“акб пришли быстро, это радует. Но у одного немного повреждена термическая оболочка, это расстроило , но не критично. Термическая оболочка и кольца со стороны “плюс” коряво натянуты , так что могу предположить, что это подделка, но только после всех проверок и тестов. Проверить сейчас не могу на ёмкость и отдачу тока, так как ещё жду imax b6. пришли заряженными до 3,2v. Буду изучать этот продукт и оставлю отзыв позже.
09 Dec 2018 23:57
Дополненные отзывы Ёмкость оказалась чуть меньше 5000 mA/h. Покупать 2 штуки бессмысленно. Минимум 5 штук, так как моё балансирующее устройство идёт для 5 акб 100А. Придётся еще 3 покупать.”
translation from Russian into English:
“Akb came quickly, it pleases. But one had a slightly damaged thermal envelope, which was frustrating, but not critical. The thermal shell and rings on the plus side are clumsily stretched, so I can assume that this is a fake, but only after all the checks and tests. I cannot check now for the capacity and return of current, as I am still waiting for imax b6. Came charged up to 3.2v. I will study this product and leave a review later.
09 Dec 2018 23:57
Augmented Reviews Capacity was slightly less than 5000 mA / h. Buying 2 pieces is pointless. At least 5 pieces, as my balancing device goes for 5 Akb 100A. 3 more to buy.”
I always use the advanced post editor. The simple post editor cannot cope with web addresses consisting of special characters (like the ones at Henrik's site).
Since the advanced post editor can do nearly everything the simple does and much more, if I were sb56637 I'd unify the editor engine so only two choices would be seen in the drop down below: post editor and plain text.
The unified engine should be based in the advanced editor plus the good stuff missing from the simple one (like image width fit to screen, a working insert emoticon window, etc).
Yes, maybe most of you would cry for a little while but this is normal for newborns. ;-)
I got 1/2 dozen, been available for least a few months, thought sold in a lot of places under the Vapcell wrapper, but they advertise them as VTC5D. They are right up there with the 25S - my tests get about the same performance, better than a VTC5A, least for me.
Is the Samsung 20S in the queue? It's supposed to be the top 18650 performer - would be great if you can get a pair to test. The 24S is also good but hard to find. I have a couple 20S's, think bought here, in stock: https://www.18650batterystore.com/18650-p/samsung-20s.htm
