How many people will buy SP36 Anduril with XPL2 5000K ? Maybe 80 CRI according to the availability from supplier.
I’d consider a second one. It sounds like a winner.
Hey Sofirn. Please answer my AliExpress PM. I have a problem with defective battery holder on my SP36
Sorry for the slow reply, please Check the PM, and do not worry any warranty of Sofirn lights.
We have finished weekend and start work today in out time.
Yes I’ve PMed back. Thank you so much
I would buy one.
In my opinion 80 CRI is the best compromise colour rendering for high output flashlights so if 80 CRI: .
Sofirn, does your supplier give a tint bin for the 5000K 80 CRI XP-L2? Or at least a Cree order code?
I’m not committing yet to buying one though.
I don’t like the xpl2 tint shift
My SP36 has xpl hi 5000k and the beam is very nice
I’d like to try it with SST20
The attraction of XP-L2 is of course the output in direct drive, this will justify the yellow corona for many especially non-flashoholics, no other 3535 led will get you so much light (although the Samsung LH351D comes close, a 80CRI variant of it would be a good choice also).
My SP36 now houses sliced 4000K 90CRI LH351D leds, makes 3500K in 93CRI and has great tint. But I’m down to under 3000 lumen now so that comes at quite a price. That is why I see 80CRI as a good compromise.
This is killing me... Has anyone taken/posted pics of the driver? Wondering if there's space I could drill in to. I think only 2, maybe 3, have gotten out the driver - any pics, please?
I applied a fair amount of force with a soft handled screwdriver before the wires solder joints gave way, oh boy.
If I destroy the driver, I'd lose the USB charging for a replacement. Will Sofirn be selling drivers like they do for the Q8, some other lights?
That would be another option - simply destroy removing the stock driver, pop in a replacement with no glue -- sounds good to me...
These XP-L2's gotta go, though it would be nice to retain USB charging.
You did try the solder-a-loop-to-the-brass-ring method, right? (see post 62 of this thread, someone else managed the same with a thick copper wire). I had to use my 80W (quality!) solder iron with massive chisel-shape tip to get the heat quick enough into the brass to solder the loop and not unsolder the brass ring. The loop held and the driver glue gave in.
Yes - used 16 AWG wire, nice rubber handled screw driver, this one shown below. No pics, but I soldered the wire little towards the side away form the USB connector, fearing I might damage it when the driver loosens. The solder is what broke, not the wire, nor the brass ring. I had a lot of solder on there, but didn't get a chance yet, but will try again using a big iron tip and more heat. The Hakko FX-888 was set to about 710F, but can go up to 900F.
Hakko FX-888 (prior to the FX-888D model) I use:
I did swap out the stock dual springs for the large Blue BeCu ones (no bypasses) and measured a slight boost in lumens using the same VTC6 cells. So slight, hard to say whether it was a real boost or not based on typical measuring variables. Only other difference was added solder to the tail PCB on the screw holes where they lay up against the alum battery tube, and added NO-OX-ID on the screw contact surfaces.
The copper strip that I used has a larger contact surface when soldered than a piece of wire, that may be a next step still. But if you have a SP36 copy that by chance has a bit extra glue applied on a cleaner surface you may be unlucky enough to be stuck with an extra tight driver.
This would be good for my liking.
Thanx djozz! Will work on it more, and yep, understood bout the copper strip. Still would appreciate any pics of the driver, top side.
If the brass ring pulls off before the driver and damaged beyond repair, then it's Drill Baby Drill!
Yes, I would buy one like that.
I'm not fond of the ugly beam with tint shift of the XP-L2's. Not sure if there's an optics setup that will make it look better, but I'd much rather see the "good" non-green Samsung 351D's.
And ohhh, did I mention the glue for the driver is a really, really bad idea? Please..... do something better - screws or retaining ring?
I would buy a XPL-Hi version of the SP36
This is with the large BeCu springs installed, extra solder added on screw hole mounts:
NO-OX-ID treatment on contact surfaces:
Finally got the driver out, no damage. This is first attempts with solder joint breaking:
Got it off with just one end of the wire soldered, wrapping the wire around the screwdriver and pulling:
This is a whole lot of adhesive, way too much:
It does seem to soften with heat I noticed, so probably would have been easier pre-heating:
Nice view of the driver. Those stripped traces are a little strange. Looks like the same FET in the Q8. Extra circuitry for the USB-C charging:
Inside of pill showing the screws:
