Very floody AA flashlight
28 posts / 0 new
ZoomieFan
ZoomieFan's picture
Last seen: 8 months 1 week ago
I’m looking for an AA flashlight for close range work.
Preferably a very wide beam with as little hotspot as possible.
With memory.
Any tips?
Chargers: 1xBasen BD01 5/5, 1x Gyrfalcon All-88 4/5, LiitoKala: 3x100 3/5, 2x202 3/5, 1x402 3/5., MiBoxer C4-12 3/5.
Flashlights: DQG Tiny III 26650 5/5, DQG Tiny III 18650 5/5
FiTorch MR35 3/5, Haikelite SC26 HD 3/5, Lumintop Tool AA/AAA 4/5, Nitecore LA10, Skillhunt H04FRC 4/5, Sofirn C01 BLF 3200k/5600k 2/5, Zebralight H600Fc 3/5.
Powerbanks: Romoss 30000 4/5, xiomi 1000 4/5, Xtar PB2 4/5, Xtar PB2S 5/5
Pete7874
Pete7874's picture
Last seen: 6 hours 26 min ago
Manker E03?
hank
hank's picture
Last seen: 4 days 5 hours ago
Get a cheap SK68, remove the bezel, remove the lens, and the bare LED will give you a floodlight.
You can even put a flat lens in place of the original and put the bezel back on.
ZoomieFan
ZoomieFan's picture
Bedtime in my timezone…. gonna read the suggestions tomorrow.
Found Astrolux A01 at 61% discount. Any good?
EDIT: That’s a AAA not a AA.
Review: http://www.candlepowerforums.com/vb/showthread.php?414612-Review-of-Astr...
Pete7874
Pete7874's picture
I thought you were looking for AA and not AAA?
hank
hank's picture
That’s not the BLF Astrolux A01 (3 levels), it’s the cheap one-mode imitation that followed.
Also, not floody, and not AA.
LightUpTheDark
Last seen: 11 months 1 day ago
Subscribed…
I’ve got a thrower, a flooder, and an EDC too. Still looking for a bigger thrower, flooder, and a new EDC, give or take a few. I’m a flashaholic.
toddcshoe
toddcshoe's picture
Last seen: 9 min 12 sec ago
hank wrote:
That’s not the BLF Astrolux A01 (3 levels), it’s the cheap one-mode imitation that followed. Also, not floody, and not AA.
Present day A01’s are 4 mode actually, low, mid, high, and strobe. With a sometimes next mode memory, sometimes not. It has a mind of it’s own.
"Everywhere I go, there I am"
hank
hank's picture
> A01
Todd, would you mind putting that info on the contemporary A01’s flaky modes in one of the relevant threads? First time I’d seen anyone mention what they’re selling now.
Maybe here: http://budgetlightforum.com/node/44039
MascaratumB
MascaratumB's picture
Last seen: 15 hours 15 sec ago
A Sofirn SP10 A/B with some kind of diffuser on the lens! Has memory (with long press), and also direct access to Moonlight, Turbo and Strobe!
There is also the Sofirn SF10, in wich you can adjust the pill to fit a small pebbled TIR lens. The stock driver has mode memory, if I recall correctly.
Convoy T2, has memory and can be added a diffuser sheet to make the beam floodier!
Another one, more expensive and without memory, DGQ Slim AA Ti, that also fits one of those small TIR optics.
Last but not least, Wuben E05, has memory and can also be added a diffuser!
Thumbs Up
mk23
Last seen: 1 year 1 month ago
Lumintop Tool AA 2.0 : an awesome budget aa flashlight and it also come with a diffuser and a magnetic tailcap right in the box. If you get this light, remember to get the 2.0 version which is much better than the first ones.
Nitecore LA10: a bit low on power for my taste but it comes with high CRI emitter.
But for a worklight, i think the Manker E03H suits best. The Tool AA will be more versatile and can be used as an edc light.
ZoomieFan
ZoomieFan's picture
You are totally right. Shouldn’t post here after bedtime Smile
I’m looking for AA (but won’t delete the AAA in case somebody is looking for one on a nice discount)
toddcshoe
toddcshoe's picture
hank wrote:
> A01
Sure, no worries.
desmondkun
Last seen: 1 week 3 days ago
I have eagle eye x1 from gearbest but it’s not available anymore.
