin didn't see my PM in time. We can do the next raffle round your way, if everybody agrees. I think there were still some open questions about your way to do the raffle. I wrote you a PM to explain it better... I hope there are no hard feelings. From my personal point of view it is absolutely OK and a good idea to include Mr. Admin even it is very last minute... I just hope that everybody feels the same...
PM replied, no hard feelings. Maybe if more was discussed in open on the forum as opposed to PMs I would have seen the progress you had made and not interfered. If anyone else disagrees please say so and I will remove one entry (my personal one)
I kind of had to PM them to make sure they see it (and I see the responses).... I have turned off thread notification emails because of all the spamming.
I'm opposed to tossing Mr admin. into the drawing last minute ...just on principle .it wasn't discussed and jeansy isn't the only one with multiple orders here ... i think just because no one didn't disagree that doesn't allow people to change the rules in the middle of the game .there is another giveaway coming up right after this one ..feel free to add Mr.Admin. to that one .
Why dont you ask him first? What if he wins and says he doesnt want the prize? I offered Admin my last DD giftcard before I gave it away here, Mr Admin didnt even want it.
And make it transparent no PMs about what youre doing...if you want...
I have removed my entry then and left the one for mr Admin, I believe that is my right. Indeed, I feel bad now as mr admin has not even asked or ever asks for anything from the members here! And I'm sure he wouldn't of wanted to be the cause of any controversy. As to the further question and he doesn't want it, I'll donate it to another user that will likely do a little review and contribute to the forum, I want no part of it after this
That's kind of hard to guarantee to hear back from him in time, now. This is what I meant that it is a little too last minute for my taste. Jeansy's heart was in the right place and he wanted to make a nice gesture for BLF and Mr.Admin. Next time I will make sure everything is set in stone before we start, this is the 1st raffle that I'm organizing... so I hope everybody is still OK how everything works out... I am still learning. Jeansy now only has one entry and gives it away as price to Mr. Admin in case he wins... I think everybody can live with that? Good luck to everybody.
I have seen that you entered in the raffle with orders that lay outside the first pot of $100 commission money, so your order would be eligible for the 2nd round raffle (100-200$ commission) but not the first one. Could you remove your entries from the 1st raffle thread? I will PM you again when the 2nd raffle round starts (we are currently at $21.14 for the 2nd round) so you can enter again with your already made purchases. If you still have questions, or suggestions how to make the rules more clear to everybody.... don't hesitate to contact me via PM or in this thread.
