Yup. Back in the day I have used that exact set up you describe for extending SK68’s. IDK about these either butt at about $1.00 each I guess worth a shot.
Small, nice. Metal switch. Low price. AA or 14 500 cells. Three colors to choose from. Current price slightly over $ 10. Sofirn is a good brand. Ideal torch in your pocket.
I carried a SP10 V2 with a niMh in it on a recent European vacation and I liked it a lot. Small and more than bright enough. I usually take a Convoy S2+ on vacations but the SP10 is noticeably easier and more convenient to carry. The fact that it doesn’t need a li-ion battery is another big benefit.
I like a too, very much the Sofirn SP10 (B in my case).
It’s a pity, though, that the V 2.0’s UI and output are worse/weaker than ones in the first version.
There is a thread with detailed info.
Killer deal on a great little light and even comes with a battery. Coupon only works once per account so make sure you order the amount you want on that order.
Don’t know if there is a limit.
Later,
Keith
+1 on the Ultratac A7 AAA!! It is a neat little light & with the Vipon Coupon price on Amazon it is a no-brainer for sure. They make a great little gift light too. I got a lifetime supply……
I couldn’t stack them yesterday on something I wanted to buy. Next time I’m going to click the coupon and add the item to my cart , then try adding Vipon discount code and see if that does the trick.
SMO reflector instead of OP
starting with low (5lm) instead of eco (0.5lm)
lower output than v1 with 14500
lower output than v1( only about 170 lm with AA), the head is glued
it seems it doesn’t have memory when using AA (it must be confirmed by one who actually bought it)
