OSRAM CSLNM1.TG & CULNM1.TG 1mm², CSLPM1.TG & CULPM1.TG 2mm²
1403 posts / 0 new
Enderman
Enderman's picture
Last seen: 1 day 6 hours ago
That’s a good video showing how bad that ledil lens is.
So much wasted and scattered light.
A single surface aspheric lens is the way to go.
Th558
Th558's picture
Last seen: 32 min 37 sec ago
Some ppl are saying you can DD this led (1mm) and some are saying you can’t. I’m really confused. If I use a keeppower protected 3500mah in a GT mini how much current will it draw?
Lexel
Lexel's picture
Last seen: 8 months 3 weeks ago
for DD the current with full cell needs to be below 4.5A, so some older cells like NCR18650B with PCB may do only 4.5A when full
also you may try to solder simply a 1W 47mOhms resistor on each contact on the MCPCB to get the current limited
you need to check with a clamp meter
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 2 days 23 hours ago
X3 wrote:
BurningPlayd0h wrote:
Th558 wrote:
The GT mini has a FET 4.5A driver. Does this mean it’s direct drive or constant current? I want to use this led but don’t know if the stock driver will work.
I don’t know where you read that the driver outputs “4.5A” but the whole point of a FET is that it will pull basically all the current the battery can provide (minus the resistance of the circuit in the host and driver).
The first announcement of the Mini-GT was about a 4,5A FET driver…
GT-Mini User Manual
Quote:
17 W, 4.5 A regulated buck driver
with conversion efficiency that
exceeds 90%. Parasitic drain while
OFF is ~27 μA.
That quote says “regulated buck driver”…
IDK how they managed to get that into the manual though lol.
ZozzV6
ZozzV6's picture
Last seen: 12 hours 44 min ago
The GT mini Manual mostly copied from the GT manual and Lumintop made a mistake that they written buck driver. It is not a buck driver. it is a fet+7135.
nkresho
nkresho's picture
Last seen: 2 months 6 days ago
Finally got my few white flat (CSLNM1.TG) builds sorted. All now using L4P LD-A4 drivers set to 5.5a
Measurements at 20’
Convoy L2 with single liitokala black: 407,659 candela, 720 startup lumens
Cometa with liitokala black: 333,708 candela, 780 startup lumens (zoomed in for sphere)
Convoy C8 with 30Q: 219,623, 720 startup lumens
Had to sand the centering rings down to adjust focus on the c8 and l2 a little. I’m still not 100% happy with it, but I think it is nearly right.
KawiBoy1428
KawiBoy1428's picture
Last seen: 3 hours 42 min ago
Measurements at 20’
Very NICE! Thumbs Up
KB1428 “Live Life WOT
polarweis
polarweis's picture
Measurements at 20’
I thought there was a problem with that driver getting to hot?
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
contactcr
Last seen: 8 hours 32 min ago
What did you use to make the 17mm drivers larger?
KawiBoy1428
Maybe the store bought brass adapters…or make your own out of copper crush washers…like I do?
TheDude
TheDude's picture
Last seen: 1 year 1 month ago
My results from installing CSLPM1.TG into a Manker T01
T01 – Tune Up
That's just like . . . your opinion man.
nkresho
nkresho's picture
Yup. Adapters from kaidomain, sanded thinner to fit. They’re a little tall in stock form.
I grabbed some 20s and 22s.
I’d love to do an l6 or mod my gt with this emitter.
Any other drivers out there that’ll do narsil eswitch and limit current?
Th558
Th558's picture
Can you measure the temp of the driver after 2 mins?
contactcr
Fyi Hank (intl-outdoor.com) posted some of the 1mm leds bare and on stars. You can add optional gasket with it also.
I even emailed Hank and ordered extra gaskets without led or pcb.
thijsco19
Last seen: 5 days 9 hours ago
Someone knows a source for a white flat on a 26mm board?
smokuxx1987
smokuxx1987's picture
MCPCB from maxtoch
And LED from Led4power.
Soldering individual.
Enderman
Enderman's picture
No, you would need to do it yourself.
Enderman
Enderman's picture
Did an intensity test for the CSLNM1.TG
LED obtained from Led4Power on a 20mm copper MCPCB.
LED heatsinked on a Coolermaster GeminII S CPU cooler with a 120mm corsair SP fan at full speed.
Thermal Grizzly Conductonaut liquid metal used between the MCPCB and heatsink.
MCPCB tightened down with two screws.
