I revised my post above by the way. Just sign up for a free www.photobucket.com account. It's easy to use. I'd also recommend resizing photos (or decreasing quality a little bit) to save on the file size (so you don't hit your account limit too quickly and also so the photos can load a little quicker).
Yeah that's what I thought. I sometimes I wonder if I am being a little fussy, but then I ask myself 'would I send some of my work out like that?' It probably looks worse in real life because I am no photographer!
The question has been asked many times, Is it sand or bronze? Well mine is bronze, I would have like it to be sand. Don't get me wrong though, the torches seem very good, strong switch, nice fit and finish, apart from the grey one. I'm glad I got them, but will feel better when grey one is sorted.
Pics look great! One suggestion: edit your post, click on the photo (you'll see little boxes on each corner of the image), then click on the photo tree. Go to the appearance tab, change first dimension box to 100% (or smaller, make sure you enter the % sign) and zero out the second box. This resizes the photo to fit anyone's screen, within the dimensions of the post - see below:
I have a black L2P and a gray L2 on the way. Sure hope they look better than this!
Yeah Solarforce sales. The bronze one is OK, and it is bronze. I have just been on there website to compare and they are not alike. I like the one on the website, it's a nice muted tan colour. The solarforce logo is a little high and therefore not centered. But the build quality is Quite good. I must also point out that I bought a SS bezel, the $2.50 one and that is not very well made. It has sharp pieces sticking out. I can fix this, no probs, but you should not have to.
Yesterday I received a Jetbeam BC40 and there is a massive difference! The jetbeam looks like it has been made by very sophisticated robots wearing cashmere gloves. The Solarforce however looks like it had been made on a lathe from the Victorian era, that in turn, has been operated by a man in a very greasy apron. There is also a lot of scratches on the inside of the battery tube, just where the battery enters. If you look closely there are tiny dings which have been anodized over. It's as if they are literally spat out of a machine, from a height and ping! into a large bin, where they rattle around for a bit.
I know the jetbeam is more expensive, but I paid $40 from DD if you get the L2p XML it is $32 and the prices go higher as you go up the model range. That's before you realise that the L2 is not really designed for high output like the Jetbeam. So I'm just trying to justify why I am comparing the two.
Wow, Marc! That is really some horrible stuff! I don't think I've EVER seen a light that poorly machined from any Chinese maker before. I bet you could easily poke a knife tip through the battery tube at that thread spot. Maybe even a fingernail if pushed in the right place. And the horrible pitting in the aluminum...just terrible.
I can't imagine they would refuse to send you another one if they saw those pics. They should be ashamed.
On the first pic, what I am trying to show, taking in to account my photography skills, is the scratch on the battery tube. It looks like its been placed in a vice and turned a few degrees. Not good.
As for inserting a knife tip between the tail cap and battery tube (if that's what you mean) That I like, you see Foy mentioned that the tail cap and body diameter don't match. Well that's because the cap over laps, meaning you can extend the length by up to 6mm without showing the O-ring, by not screwing the cap all the way. Simply put there should be no problems with different length cells.
Ahhh…no, what I meant was you could poke a knife right into the battery tube on the spot where you can see the threads through the machining because the aluminum is so thin. Almost thin enough where you could even poke a fingernail through it.
