If it’s called grey (or gray) it isn’t white.
Edit: Then it’s just a dirty joke. (A WHITE horse fell in a mud puddle. my son’s idea of a dirty joke)
Signed up for 1 NW.
Thanks
:beer:
Any news yet?
as I know:
ca. 70g
36mm max diameter x 105mm long
reflector: 29mm ID
Any updates on the GT Micro?
Filled the form. One in NW, please.
Hope it will be able to outperform in throw Nitecore MH20GT which is almost identical in dimensions (except max diameter)
Or maybe its just a wishful thinking?
as soon as I get news I post it ;)
I am in for 1 CW and 1 NW… form submitted. I prefer 14500 cell sized flashlights for EDC so I’m excited for this one to come out lol
Luke
Still no news on specs?
they are testing the prototype afaik to get those numbers
€dit got the
Specifications
Emitter: Cree XP-L High Intensity, neutral white or cold white, mounted on copper DTP MCPCB
Flux: ~1000 lm
Throw: ~400 m & ~50Kcd
Firmware: Tom E’s open-source GPL NarsilM v1.3 adapted by Texas_Ace
User interface:
[1] By default the GT micro is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to a 2.5 A TURBO mode is also provided.
[2] A more conventional discrete level MODE-SET UI is available as an alternative. Any one of 12 predefined mode-sets can be selected.
[3] MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.
Battery: One 14500. Cell is not included.
Driver: Texas Avenger FET driver
Reflector: 29 mm ID, aluminum, smooth finish
Lens: Glass with anti-reflective coating
Body: Aluminum with Type III hard-coat anodizing
Button: Tactile with back-lit rubber boot
Ingress rating: Equivalent to IP65, do not immerse in liquids
Weight: Approximately 70g without cells
Dimensions: 36 mm Ø head x 105mm length
I’m glad they skipped the nimh.
Is there a spring on the driver end? My recently acquired Vapcell 14500’s doesn’t work with some button head drivers.
Thought I signed up for this, but I don’t see it in my subscriptions, so I’m in for 1 NW please
you need to leave your contact email in the sheet to receive the buying information ;)
Filled in for one cw , thx
Any update on this?
nope
silence from Neal :(
