Armytek Prime Pro on a IMR cell is much brigher then a 2xAA.
On 4+year old Olight protected 14500 I am getting 485 lemons
Switch bodies and I can get 850+ on a Vapecell 18350
They go into direct drive or something close to it.
Like my Klarus Mi7. Great mode spacing. Very bright on a 14500 and AA eneloop.
Wuben E05 is very bright on Turbo (4 brightness levels when used with 14500). But when using AA, it has only 3 brightness levels, and its brightest level on AA is not so bright.
Lumintop Tool AA v2.0 lists 650 lumens on Turbo mode, but would seems to be a bit brighter than 650 lumens. The brightness spacing is more logically spaced than the Wuben E05 (on 14500, big gap from “High” mode to “Turbo” mode).
Lumintop EDC05 is another candidate, 800 lumens on Turbo (must program it first, since it’s set to 75% level from the factory).
Lumintop EDC05
Factory Default: Level ② Output 75% Brightness
By default, the flashlight doesn’t come at its highest output from the factory. You can manually set it to the maximum lumen output by going into programming mode.
14500 Battery:
Stage ③ Output 100% Brightness:
High: 800 lumens Med: 320 lumens Low: 100 lumens Moonlight: 10 lumensStage ② Output 75% Brightness:
High: 600 lumens Med: 240 lumens Low: 75 lumens Moonlight: 5 lumensStage ① Output 50% Brightness:
High: 400 lumens Med: 160 lumens Low: 45 lumens Moonlight: 1.5 lumens
comparing Klarus Mi7 vs Lumintop Tool AA v2.0
Mi7 is the left beam while Tool AA v2.0 is the right beam
Nitecore had a 900-1000 lumen single 14500 - the EA11, but it’s discontinued. They also had another very similar one with slightly different UI - MT10A, also discontinued.
To me, there’s a distinct difference between the 500-700 lumen lights, and the 900+ lumen ones. Below 700 lumens the lights are using conventional ICR 14500, so most cells, including protected ones, work. The 900 lumen ones need high discharge IMR chemistry.
samyy:Zebra SC5 II is NOT brighter than 500lm. Ok ,on the paper 550lm, in reality about 430lm.
So the brightest single AA flashlight I know is Armytek Prime A1 PRO - 465 real lumens (warm tint version).My first version Zebralight SC5w measures 450 lumens. I think the newer SC5 II, especially in cool white, has to be over 500 lumens.
You’re claiming the Armytek Prime A1 Pro is 465 lumens? I have the A2 warm, and it measures 450 lumens. I don’t see how the 1xAA version could be 465, if the 2xAA version is only 450. Granted, mine is the XML2 version, and I think the newer XPL version is brighter, but I don’t believe Armytek has made as bright a 1xAA light as Zebralight.
Generally the 1xAA can use 14500, but 2xAA only take Ni-MH. So they end up very similar in output. See Olight S1A and S2A.
WalkIntoTheLight: samyy:Zebra SC5 II is NOT brighter than 500lm. Ok ,on the paper 550lm, in reality about 430lm.
This means 2*AA can not use 14500? Could you tell me the reason plz?
EDCba: WalkIntoTheLight: samyy:Zebra SC5 II is NOT brighter than 500lm. Ok ,on the paper 550lm, in reality about 430lm.
I think not many drivers can handle up to 9 V. Fenix has one but lumens isn’t impressive. Another problem is safely discharging 14500 in series.
Another vote for the Wuben E05… I am really liking mine.
I don’t know if this will be considered a “custom” or a “production” flashlight (maybe the 1st, I guess), but is probably one of the brightest lights on 14500.
It is made by our fellow member vestureofblood, a.k.a. Matt, a.k.a. AdventureSportFlashlights!
“Everyday Carry Brass” - 1536 lumen (on XPL-HI V3-1B and using a high-drain 14500 battery)!https://asflashlights.com/home/105-everyday-carry-brass-3x-xp-l-hi.html
It can also be seen here, on his channel!
https://www.youtube.com/watch?v=Zlvfbx8wEwk
BTW, the main reason why I mention this is due to the “Unlimited bugdet?” part in the OP :money_mouth_face:
Impressive output ,BUT who is willing to pay $219 for a AA light whose battery can NOT maintain that output for long! Not me!! I would take the Wuben E05 and then buy another modded EDC and still have enough money to buy a $65 bag of Merrick Buffalo and sweet Potato for CAPO!!! :+1:
MascaratumB:I don’t know if this will be considered a “custom” or a “production” flashlight (maybe the 1st, I guess), but is probably one of the brightest lights on 14500.
Impressive output ,BUT who is willing to pay $219 for a AA light whose battery can NOT maintain that output for long! Not me!! I would take the Wuben E05 and then buy another modded EDC!
Sure, I’m with you too Still, in what concerns being “the brightest”, this surely reaches a place into the top ranking!! (I wish I could have it, though :money_mouth_face: )
The more I know this flashlight world, the more I’m inclined to choose better runtime over more output! The Wuben E05 seems to be a very good one or the best in the budget range to be bright and have decent runtime on a 14500 cell!
I subscribe that one as well as a good choice!!!
wolfdog1226: MascaratumB:I don’t know if this will be considered a “custom” or a “production” flashlight (maybe the 1st, I guess), but is probably one of the brightest lights on 14500.
You are right,it qualifies for the brightest! :+1: I was just looking at it from a practical point of view.
OT- I see you are from Portugal. I hope you bring me good luck!!!
I have a date at noon[6pm Roma time] w/ a woman whose blood is from Portugal but she was born in France. Her mom and dad moved there after her 2 siblings were born. She speaks French, Portuguese and of course English! She is Pretty and seems like a sweetheart,I must be on my best behavior!
You want a bright 14500, get you one of these bad boys!!
They have practical use at lower power & a SUPER DUPER ‘W.O.W Factor’ when you open it up!!!
Hi All, Up for sale is my latest batch of micro mags. I’ve used Mountain Electronic’s version of the FET+1 driver in these micromags as well as Samsung LH351D 4000k 90+CRI emitters on the Mountain triple copper board. This combination uses direct drive off a high drain 14500 cell to drive the light to 8 amps on turbo at start up, dropping to 6.8 amps at 30 seconds. There is around four to five minutes of run time before the light gives a low voltage warning when the battery reaches 3 volts. The…
Kyfishguy Micro Mags
…“around 2800 lumens at start up and 2400 lumens at 30 seconds based on emitter testing by Texas Ace”……
Okay, I thought we were comparing apples to apples, not oranges.
AKAIK, the Zebralight SC5 is the brightest single AA light on the market, that uses a NiMH cell. Yes, there are plenty of 14500 lights that are brighter, possibly including the Armytek on a 14500.
The Armyek Prime Pro 1AA is brighter then the Zebralight SC5.
Advertised, or independently tested? Issues with the Prime’s optics are well documented by now, and I do not believe the advertised OTF output for any model.
Read post 17. Armytek Prime Pro 1AA on a good IMR cell will do 800 lemons
Cool, how many oranges or apples will it do??
Just kidding around, couldn’t resist. …. :person_facepalming: …
LOL. Lemons is my un-official lumen guess
I’m surprised nobody mentioned the Klarus XT1A. I’ve been using it for a few months and I’m very impressed.
Specs state 1000 lumen, I guess it’s a bit exaggerated but still pretty strong.
