I’m thinking o f getting a D4s ,I like the XPLHI 6500k version of my D4 & I’m thinking of getting that in the D4s but what’s the difference between it & th SST-20 6500k version ,I know it has more throw ,do you sacrifice flood? Is the tint the same? Is it more power hungry?
It would be nice if we got a side by side pic of the tints and beam shape for each of the different emitters. I’d bet it would help people get off the fence and order.
It’d be really nice if it was standard for flashlight companies to include a “cd/lm” metric for every model and every emitter type. This goes a long way toward giving people a good idea what the beam is like. For example, is it a 2 cd/lm flooder, a 8 cd/lm EDC light, a 35 cd/lm compact thrower, or a 200 cd/lm dedicated thrower?
In order to pick the right firmware for YOU, maybe there should be a survey.
“When I press the button, I want the flashlight to respond immediately: (please circle one)
(AGREE STRONGLY) (AGREE SOMEWHAT) (NEUTRAL) (DISAGREE SOMEWHAT) (DISAGREE STRONGLY)
When I adjust levels, the light should not flash or flicker:
The light should remember my last-set ramp level, even if I have used a shortcut to moonlight or turbo:
(AGREE STRONGLY) (AGREE SOMEWHAT) (NEUTRAL) (DISAGREE SOMEWHAT) (DISAGREE STRONGLY)”
That’s more or less what the “USE_*” flags already do. It would only need a script to set or unset those. There are lots of other software projects which work this way, and even an entire OS based on the concept. Gentoo makes heavy use of “use” flags, both on a per-package basis and system-wide, to let people customize things exactly how they want… but OTOH, it also takes a great deal of time and electricity to compile everything from scratch all the time.
Thanks for the beam shots. I’m not familiar with the PL47 but is this indicative of how they would look and perform in the D4S? I’m surprised the SST-20 isn’t closer to the XPL-HI in terms of output and beam profile.
Ordered a D4S with sst20 3000k. Already have one with sst20 4000k which i like.
But i thought i might like 3000k. I Was about to order the M43 with 3000k, but not sure i Will like it. So i ordered D4S instead to try it out, because D4S is cheaper.
I also ordered the Another M43 in sst20 4000k.