Luxmeter is an LX1330B.
Distance from LED to luxmeter measured with a UT393B laser meter at 1m +/- 0.01
Stray light from LED blocked using Edmund Optics flock paper to avoid reflections.
Current was monitored with a UT210E clamp meter.
Power supply used is a DPS5020, also used for the voltage readings.
Die area used for calculations is from datasheet, 1.03mm x 1.03mm
Results:
Very impressive LED under extreme cooling.
Peak reached at ~5.6A, would not recommend going this high in a flashlight host.
Should be close to 700cd/mm^2 with an RLT collar, if I feel like it I might redo the test with a collar on it.
luminarium iaculator
luminarium iaculator's picture
Last seen: 6 days 15 hours ago
Nice test… I have put that test in a first post.
Mine is running fine in FET DD rig setup. Nothing died yet. Generic flashlight host which goes from 5.8-4A depends on low current battery.
So I don’t think it will die even if it is not super cooled like in your test… But time will tell. Members will share experiences Thumbs Up
Enderman
Enderman's picture
Yeah it won’t die, you can see from djozz’s test that it can handle a lot of current (probably thanks to no bond wires)
It just heats up too much and output starts dropping.
Jerommel
Jerommel's picture
Graph and numbers confirm to me it’s not really worth it to go beyond 4.5 Amperes.
Even 4.0 Amperes seems like a high enough maximum current.
Thanks for testing.
Enderman
Enderman's picture
Thanks for testing.
Yeah in a normal flashlight the peak will be at around 4A, more like djozz’s test.
Even at 3A you get msot of the performance.
This would be a great LED to swap into all those flashlights that have a 3A driver usually driving an XP-L HI at 1000lm.
I really wanted to know how far I could push it Silly Should I try make a 7Mcd optofire?
You’re welcome!
cadmium
Last seen: 7 months 1 week ago
What is the focal point relative to the Cree led? Do I need a shorter or taller spacer? I am having trouble focusing these and creating as tight of a spot as the xpe2 they replaced.
Output looks about the same intensity as before, but I still don’t have a light meter to verify. I am also not driving these hard enough as I am putting about 2.5A . Tint on the other hand is way better than a dedomed xpe2.
Enderman
Enderman's picture
Did another test, this time with a small RLT collar.
The LED reached its peak sooner, at about 5.3A instead of 5.6, likely due to the additional heating of the die.
About a 2x improvement from the small collar.
Both graphs compared:
Barkuti
Barkuti's picture
Last seen: 1 week 1 day ago
So driving the CSLNM1.TG at 4A nets ≈90% of maximum performance, and is probably close to the maximum attainable in a flashlight due to thermal reasons.
Indeed interesting. Has this led emitter been tint and CRI tested? Big Smile
Cheers Party
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
Enderman wrote:
Yeah it won’t die, you can see from djozz’s test that it can handle a lot of current (probably thanks to no bond wires) It just heats up too much and output starts dropping.
Well it won’t drop in first 20-30 seconds or so… Now some will say 20 seconds! That is to low… Real test is above 30 seconds… For me even first 5 seconds are more than enough to do job I need to do… This kind of action: Scan in front of me – nothing in range – cool down… When it lasts to 30 seconds it is super long scan Smile
Enderman
Enderman's picture
Yeah I should also mention I do all my tests continuously, without letting the LED cool down at any time, I just keep increasing the current until there is no improvement.
None of that “X performance at turn-on” stuff.
For the record, I just did a test with the large RLT collar and got 708 (small collar max was 689) so 667cd/mm^2.
There is almost no improvement from the large collar over the small, it’s still ~2x intensity increase.
djozz
djozz's picture
Last seen: 3 hours 36 min ago
Nice test Enderman! It shows once more that the phosfor of these leds even at these huge excitation intensities are still pretty far from saturation.
Enderman
Enderman's picture
Thanks Smile
Can’t wait for the boost HX to come out so I can buy and test it.
I would buy the CSLPM1 but shipping makes it expensive and it will just be obsolete for us when the boost HX becomes available anyway.
The_Driver
The_Driver's picture
Last seen: 1 week 6 days ago
Thanks a lot for these two tests Enderman, especially the one with the small collar!!! The latter is very relevant to me as I plan on having a small light with this configuration at some point in the future.
I have all the needed parts except for the body of the light. It will be a compact light that showcases what is possible with LEDs. It will also look cool because there will be a clear cylinder around the collar instead of metal.
