Review request for HKJ [Rechargeable Batteries]
LoL :-D ended my previous post and then I was going to look up for the Review request for HKJ [Rechargeable Batteries] thread aaand… we're here!
Could you please add those 32700 LiFePO4 cells to your review queue Henrik? 2 pieces to Denmark for €≈10.65 at Surplus xin battery Store with PostNL shipping.
Thanks.
Cheers ^:)
I have ordered them.
Can you test a VTC5D (18650) and the VTC6A (18650 if it exists and 21700 for sure)? Either a true Sony/Murata one or the Vapcell re-wrap is fine.
Would also be nice to re-test a VTC6 now that they are all Murata wraps.
:+1:
What’s the difference between VTC5A and VTC5D ?
I saw some NOR test pics on AliExpress and they were over 6000mAh, but now i’m not sure anymore if i remember it correctly…
Many sellers have these big fat cells, but maybe there are different types being sold with that grey wrapper.
Who knows?
Either way, they seem nice for a 3D Maglite. :smiley:
It would be good enough for me if they did 20 Amperes without too much sag.
I agree about the AE links.
If possible, please use the English language address.
Another thing, i hate when people use the advanced post editor…
It’s really a mess with code cluttering the text when you quote someone…
Oh well…
:slight_smile:
Only 200mAh :wink:
VTC5A is a 2600mAh Typical Capacity Cell
VTC5D is a 2800mAh Typical Capacity Cell (Designed for Dyson, with some technological improvements over the VTC5A)
Thanks. :+1:
Haven’t seen them for sale yet.
акб пришли быстро, это радует. Но у одного немного повреждена термическая оболочка, это расстроило , но не критично. Термическая оболочка и кольца со стороны “плюс” коряво натянуты , так что могу предположить, что это подделка, но только после всех проверок и тестов. Проверить сейчас не могу на ёмкость и отдачу тока, так как ещё жду imax b6. пришли заряженными до 3,2v. Буду изучать этот продукт и оставлю отзыв позже.
09 Dec 2018 23:57
Дополненные отзывы
Ёмкость оказалась чуть меньше 5000 mA/h. Покупать 2 штуки бессмысленно. Минимум 5 штук, так как моё балансирующее устройство идёт для 5 акб 100А. Придётся еще 3 покупать.
translation from Russian into English:
Akb came quickly, it pleases. But one had a slightly damaged thermal envelope, which was frustrating, but not critical. The thermal shell and rings on the plus side are clumsily stretched, so I can assume that this is a fake, but only after all the checks and tests. I cannot check now for the capacity and return of current, as I am still waiting for imax b6. Came charged up to 3.2v. I will study this product and leave a review later.
09 Dec 2018 23:57
Augmented Reviews
Capacity was slightly less than 5000 mA / h. Buying 2 pieces is pointless. At least 5 pieces, as my balancing device goes for 5 Akb 100A. 3 more to buy.
I always use the advanced post editor. The simple post editor cannot cope with web addresses consisting of special characters (like the ones at Henrik's site).
Since the advanced post editor can do nearly everything the simple does and much more, if I were sb56637 I'd unify the editor engine so only two choices would be seen in the drop down below: post editor and plain text.
The unified engine should be based in the advanced editor plus the good stuff missing from the simple one (like image width fit to screen, a working insert emoticon window, etc).
Yes, maybe most of you would cry for a little while but this is normal for newborns. ;-)
Cheers :-D
Advanced editor doesn’t work in my browser. So I type html tags myself when I need to.
I got 1/2 dozen, been available for least a few months, thought sold in a lot of places under the Vapcell wrapper, but they advertise them as VTC5D. They are right up there with the 25S - my tests get about the same performance, better than a VTC5A, least for me.
here in stock: https://www.18650batterystore.com/18650-p/vapcell-18650-2800mah-25a.htm
here also: https://liionwholesale.com/collections/batteries/products/vapcell-18650-25a-flat-top-2800mah-battery-genuine?variant=8642893381726
Grrrr…. I know… :wink:
That’s a feature that should be added to the simple editor then.
Is the Samsung 20S in the queue? It's supposed to be the top 18650 performer - would be great if you can get a pair to test. The 24S is also good but hard to find. I have a couple 20S's, think bought here, in stock: https://www.18650batterystore.com/18650-p/samsung-20s.htm
20S is already tested:
http://lygte-info.dk/review/batteries2012/Vapcell%20INR18650%202000mAh%20(Black)%20UK.html
You just made the decision for today’s review.
Thanx HKJ! Ohh, I see the Vapcell black 2000 is listed as a 20S for $8 here: https://www.18650batterystore.com/18650-p/vapcell-18650-2000mah.htm, and the real 20S is listed at $5. Wow!
The 20S review is up.
That was fast! Thanx!
Edit: Yes, very close, slightly better than the Vapcell 2000 black. Discharge curves align well.
I have just recieved two of these 32650 LiFePO4 cells: https://nl.aliexpress.com/item/32650-3-2-v-7000-mah-lifepo4-oplaadbare-batterij-mobiele-LiFePO4-5C-ontlading-batterij-voor-Backup/32878468860.html?spm=a2g0z.10010108.1000013.5.3d9e7580Cyry4Y&pvid=c5572a18-c89d-440b-a640-9a2bed6460af&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.90158.0&scm-url=1007.13339.90158.0&scm_id=1007.13339.90158.0
Tested with a HTRC B6V2 Balance charger at 2A discharge current they are about 6500mAh.
These will be used to replace a 6V / 4Ah lead-acid battery in a solar powered light (as soon as i get the 2S balance boards https://nl.aliexpress.com/item/2S-8A-Li-ion-7-4v-8-4V-18650-BMS-PCM-15A-Peak-current-battery/32800676048.html?spm=a2g0z.10010108.1000013.3.3e367ecfk06lou&pvid=fbbf3d65-a32c-4bf2-8991-8767aa669f45&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.90158.0&scm-url=1007.13339.90158.0&scm_id=1007.13339.90158.0 )
