How many people like C8F with 3* SST20 4000K 95CRI?It will be quicker and easier.
I know some say a single XHP family + bigger head + 21700 tube or 26650 tube light gives 15k+ cd, it’s a new light which takes longer time to fulfill.
Furthermore, there is already a light such as thrunite Catapult V6 like that, how could Sofirn makes it better?
Note:
If you guys want tell new ideas for Sofirn light, please just PM me, but contact aliexpress sales only for order related topics. Simple and clear communication helps us making acurate plan.
I think quite a number of people have modified or built their Sofirn C8F to have 3x Samsung LH351D (4000K 90CRI or 5000K 80CRI), maybe could also have that as an option?
I think both the SST20 4000K 95CRI and the LH351D 4000K 90CRI would be a great emitter choice for the C8F. I’m weighing up which of these two options to put into my own C8F.
I can’t say I’d defiantly buy another C8F just because they became available with SST20 4000K 95CRI emitters, but I would choose the SST20 over the current XP-L.
Yep I have the Nightwatch NA40 SE with SST-40 emitters and it measure 3,970 lumens at 1s. I love the usb-c recharge being separate from the head so you can swap the driver and still retain usb recharge. They are now offering SST-20 3000k and 4000k option. The SST-20 3000k they are using has a very good below the BBL tint. I think it is most likely the HD2 tint bin.
Sofirn, do you have any idea what tint bin and flux bin you are getting with the SST-20 or LH351D?
Also putting in the CSLMN1.TG or CSLPM1.TG in the C8F would be good. Usb-c recharge would be very nice to have.
I put 3 LH351D 4000k in mine and the overall result is great, I love the tint, and the rings can only be seen when pointing to a white wall (the rings exists also with the stock leds)
Yours looks way more centered than mine. I used the older 18650 host and did 3x SST-20 4K sliced dome. I would probably leave dome on if I did it over again but I was re-using LEDs from another build.
@Contractcr, centering rings did all the work, ALTHOUGH I did have to slightly widen the MCPCB-to-Reflector screw hole slightly (~0.4mm) because it was not aligned with reflector (thanks to DJozz for first pointing this out)
Hopefully Sofirn can correct this problem and/or improve QC.
Don’t know if this helps with what you need to see but here ’ya go. Both about 4-feet from an off-white wall.
I don’t have a reflectored triple XP-L Hi for comparison (I do have TIR triple but that’s too floody), so I grabbed a single reflector XHP35 HD for comparison.
Haikelite SC26 w/XHP35 HD warm/neutral for comparison (on Left), Sofirn C8F w/SST20 4000K (on Right);
FWIW, at longer distances my C8F config continues to appear even tighter (~30%) than my SC26.
EDITED - added a short distance beamshot
Both about 40-ft from a white fence
Note:
If you guys want tell new ideas for Sofirn light, please just PM me, but contact aliexpress sales only for order related topics. Simple and clear communication helps us making acurate plan.[/quote]
Easy. Make turbo in the mode sequence and so that turbo can be memorized.
In Modes, the difference between memorized and non memorized turbo is practically nothing. Single click for memorized or double click for non memorized. The extra click bothers you?
What he is trying to say: “If you put a CSLPM1.TG in a host the size of a Catapult V6, it will throw much farther with only a small drop in lumen output.
Late to the game on this, but was there a reason for the dual switch? I’d be interested in a single side e-switch C8F (21700 triple) ideally with Anduril Having the single switch would enable it be slightly shorter too. Does something like this already exist?
I don’t know anything about the XHP, but SST20 4000K 95CRI would be nice, especially if tint was below BBL.
It works with the unique UI. You can operate the light as if it were a single e-switch only, or you can use the rear switch to turn the light off which would then allow you to turn the light back on at the previously-used level using the forward clicky switch in a tactical way. For instance, flashing Morse code, etc.
