OSRAM CSLNM1.TG & CULNM1.TG 1mm², CSLPM1.TG & CULPM1.TG 2mm²
1403 posts / 0 new
Lexel
Lexel's picture
Last seen: 10 months 2 weeks ago
The_Driver wrote:
Thanks a lot for these two tests Enderman, especially the one with the small collar!!! The latter is very relevant to me as I plan on having a small light with this configuration at some point in the future.
so 1mm2 with collar is as good as LEP?
but with considerable more lumens
The_Driver
The_Driver's picture
Last seen: 4 weeks 1 day ago
Well not quite. It’s as good as small LEP modules used in commercial flashlights. Much higher Luminance values have been achieved with LEP in the lab.
The collar is also a few cm wide. LEP lights can be made slimmer.
luminarium iaculator
luminarium iaculator's picture
Last seen: 1 week 5 days ago
The_Driver wrote:
Thanks a lot for these two tests Enderman, especially the one with the small collar!!! The latter is very relevant to me as I plan on having a small light with this configuration at some point in the future. I have all the needed parts except for the body of the light. It will be a compact light that showcases what is possible with LEDs. It will also look cool because there will be a clear cylinder around the collar instead of metal.
Jaxman?
The_Driver
luminarium iaculator wrote:
Jaxman?
No, it doesn’t need to be focusable. Something simple where the head has the right diameter and can be removed without removing the LED. Probably a 1× 18650 host.
Jerommel
Jerommel's picture
Last seen: 1 year 4 months ago
Enderman wrote:
Did another test, this time with a small RLT collar.
The LED reached its peak sooner, at about 5.3A instead of 5.6, likely due to the additional heating of the die.
About a 2x improvement from the small collar.
Both graphs compared:
Wow!
So sad i missed that collar deal a year ago or so…
polarweis
polarweis's picture
Last seen: 1 month 17 hours ago
How much lumen would one get with 1mm white flat at 8×7135 ? im thinking of s2+ with this led for a sort of tube thrower..
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
blueb8llz
Last seen: 1 day 2 hours ago
djozz wrote:
Enderman wrote:
Th558 wrote:
So is the XPL HI dead now?
For intensity yeah.
It does have higher efficiency and lower colour temperatures though for people that want that.
I changed the 2mm2 white flat (so not the throwier 1mm2 version that has a bit too low output I think for this light) in my mini-GT for a dedomed XP-G2 3D because of the much better tint, I do not like the very cool tint. It costed me just 15kcd.
The XP-L Hi comes in many tints but I was unfortunate to never have found a tint that was really great.
Only a loss of 15kcd? How about lumen loss? 500 lumens? Did you ever get s chance to put a 1mm flat in the same light? How much more kcd did you get?
Enderman
Enderman's picture
Last seen: 3 days 3 hours ago
You’re welcome Smile
Looking forward to see what you build!
Yeah, with a collar it is significantly more intense than the LEPs found in retail lights like the L2K, W10, W3.
Even without collar it comes pretty close to LEP performance.
But the LEPs in those retail lights are much less than theoretical maximum for an LEP.
Enderman
Enderman's picture
About 700 according to djozz’s test on the first page.
-X3-
-X3-'s picture
Last seen: 4 days 17 hours ago
Also an S2 would make more sense than an S2+ because of the deeper reflector (also use an SMO of course)
EDIT : that is not quite true, as said by The_Driver. You’ll have a smaller hotspot but a bigger corona and not more Candela.
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
polarweis
polarweis's picture
oh i didnt know that thanks! So i know intl sells centering rings for the 1mm flat white but only for 7mm reflector hole. what should i use with a 9 mm reflector hole?
The_Driver
No. A deeper reflector just makes the light longer, it does not increase throw in a meaningful way. It does make the hotspot smaller though.
BobbyMK
BobbyMK's picture
Last seen: 13 hours 19 min ago
I just installed CSLNM1.TG in s2+. The led is driven at 4.1A and it has 32500cd throw. Not sure how good this results is but this is what i got. I must note that i did the reflow and it is a sloppy job since it is on a XP sized board.