How about a convex lens aa flashlight?
Take care of your flashlight and your flashlight will take care of you.
agent80
Last seen: 1 day 3 hours ago
Klarus Mi7
ZoomieFan
ZoomieFan's picture
 I’ve been ‘researching’ all suggested flashlights. I’m wondering why the runtimes and output differs so much between 14500 and AA.
The footnote in the table below states the tests were done using an 2450 mAh AA cell and a 750 mAh 14500 cell
I can imagine an AA cell can’t handle high currents and that’s why the max. lumens can’t be as high as from a 14500 cell.
Turbo shows a AA cell can deliver 270 lumen; so why not 270 lumen on high?, or 85 lumen on Med, etc
Why is that? I see that the 14500 output is roughly 3 times higher for the 14500. Does the driver only regulate the amps and because 14500 has triple voltage the power at the same amps is also triple?
The 14500 cells even outperform the Eneloop on low. I would expect the Eneloop with over 3x the capacity would shine the there. On the contrary, the 14500 does 2.7 times better.
 What are the highest capacity 14500’s? The max. I found is 1200 mAh*. That would be 1.6x the runtimes.
*=To be honest the highest is 2500, but considering even 1200 is way above average (800) I think 2500 is just fake. Here
ggf31416
Last seen: 5 hours 56 min ago
NiMh AAs can handle the current. Unless we are talking about some lights like the not-exactly-small Zebralight SC5 that reaches 500lm on an Eneloop Pro, pushing them close to their maximum, the limit would be the small boost driver that increases voltage from 1.x V to the 3.x V used by the led. The best 14500 at the moment would be the Vapcell 14500 that has a capacity between 950mAh and 1000mAh.
hank
hank's picture
Seriously, just take a cheap SK68 and remove the lens.
It makes an excellent “mule” floodlight.
ZoomieFan
ZoomieFan's picture
Ordered:
  • Lumintop Tool AA
  • Lumintop Tool AAA
  • SK68
But still following this thread. Maybe I order one more Smile
RobertB
RobertB's picture
Last seen: 3 weeks 4 days ago
You don’t have your profile location filled in, and didn’t say where you are from, but these are great flooders
Zebralight SC5Fd
http://www.zebralight.com/SC5Fd-High-CRI-Floody-Neutral-White-AA-Flashlight_p_168.html
Zebralight SC53Fc
http://www.zebralight.com/SC53Fc-AA-Floody-Neutral-White-High-CRI-Flashlight_p_230.html
Zebralight H502d L2 or the H502d L2 right angle lights
http://www.zebralight.com/H502d-L2-High-CRI-Daylight-AA-Flood-Headlamp_p_142.html
ZoomieFan
ZoomieFan's picture
Zebralight SC5Fd
Zebralight SC53Fc
I live in Indiana and Netherlands, and can buy Zebralight locally in both places Smile
I got a 18650 Mk IV Zebralight. While good in high modes the PWM on low is awful. So I don’t really trust Zebra for low output lights.
RobertB
RobertB's picture
ZoomieFan wrote:
Zebralight SC5Fd
Zebralight SC53Fc
Strange, I have 5 of their 18650 lights, and never noticed PWM in any mode on any of them.
Sounds like you already know what you need
ZoomieFan
ZoomieFan's picture
You got that wrong sir! Crown
I bought several because I don’t know Facepalm
Johm
Last seen: 2 months 4 weeks ago
If you have a light that is close to what you need (in terms of beam profile), maybe use DC-fix.
A self adhesive film that diffuses the beam. (even sold here at blf, sorry can’t find the link)
ZoomieFan
ZoomieFan's picture
Are there AA only lights? If yes would they have any advantage over a 14500/AA light assuming I only want to use AA cells.
Same question,but 14500.
samyy
Last seen: 21 hours 49 min ago
Olight S1A.
hIKARInoob
hIKARInoob's picture
Last seen: 8 hours 3 min ago
Nitecore LA10. No memory though, but pure flood. And it’s got a magnet in its tail. I love mine a lot.
ZoomieFan
ZoomieFan's picture
That’s an unique light with that diffuser.
Even an high CRI version, but that has a greatly reduced runtime.
Is high CRI noticeable/effective with, what looks a heavily, frosted diffuser?
