I’m not bothered by the delayed turn off because it is only a fraction of a second. However, trying to get it to start in moonlight mode but end up with full blast in the middle of the night with the wife asleep is very annoying. I wish that can be fixed.
I’m also replacing our bedroom fan lights with Alexa enabled LEDs so we can use reds to preserve night vision and not bother each other when our schedules conflict with sleep habits. Soon there may be no need at all lol
I’m thinking o f getting a D4s ,I like the XPLHI 6500k version of my D4 & I’m thinking of getting that in the D4s but what’s the difference between it & th SST-20 6500k version ,I know it has more throw ,do you sacrifice flood? Is the tint the same? Is it more power hungry?
It would be nice if we got a side by side pic of the tints and beam shape for each of the different emitters. I’d bet it would help people get off the fence and order.
It’d be really nice if it was standard for flashlight companies to include a “cd/lm” metric for every model and every emitter type. This goes a long way toward giving people a good idea what the beam is like. For example, is it a 2 cd/lm flooder, a 8 cd/lm EDC light, a 35 cd/lm compact thrower, or a 200 cd/lm dedicated thrower?
In order to pick the right firmware for YOU, maybe there should be a survey.
“When I press the button, I want the flashlight to respond immediately: (please circle one)
(AGREE STRONGLY) (AGREE SOMEWHAT) (NEUTRAL) (DISAGREE SOMEWHAT) (DISAGREE STRONGLY)
When I adjust levels, the light should not flash or flicker:
The light should remember my last-set ramp level, even if I have used a shortcut to moonlight or turbo:
(AGREE STRONGLY) (AGREE SOMEWHAT) (NEUTRAL) (DISAGREE SOMEWHAT) (DISAGREE STRONGLY)”
That’s more or less what the “USE_*” flags already do. It would only need a script to set or unset those. There are lots of other software projects which work this way, and even an entire OS based on the concept. Gentoo makes heavy use of “use” flags, both on a per-package basis and system-wide, to let people customize things exactly how they want… but OTOH, it also takes a great deal of time and electricity to compile everything from scratch all the time.
