Is it just me, or is it a difficult thing to judge the white flats vs. the black flat? Seems like in theory the white flats should have better throw, but in practical mods, every head to head I've seen the black flat prevails. This thread mostly compares the white flat to the good dedomed XP-G2 but I don't see apples to apples comparison in a real host to the black flat.
I understand the difficulties with the black flat with electrical isolation, but still, in a decent thrower host, has anyone proven the white is better than the black? Is it dependent on the host or maybe spending the time/effort on focusing a white flat for a particular reflector? Why would the white flat be more difficult to focus?
I’m going to try putting the white flat into another flashlight with one of my 120mm lenses so I’ll let you know how much improvement I get over the optofire once it’s done.
focus should be the same cant be that, maybe those LEDs are a tiny bit different in height but this should be so minimal not making a big difference
the main problem is getting this ultra low Vf LED driven at a current below 4.5A, DD driver cant do it even with Medium drain pulls too much
enderman measured at acceptable current about 300cd/mm² and 600 with collar, but this of course to the fact he uses a regulated supply
same measurement numbers on other testers
Not sure why, but the old tricks of simply adding resistance by using thin, long LED wires and higher resistance batteries should do the trick. The springs you have to be careful with because even 5 amps on cheap wires may be a problem. I'd choose to use the high quality Blue springs for example, and would rather up the resistance on the wires. Of course it would be better to have a great regulated driver but that's not so easy or cheap as a FET based driver.
It's like those cheap SRK's that have the squiggle line traces all over the big driver -- they are only doing that to add resistance - bypassing the traces is an easy power boost.
Example in a 12X SRK clone (added jumper to circumvent the squiggles):
Agree, not the best solution but it works, just like any other FET based driver we have in all the popular lights as of late (Emisar, Fireflies, Sofirn. etc.). On all of them you get the max on full cells, then slowly drops - sorry, but it's our only/best solution for a reasonable cost.
I believe led4power’s driver uses a FET in its linear region. The driver must be constantly sensing how much current is passing, and adjusting the FET accordingly.
I guess…
The LD25 driver is FET CC though, and not expensive.
Will need some extra cooling above 3 Amperes, but can be boosted with slapping on R030 (for 4 Amperes) or R020 (for 4.5 Amperes) on top of the R010.
But with high Vf LEDs on a single cell you might as well use a DD driver.
But with low Vf LEDs on a CC driver you can also optimize the electrical path (spring bypasses and thick LED wires) and have full regulated output for a long time of the battery charge.
With the White Flat 1mm² you can keep the max current on 4 or 4.5 Amperes (diminishing effect when going above that) and keep the Vf rather low in order to be able to have full output for even longer.
i saw some reports (djozz), that 7135 amc are killing this led, is this true or is it even possible in some way? Maybe somebody can explain, cause I am really interested about this.
The thing is with specific regulated/linear drivers, they are fixed size. Right now I can do about any size in a FET+1, from 15 mm all the way up to SRK size, and lots in between combined with filing down, etc., plus I can configure them for power or e-switch lights.
Sort of related, looking for a decent host for these LED's, I do have a couple Cometa's and one B158. I did find FT has the B158 in stock at $29 with the BLF code, but I'd prefer a B158B and it seems no longer available at GB. I only have one B158, wish I got the B158B's when they were there. Now, Brinyte is under new ownership or something, or sold the B158 line - looks like they gave up on the B158. I messages with a rep a few weeks ago - the Brinyte that is now is not the old Brinyte, so not looking good for the B158's - what a shame... I think/believe the B158 is still bout the best throw for it's size around.
Of course there are many other lights/hosts that would do.
Worth to mention that B158 beats all commercial available 50mm aspherical flashlights when it comes to throw… All that with super cheap 2$ acrylic lenses.
When I was telling that to certain Copyfire factory they just ignored me… They stick to their production and lenses vendors and that’s it.
Also worth to mention that B158 lens will give less die projection than other 50mm aspherical lights.
How much you can expect with White Flat? Mine cheap Uni-t Light meter says 420kcd! Yes with FET DD setup( I am obviously brainwashed hehe )
I Built a C8+ (stock AR lens) with white flat CSLNM1.TG on Noctigon xp and LD-4 driver. After doing measurements hand-held at 5 meters I decided to get out my tripod for more accuracy in measuring lux at different currents.
Keep in mind that the led is very close to center but not exact with stock xp centering ring not yet focused.
So here are my numbers:
At 4.50 amps - 160,500 cd - 801 m
4.75 amps - 163,700 cd - 809 m
5.00 amps - 167,500 cd - 818 m
5.25 amps - 168,575 cd - 821 m
5.50 amps - 169,750 cd - 824 m
5.75 amps - 166,250 cd - 815 m
Measurements done with 1330 lux meter corrected to .93 to match known lights.
For some reason I can’t get the driver to do 6 amps but as you can see with my setup the output peaks at 5.5 amps and starts to fall after that. Normally I’m a numbers guy but it doesn’t make any sense to drive this led harder than 5 amps. I’m inclined to run it even softer at 4.5 just to give it better battery life and generate less heat. The loss in candelas is a negligible trade off.
As noted before the led doesn’t like to self center on an xp MPCB so that is a challenge. I look forward to trying on a 3030 board. The stock xp centering ring is also sloppy because the hole is larger than the led. It takes time and effort to get this one even close to center. As you can imagine I’m not crazy about sanding the ring to achieve better focus.
Pros:
Very low Vf. Longer runtime at top output.
Higher candela than dedomed xp-g2 without the hassle of dedoming and tint shift.
Throws further than any single cell C8 I’ve seen to date.
Cons:
A little too white for my taste.
Needs a custom centering ring.
As a comparison, the same light with XPL-HI V3 3A direct driven at 5 amps gives me 650 meters throw. A 2S dedomed XP-G2 driven at 5.1 amps shows just under 800 meters.
