Are these available to order? I may purchase one and give it a go.
Neil
Simon do you have any plane to make L2 with XHP35 ?
Simon , do you sell the XHP 50.2 NW on a 26 mm board in your store?
Simon is the owner of convoy. This light will be for sale soon.
Unlikely, as the XHP35 is only available in a 12V configuration, which would require the use of a boost driver. The XHP50 and XHP70 are also available in 6V configurations, which is what Simon is using here. Powering a 6V emitter with two cells in series is relatively straightforward. Developing a 12V boost driver would be considerably more difficult.
yes, i will get the XHP35 driver sample for L2 several days later
but the max output current is 1000mA,
is it too low?
i dont have 26mm DTP copper board
it seems that 25mm is regular size ,i can get some from manufacturer
i will supply XHP35 driver for L2 flashlight soon
You can give 2000mA to the XHP35 and it will good. Maybe measure heat and add a timed 5 minute stepdown on turbo.
pennzy:Simon , do you sell the XHP 50.2 NW on a 26 mm board in your store?
Thanks, 25 mm would be good. I will message you on your AliExpress store.
Edit : I don’t see 5000k at your site. Not available?
Simon Mao: pennzy:Simon , do you sell the XHP 50.2 NW on a 26 mm board in your store?
it seems that 25mm is regular size ,i can get some from manufacturerThanks, 25 mm would be good. I will message you on your AliExpress store.
no 5000K in stock presently ,i will order some if you need it ,my email is 468924022@qq.com
Satan@103TFS:Simon do you have any plane to make L2 with XHP35 ?
is it too low?
Good news but 1000mA is quite low I would like to get 2000mA .
i will get some 25mm xhp50 DTP board samples tomorrow
Simon, is there any chance to get the Convoy L6 tail cap / tail part as spare part?
It would be great to use it for high current purposes on other flashlights.
I plan to make a considerable purchase order on your webshop and this would be the icing of the cake. :LOVE:
Thank you.
I plan to make a considerable purchase order on your web shop and this would be the icing of the cake. :heart_eyes:
Thank you.
Are you just talking about the inside switch
No, actually I'm looking for the entire tailcap unit with the outside switch.
I plan to make a considerable purchase order on your webshop and this would be the icing of the cake. :heart_eyes:
Thank you.
i dont have spare tail
but if you need the tailcap and the switch ,i can send you some for free
If there is an XHP35 model coming I will definately be buying one of those. Hopefully there will be a 3500/4000K version. That would be awesome.
Lux-Perpetua:Simon, is there any chance to get the Convoy L6 tail cap / tail part as spare part?
Thank you.
i dont have spare tail but if you need the tailcap and the switch ,i can send you some for free
Thank you Simon, that would be great! I will leave a message in my AliExpress order. :-) :BEER:
