It was cold outside, so I really didn’t hang out very long to find out. I would guess I was outside for at least 3 or 4 minutes, but it was 25ºF outside. No stepdown and the light warm but not hot
I'm still surprised it could even hold it that long considering it's size even with the cooler weather. I was expecting you to say something like 20 - 30 seconds.
Anything over 30 seconds is a winner to me in that size category. Not sure if it will make a huge difference but I did order mine with a 40T instead of the 30T.
joechina, the actions part of the manual is critical, needs to be front and forward so it’s the first thing you refer to before digging into the UI… without knowing the actions the UI is confusing, understand how to get there and everything is easy.
I know Dale. It’s the not pretty version.
Others have the line description on the bottom or lower right. I think with so much different lines I guess a user searches for the explanation.
I made three versions, this is the 90% where I pushed things around and with the most free space.
The other two are a 90% and a 95% version where I moved nothing.
We both don’t know how much space the misses needs.
I lost track at the moment of the changes in Andúril, but the not pushed ones should be good for 7th click and a bit of text.
(It reminds me a bit at Narsil: Boy the cheat sheet is so packed, no way to add more stuff. And the next week Tom E had new features. Ok, I must push stuff around)
Also the lines for Hold, 3 fast clicks and other actions need probably a bigger spacing.
On A4 paper size its ok, but manufacturers print normally in a much smaller size.
I haven’t made print out in A5
A option for the “3 fast clicks”-line could be
Ah, but joe, I HAVE been speaking with her… the chart needs space in certain area’s for the addition of new functions… not necessarily a new block but more info in some of the old blocks. And only some lights that use Anduril would require this information, so it’s a toss up as to whether or not to add it in. Mostly it’s the aux led’s of a couple of manufacturer’s lights, not really applying to the normal version we flash.
Gonna have to be a couple of versions of the manual I think, one expanded for the auxiliary lights and the other not.
TK has her own methodology, someone else writing the manual the language seems off… probably best to let her do it so the speak reads true to form for the Author.
Just got mine, nichia, blue/purp, gray. (Fyi: My order was placed on nov 28)
This is a really pretty light. Next to my zebra light 60whatever 3 plus thingy my current, er, which is to say former edc, it looks like jewelry. MAN-jewelry.
I was a bit leary this past month about whether or not it would pocket edc well…but it is really smaller than expected, i think it will be fine in my pocket.
Pretty psyched.
I will post a pic in a bit with some former edc’s for size comparison for those interested.
What a pretty light. It’s just so handsome. Seriously. Nicest looking torch in my collection, easily. I dont collect—i use—so most of my lights are pretty utilitarian. So, those with fancy copper, heat treated titanium art projects may be less impressed. But i’m impressed, and i am not easily impressed. I am also—relieved, that it seems alot smaller than i thought it would be.
