Same way it works on any cell… Cell gets hot and hits thermal limit, thermal fuse trips, cell is dead.
It can not be revived after the thermal protection has been activated, it’s a one time thing to try to save you from a vent with flame (industry term for explode). It does nothing to “protect” the cell, it’d be more accurate to say it sacrafices the cell to try to save your house / life.
It really sounds like you have more reading to do before you’re at a safe level of understanding…
Edit: were not picking on you personally, why would we (we obviously don’t even know you)? Instead we’re trying to help you. Help you learn but mostly help you not hurt yourself. It’s clear by your questions youre brand new to this, li battery danger is real and li batteries burn houses down every single day, so often now it doesn’t even make the news anymore like when the technology was younger.
hey guys. its me again. yay! my sofirn has arrived!! . tried changing the settings etc and im happy with the ramping mode haha. anyways . i changed the thermal to temp based haha. i dont think its wise to change it to 3 minutes haha. its because sometimes its hot here so 60seconds are enough time to make it so hot lol. anyways… my vtc6 works just fine without a magnet. tried turbo for a few and measured the voltage each. and its the same. so it is draining thru all of em at the same time. im really impressed so far haha. also . i have a suggestion for later batches or newer model. add PD (power delivery) support for charging the flashlight. why is it important? because most C-C charger is PD . (Apple charger etc) and how it works , is that it wont give ANY power until it detects a handshake or i guess sometimes a resistor works as a pulldown so it will know that a device is plugged in… anyways. i guess i could just use usb A male to usb C female adapter for now. also another note is to widen the charging port. like not the port itself but the surrounding… some of my cables dont fit. oh and yeah the best i can get is about 7-8watts over the usb. its nice .i guess that is for now… i will add things if it comes to me.
I wouldn't take any risks that voltage will always be the same using flat top cells. There's always the chance that one or more cells will not have proper contact and might be drained less than the rest, i.e. eventually you might be facing sudden voltage equalization which in return can result in collapsed springs. But it's up to you to take the risk or not. ;-)
yeah guys. i wouldnt use it if i have button tops vtc6 or 30q seller here. the only good battery with button top which is real and not fake is the ncr18650b . so yeah. and why dont i just use my magnets? ive tested the magnet. and on high amperage, i could see voltages drop. noticeable enough it makes me just dont want to use it if it works fine without it . but yeah . i see. i’ll think about putting the magnets later…
i have no solder experience. and yeah i know its not save as it can move around. thats why if i were to use magnets, i will glue the side and let it dry for 1-2 days on constant fan so it wouldn’t move like at all.
many on Gearbest Bangood or aliexpress are fake. and even if its real. the shipping cost is like . much more expensive than the batteries itself. some dont even ship it to my country… and yeah its hard to buy things here. mainly things that arent really that popular… like i said in a few post ago. we have vtc6 only in flat top because well many use it for vaping etc…
I think I've bought them, pretty sure many others did as well - did not hear anything of fake 30Q's. More recently I've been using a couple of eBay stores in the US to buy quantities - never a problem.
To make a long story short - you have been given a lot of good advice from BLF members to refrain from using flat tops or - even worse - flat tops with glued magnets in flashlights like the SP36. I really recommend to take the advice as you could encounter severe damage to your SP36, your batteries and - most important - your own life. Lithium-Ion cells are no toys and have to be treated with appropriate caution. I'm sure there is somewhere to get 30Q or VTC6 button top cells in Indonesia. Since you said you were living in a big city chances are not too bad to find someone on BLF who can help you to put a solder blob on your flat tops.
