Convoy L2 XHP50.2 K2-1C outdoor performance
you need a larger area to test in! :slight_smile:
uh ,it’s hard to find an open land without lights here.
Most of the Chinese live in high-rise buildings, and the villas with large lawns are extravagant to us. :cry:
You could light from one of those high buildings and light to another, as long as you use fixed camera exposure settings I see no problems in doing so with the light not white out at too high exposure
Adding the distance from google maps for example
yes ,i understand.
and i saw many posts on forum doing review as you said.
But there is no such place in the environment around me.
It’s better that if some BLFer can help me :laughing: My video is just a preliminary demonstration
Are these available to order? I may purchase one and give it a go.
Neil
Simon do you have any plane to make L2 with XHP35 ?
Simon , do you sell the XHP 50.2 NW on a 26 mm board in your store?
Simon is the owner of convoy. This light will be for sale soon.
Unlikely, as the XHP35 is only available in a 12V configuration, which would require the use of a boost driver. The XHP50 and XHP70 are also available in 6V configurations, which is what Simon is using here. Powering a 6V emitter with two cells in series is relatively straightforward. Developing a 12V boost driver would be considerably more difficult.
yes, i will get the XHP35 driver sample for L2 several days later
but the max output current is 1000mA,
is it too low?
i supply driver ,too
i know some BLFers already have L2 flashlight,they may DIY it themselves
i dont have 26mm DTP copper board
it seems that 25mm is regular size ,i can get some from manufacturer
i will supply XHP35 driver for L2 flashlight soon :smiley:
You can give 2000mA to the XHP35 and it will good. Maybe measure heat and add a timed 5 minute stepdown on turbo.
Thanks, 25 mm would be good. I will message you on your AliExpress store.
Edit : I don’t see 5000k at your site. Not available?
no 5000K in stock presently ,i will order some if you need it ,my email is 468924022@qq.com
Good news but 1000mA is quite low I would like to get 2000mA .
i will get some 25mm xhp50 DTP board samples tomorrow
Simon, is there any chance to get the Convoy L6 tail cap / tail part as spare part?
It would be great to use it for high current purposes on other flashlights.
I plan to make a considerable purchase order on your webshop and this would be the icing of the cake. :LOVE:
Thank you.
