Grrrr…. I know…
The simple post editor cannot cope with web addresses consisting of special characters (like the ones at Henrik’s site).
That’s a feature that should be added to the simple editor then.
Grrrr…. I know…
Is the Samsung 20S in the queue? It's supposed to be the top 18650 performer - would be great if you can get a pair to test. The 24S is also good but hard to find. I have a couple 20S's, think bought here, in stock: https://www.18650batterystore.com/18650-p/samsung-20s.htm
20S is already tested:
http://lygte-info.dk/review/batteries2012/Vapcell%20INR18650%202000mAh%20(Black)%20UK.html
Is the Samsung 20S in the queue? It’s supposed to be the top 18650 performer - would be great if you can get a pair to test.
You just made the decision for today’s review.
Thanx HKJ! Ohh, I see the Vapcell black 2000 is listed as a 20S for $8 here: https://www.18650batterystore.com/18650-p/vapcell-18650-2000mah.htm, and the real 20S is listed at $5. Wow!
The 20S review is up.
That was fast! Thanx!
Edit: Yes, very close, slightly better than the Vapcell 2000 black. Discharge curves align well.
I have just recieved two of these 32650 LiFePO4 cells: https://nl.aliexpress.com/item/32650-3-2-v-7000-mah-lifepo4-oplaadbare-batterij-mobiele-LiFePO4-5C-ontlading-batterij-voor-Backup/32878468860.html?spm=a2g0z.10010108.1000013.5.3d9e7580Cyry4Y&pvid=c5572a18-c89d-440b-a640-9a2bed6460af&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.90158.0&scm-url=1007.13339.90158.0&scm_id=1007.13339.90158.0
Tested with a HTRC B6V2 Balance charger at 2A discharge current they are about 6500mAh.
These will be used to replace a 6V / 4Ah lead-acid battery in a solar powered light (as soon as i get the 2S balance boards https://nl.aliexpress.com/item/2S-8A-Li-ion-7-4v-8-4V-18650-BMS-PCM-15A-Peak-current-battery/32800676048.html?spm=a2g0z.10010108.1000013.3.3e367ecfk06lou&pvid=fbbf3d65-a32c-4bf2-8991-8767aa669f45&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.90158.0&scm-url=1007.13339.90158.0&scm_id=1007.13339.90158.0 )
These will be used to replace a 6V / 4Ah lead-acid battery in a solar powered light (as soon as i get the 2S balance boards Page Not Found - Aliexpress.com )
Dank u. :+1:
But that protection board doesn’t balance charge, i think…
Weltool ub-123a
3.0v micro-usb
Inr 16320 2.25wh
Newbie here and hello to all….
I have a collection of NiMh and for the price and availability, Ikea batteries are pretty good.
Henrik, did the EAIEP cells arrived? Just curious, I know super cheap shipping can be super slow but, by this time, they should be at home. :???:
Welcome newbie. This thread is for battery review requests for HJK but in time you will figure where to post what. Again, welcome to BLF!
Henrik, did the EAIEP cells arrived? Just curious, I know super cheap shipping can be super slow but, by this time, they should be at home. :question:
Yes, but I have not tested them yet.
Weltool ub-123a
3.0v micro-usb
Inr 16320 2.25wh
Can you do review of this usb rechargeable?
Thankk.
peabody:Weltool ub-123a
3.0v micro-usb
Inr 16320 2.25whCan you do review of this usb rechargeable?
Thankk.
It makes it easier to find it when the request includes a link where I can buy it (Remember I am in Europe, this means mostly from Europe and part of Asia).
Sorry man. It’s not for sale until February. Taobao is supposed to have it. I just wanted a rechargeable 123a that puts out just 3 volts.
… I just wanted a rechargeable 123a that puts out just 3 volts.
16340 LiFePO4 cells.
peabody:… I just wanted a rechargeable 123a that puts out just 3 volts.
Thanks dude. You have to buy a separate charger though. Guess I’ll just go with throwaway cr123a’s for now.
Barkuti:16340 LiFePO4 cells.
Thanks dude. You have to buy a separate charger though. Guess I'll just go with throwaway cr123a's for now.
Not really a problem, there are inexpensive and good chargers which can cope with LiFePO4 cells. As most notable examples the LiitoKala Lii-202 and Lii-100. This is not for sloppy users, to charge LiFePO4 cells you will have to press the MODE button to swap charging mode to Li-Fe upon cell insertion. A very easy thing to perform once accustomed.
Choosing this path will make you save money sooner or later; quite soon I'd say given the price :facepalm: of CR123A non-rechargeable lithium cells.
Cheers ^:)
