You’re welcome
Looking forward to see what you build!
Yeah, with a collar it is significantly more intense than the LEPs found in retail lights like the L2K, W10, W3.
Even without collar it comes pretty close to LEP performance.
But the LEPs in those retail lights are much less than theoretical maximum for an LEP.
oh i didnt know that thanks! So i know intl sells centering rings for the 1mm flat white but only for 7mm reflector hole. what should i use with a 9 mm reflector hole?
I just installed CSLNM1.TG in s2+. The led is driven at 4.1A and it has 32500cd throw. Not sure how good this results is but this is what i got. I must note that i did the reflow and it is a sloppy job since it is on a XP sized board.
Candela is only influenced by the front surface area of the reflector (as seen from the position of the hotspot) and the luminance of the LED. The depth of a reflector for a given outer diameter has a neglible effect on the front surface area (because the area of a circle increases with the square of the radius).
I have been wondering about this… how hard is it to get the CSLNM1.TG on an XP sized board? I know there are issues with excess solder from what I have read…