 Olight i3s, Olight S1, Olight S Mini, JetBeam Jet-1, BLF 348, Astrolux S41S, UF SK-98, Convoy S2+ 3*XP-G2, Convoy S2+ 3*XPL, Convoy S2+ 219CT, Convoy M1, Convoy C8, Brinyte B158, Courui D01, Convoy L6, Noctigon M43
Jerommel
Jerommel's picture
The S2+ reflector is very short though.
Deeper reflectors also give bigger coronas.
The_Driver
It’s all relative Wink
Yes, the light, that is missing in the hotspot and the spill, has to go somewhere.
Jerommel
Jerommel's picture
The corona is bigger because the deeper reflector is narrower near the LED.
(Deeper reflector is a smaller size parabola)
polarweis
polarweis's picture
so bigger corona smaller hot spot.
so smaller hot spot but not more candela because less light is going to the hotspot and more to corona?
Ryzbor
Ryzbor's picture
Last seen: 13 hours 35 min ago
@BobbyMk, will you take a beamshot? How is the useable range? How does it compare to the XPL-HI C8?
virence.com Nichia E21A sw30+sw40 Wizard Pro ; Skilhunt H03 XP-E2 660nm ; Wizard Pro E21A 2000K ; S2+ E21A sw40 d220 ; Sofrin C01R 660nm, Mf01 Mini Nichia 219B sw35+sw40
BobbyMK
BobbyMK's picture
Will take few in a few hours, just waiting to get dark outside Big Smile
I do not have any C8 with xpl hi but have one with Luxeon V2, here is picture side by side of those two.
Left C8, right S2+
djozz
djozz's picture
Last seen: 9 hours 30 min ago
32500 kcd is very respectable for a 20mm reflector, well done!
The_Driver
polarweis wrote:
so bigger corona smaller hot spot. so smaller hot spot but not more candela because less light is going to the hotspot and more to corona?
Candela is only influenced by the front surface area of the reflector (as seen from the position of the hotspot) and the luminance of the LED. The depth of a reflector for a given outer diameter has a neglible effect on the front surface area (because the area of a circle increases with the square of the radius).
Ryzbor
Ryzbor's picture
How does that translate to meters of range? I’m a tint snob and know little to nothing about candelas, lux etc. so forgive me my ignorance.
-X3-
-X3-'s picture
The_Driver wrote:
Candela is only influenced by the front surface area of the reflector (as seen from the position of the hotspot) and the luminance of the LED. The depth of a reflector for a given outer diameter has a neglible effect on the front surface area (because the area of a circle increase with the square of the radius).
Thank you very much for that explanation Smile
I’ll edit my post so there’s no confusion for other members
Enderman
Enderman's picture
The candela still increases a little for a deeper reflector because the unused center hole decreases in size.
It’s probably negligible for a small height difference like the S2/S2+ but it is still incorrect to say it does not increase lux.
The_Driver
Thats why I wrote “not meaningful”, “neglible” ;).
ZozzV6
ZozzV6's picture
I made a 3.15A S8 but S2+ internals with 1mm2 led and got 30800 cd with Smooth reflector and AR coated lens.
netprince
Last seen: 13 hours 3 min ago
!https://i.imgur.com/8hegEoU.jpg!
Nice job!
I have been wondering about this… how hard is it to get the CSLNM1.TG on an XP sized board? I know there are issues with excess solder from what I have read…
Lexel
Lexel's picture
Nice job!
enough flux is the key so the solder sticks together where it should adhesive forces do the rest
Tom E
Tom E's picture
Last seen: 3 hours 18 min ago
Is it just me, or is it a difficult thing to judge the white flats vs. the black flat? Seems like in theory the white flats should have better throw, but in practical mods, every head to head I've seen the black flat prevails. This thread mostly compares the white flat to the good dedomed XP-G2 but I don't see apples to apples comparison in a real host to the black flat.
I understand the difficulties with the black flat with electrical isolation, but still, in a decent thrower host, has anyone proven the white is better than the black? Is it dependent on the host or maybe spending the time/effort on focusing a white flat for a particular reflector? Why would the white flat be more difficult to focus?
Enderman
Enderman's picture
I’m going to try putting the white flat into another flashlight with one of my 120mm lenses so I’ll let you know how much improvement I get over the optofire once it’s done.
