That’s exactly how to do it kikkoman. And yes, thermal throttling (if it does it) will be disabled on the PIC. Only the Boost IC overtemp. protection can then save it.
Thanks for explaining the possibility to switch the H1-A with a momentary button.
I plan to switch modes with an external microcontroller. Basically i only need two modes (33% and 100%) and i want a microcontroller or bluetooth remote to switch through the modes for me. By chance do you know the voltage and current of the pcb trace, which needs to be cut? I could measure it myself, but the driver is still in shipping.
Here is an recent image from a H1-A driver ordered 01/2019.
I need to find a way to have only two modes 33% and 100%. Because i don’t have any idea how to program a PIC, i had the idea to use an external microcontroller to switch through the modes for me. The MCLR pin seemed to be a good solution. Pulled to the ground, the PIC should do a software reset. Therefore i desoldered the MCLR-Pin from the board and pulled the pin temporarily to ground. But nothing happens. The driver just works as before.
Besides a custom firmware, which would be great, do you have any idea how to get only two modes?
Here’s a driver which will run an LED from body heat using a TEG or Peltier stack. Input voltage polarity does not matter and I found it works well. Custom Thermoelectic and TXL Group sell these boards for $19US or you can get the unipolar version for only $14 (it has half the component count).
And here’s another energy harvesting driver which will run an LED off of body heat via a Thermoelectric Peltier or TEG, only 25mV required! The resistor and capacitor in center can have two different value pairs, depending on the design revision. The caps with question marks need to be pulled off the board and measured out of circuit. They’re 0402 parts! You can buy the PCB for only $12 from the usual electronics component distributors.
Quick question fellows, does anyone knows which type of reverse polarity protection MOSFET the H1-A driver employs? It's the small 3 pin thing at the board backside, just g00gl€d the markings but no hits. The usage of such small MOSFET is also a tad strange to me, it totally looks inadequate given the amount of input current it should handle.
Just tried to resister mod the h2-c driver from KD. It’s is now garbage, stuck on low power blinky mode. The driver also uses an different layout (compared to the pictures in the convoy L2/l6 mod thread ). The sense resistor on my version also had an r50 instead of the r100.
The sense resistor was never an R100 in the H2-C Hellie112. Jensen567's early unit had two R100 resistors stacked, that equals 50mΩ (=R050).
Carefully check what you did to the sense resistor or other parts of the layout. “Low power blinky mode” looks to be low battery warning. If you have increased the power output and are using just 1 cell as input bear in mind other parts in the circuit causing voltage drops need to be optimized, this means good switch and well done spring bypasses or high current springs (you should optimize the current path anyway). Maybe you went overboard reducing the sense resistor.
I didn’t had much time this afternoon. Guess never mod when you are in a hurry But a trace on the backside (close to the spring) was completely burned. Did a bypass but now the driver pulls 10 amps (at the battery)… no change in output when changing modes. But I still got the flashing mode…
