The clip just slides off such being that it’s a “C” style. The round tube/barrel of this tiny light has two machined-in flat sides. This great design/feature allows the clip to firmly/securely attach to the barrel which then allows you to reverse its direction for hat brim use as well. The barrel has just enough ‘roughness’ to let the clip grip and hold. Butt you can also adjust it firmly up or down the barrel length accordingly. That ‘roughness’ btw is actually very fine knurling.
This little flash is a GREAT bargain. IMO every modder should at minimum have these to practice on to help get used to working on miniature scale stuff. They also make great gifts that the gals really appreciate for their usually crowded/heavy purses.
Don’t let anyone dissuade you from owning some of these just because they aren’t this and that name brand or don’t have a loftier price. :disguised_face:
At this ridiculous price get some and then get some more before potential tariff impacts can change this faboo deal. :sunglasses:
PS. Ya wanna use it on yer hat brim, right? Well a zoomie is best for that simply becuz of its inherent flood capabilities. Flood mode on a hat tends to be the most practically useful and this little runt has enuff of it.
PSS. Here are better eBay pics of the SkyWolfEye Model E522 which shows the flat sides on the barrel allowing the clip to reverse for hat brims. Scroll all the way down the page to see those pics. This is the one ya wanna get. Shop around. They’re all over eBay. Ignore the 3500 lumen claims on all offerings. :laughing:
PSSS. Avoid the .99 cent-priced bait and switch lure-ins. Those are the major league POS ‘Police Specials’ which are only good for giving to sumone ya really don’t like. :laughing:
Some, not all, of the “Police” cheapies are useful because their battery tube head-end threads match the SK68 tail threads, allowing builing a 3xAA “SK68” frankenlight.
Yup. Back in the day I have used that exact set up you describe for extending SK68’s. IDK about these either butt at about $1.00 each I guess worth a shot.
Small, nice. Metal switch. Low price. AA or 14 500 cells. Three colors to choose from. Current price slightly over $ 10. Sofirn is a good brand. Ideal torch in your pocket.
I carried a SP10 V2 with a niMh in it on a recent European vacation and I liked it a lot. Small and more than bright enough. I usually take a Convoy S2+ on vacations but the SP10 is noticeably easier and more convenient to carry. The fact that it doesn’t need a li-ion battery is another big benefit.
I like a too, very much the Sofirn SP10 (B in my case).
It’s a pity, though, that the V 2.0’s UI and output are worse/weaker than ones in the first version.
There is a thread with detailed info.
Killer deal on a great little light and even comes with a battery. Coupon only works once per account so make sure you order the amount you want on that order.
Don’t know if there is a limit.
Later,
Keith
+1 on the Ultratac A7 AAA!! It is a neat little light & with the Vipon Coupon price on Amazon it is a no-brainer for sure. They make a great little gift light too. I got a lifetime supply……
I couldn’t stack them yesterday on something I wanted to buy. Next time I’m going to click the coupon and add the item to my cart , then try adding Vipon discount code and see if that does the trick.
SMO reflector instead of OP
starting with low (5lm) instead of eco (0.5lm)
lower output than v1 with 14500
lower output than v1( only about 170 lm with AA), the head is glued
it seems it doesn’t have memory when using AA (it must be confirmed by one who actually bought it)
