You’re right, no clip in the “normal” versions! Sorry, my mistake :person_facepalming:
18650 Samsung INR18650-35E 3500mAh High Discharge FLAT Top
Price: USD 6.5
High CRI emitter options, very nice to see Simon. Still, for driver I would prefer something regulated, PWM free. Stock configurations with LD-25 could be a nice idea, although I understand it increases cost a little bit. Or maybe not? It's a supply and demand thing, doesn't it?
Cheers ^:)
Since we’re using this as a Q&A thread…
Is it possible to put the Nichia emitter on other lights like the M2, Simon?
Of course it can installed in M2,too
Will be throwier TIRs considered for newer Convoy flashlights?
There are a few very nice LEDIL TIR optics with bigger head diameter.
I think reflector is better than TIR if you want the flashlight to be throwier one.
Hi,
Does a pocket clip come with the S2+?
Are the tint options 5700 & 4700 as in the thread title or 5700 & 4000 as on the website linked in the first post?
Regarding the UI, is direct access to low from off available only if memory is disabled or if it is the memorized mode?
What battery would you recommend for the S2+? I don’t have any 18650.
Thanks.
1.pocket clip is not included.
2.I dont understand the second question.sorry.
3.You can active the memory or disable the memory.If the memory is disabled,flashlight enters into the first mode when you turn it on.
4.S2+ only runs on 18650 lithium battery .What kind of battery do you use usually?
Simon Mao: alex64:Hi, it’s possible to buy the Nichia version with S2+ Desert Tan model?
yes,and what driver and reflector?
Driver 7135x4 or 7135x6 (I don’t know which is best for Nichia) and OP reflector if is posible.
Thanks.
Take your time ,pls tell me when you confirm the configuration, I will add link in my store,
@LightObsession, I would recommend the Samsung 35E for maximum capacity and still good power output with more powerful lights:
Price: USD 6.5
mortuus:a s2+ with triple optics and 21700 would be really nice light.
Why triple when the original S2+ can already accomodate triples? The S2+ 21700 should be sized to accommodate a Carclo 24mm diameter quad optic. Quad will provide a little extra output and efficiency over triple.
carclo is expensive and not easy to be bought in China,i want to do a little change with S2+ 21700 to adapt following quad optic.
High CRI emitter options, very nice to see Simon. Still, for driver I would prefer something regulated, PWM free. Stock configurations with LD-25 could be a nice idea, although I understand it increases cost a little bit. Or maybe not? It’s a supply and demand thing, doesn’t it?
Cheers :partying_face:
Yes,I can install LD25. i can sell this version to buyers if they ask me to do this customization
LightObsession:Hi,
Thanks.
Thanks.
Thanks.
Simon Mao: LightObsession:Hi,
Thanks.
4.S2+ only runs on 18650 lithium battery .What kind of battery do you use usually?Thanks.
- Is there a clip that you would recommend for this light?
- Your first post says the tint options are 5700 and 4700. The ad at Aliexpress gives the choice of 5700 and 4000. Which is correct?
- I don’t have any 18650 batteries, so I would have to buy at least one, if I bought this light.
Thanks.
1.following two clips are all suitable
Smarter Shopping, Better Living! Aliexpress.com
2. It’s my mistake, it should be 4000K , I will change the title,
Jack Kellar:Since we’re using this as a Q&A thread…
Excellent!
SKV89: mortuus:a s2+ with triple optics and 21700 would be really nice light.
Since you are just designing the host to accommodate a quad optic instead of making a quad version of the S2+ 21700, you can just design it around a Carclo optic. https://www.mouser.com/datasheet/2/454/10622_iss1_140509-1276368.pdf
The optic you show don’t have legs. When you twist the threaded pill into the head, the optic might shear off the emitters. But I guess if you make the head accomodate 24mm dia., it will work with Carclo quad.
And this is really great news. Looking forward to this and hopefully a copper version in the future.
Convoy M 1, a very successful model for accommodating Carclo Optic 10621-22-23-24
Simon Mao: SKV89: mortuus:a s2+ with triple optics and 21700 would be really nice light.
Since you are just designing the host to accommodate a quad optic instead of making a quad version of the S2+ 21700, you can just design it around a Carclo optic. file:///C:/Users/dAbOMb/Downloads/2D%20Customer%20Drawing%20(PDF).pdf
uh,is it folder path of your PC?
i know this lens has no legs.I will try other method to cope with this situation.
Great to see you here listening to the community Simon!
I was afraid you were getting behind on the newer flashlight developments, but I see you won’t let that happen.
That’s an M2.
Simon said “carclo is expensive and not easy to be bought in China”, dear Carclo lovers. This means it is unrealistical for him to design his flashlights around Carclo optics. Maybe you could ask him to choose some alternative optics manufacturer making Carclo compatible stuff.
Cheers ^:)
[/quote]
That’s an M2.
[/quote]
So confused. Too lazy to watch your collection
This is an M1:
Anodized aluminium bezel, wider and more conical head, deeper fins, and the body is knurled.
I do want an M2 for myself tho Eventually, I’ll have it.
