OSRAM CSLNM1.TG & CULNM1.TG 1mm², CSLPM1.TG & CULPM1.TG 2mm²
I have (2) 2S 3v17mm 4-4.5amp Mtn. Max drivers and a 22mm 2S 3v 5.5amp Mtn.Max driver I’m looking for a Push Button Host(s) for…any Ideas?
https://maxtoch.com/maxtoch-x-pro-p0025.html
Ooh nice! Awesome host. I wish it had the choice to choose small tube for single 21700 like the size of acebeam t27.
Yeah, you’re right.
Limited choice.
Not sure what Lexel has to offer though.
As for diameters, you could use an adaptor ring of some sorts.
Either way, i’m looking for e-switch 17mm FET CC drivers.
I don’t care too much for elaborate UI’s though.
3 modes usually suffices for me.
Wow, 995 available at only $9999…. I better place my order soon….
I mean those are nice drivers he mentioned. It wouldn’t be right to recommend something less than $9,999
Nice 2x21700’s hope they come out with it soon… robo…
Pic stolen from the Maxtoch site… by me…
@BobbyMk: What driver are you using
Qlite 3.04A with added 3 7135 chips and biscotti fw.
Thanks!
I’ve built a C8+ with ld-A4 at 5A and white flat 1mm
I need to tune the centering ring heigh but at the moment I’m getting 211kcd nearly 920m
Is there any similar build? I’d like to compare them and also know how many cd should I expect
I will work on D1S and likely some other sizes CC FET drivers, but this will take 5-6 weeks at least to get to production if first design works out well
I’ll start saving money for you, Lexel.
There are some other drivers i want from you too.
Same, I’ll buy one or two for sure.
Did you measure the beam with a lux meter at what distance then convert to candela?
Yes, 3300lux at 8 meters
What CC FET driver design? Think someone (TA?) did one? Wondering, not sure, if parasitic drain was considered.
I’m very impressed. My C8 (BLF A6 DD, NCR18650B) is easily hitting houses at 800m distance(measured with Google maps). That’s the holy grail of LEDs for throwers.
Can’t imagine how the D1S will perform.
190kcd for the c8 measured at 10m.
Put a white flat 2mm^2 in an Emisar D1S. I wanted to add some resistance to the circuit so I could use the FET driver and limit the current to 6-8A. Switching the springs to high resistance steel would work if you had the right size springs. The battery compartment length is very tight on this light so it would have to be the right spring. I chose to add a separate resistor in the head of the light. I figured I would need to add about 0.1Ohms to limit the current enough with a 30Q cell. The resistance would dissipate around 4W. There is a good amount of room in the head to put the resistor. One could probably use the right combination of 1W resistors in parallel, possibly using thermal adhesive to sink them to the head so they don’t overheat. I chose to use something I had around, some 16 gauge nichrome heater wire. Two inches or so of the nichrome wire has about 0.1Ohms. A difficulty with this wire is that you can’t solder to it. To attach the stranded copper wires I lashed them together using fine gauge magnet wire.
Using a clamp meter I measured 6.0A with a charged (but old) 30Q. Ideally I would have wanted closer to 7.5A, so I might shorten the resistor. I used a XM sized “butterfly” style centering ring that fit the emitter hole of the reflector, then I just fiddled around closing the bezel until it finished centered. I had to add two layers of Kapton tape under the centering ring to get the focus right. I measured 221 kcd. This intensity measurement is consistent with the measurement of this LED at the same current in the EE X6 (111 kcd). This reflector has right around 2x the frontal area (I estimate 1270mm^2) of the EE X6 reflector (~620mm^2). It’s always satisfying when things make sense. :slight_smile:
EasyB,
That all is if you insist on using high current cell with fet and WF1mm… Low current cell like LG 18650D1 even in mod with classic bypasses wont pas 5.7A and without bypasses wont pas 5.5A
But of course very creative idea.
Samsung 30Q and other high current cells are only good for old G2 S4 2B (which is still one of my favorite emitters).
Edit: Just saw that is WF2mm… OK… Not bad idea indeed :+1:
