Klarus Mi1C and Astrolux MH10 codes expired, could you get new ones?
Hello my dear friends!
i just received another list with deals:
please note: do not share my deals on other places!
Item | Code | Coupon price |
IMALENT DT70 | CHBF1 | 165,00 |
Folomov A1 | HBGLK | 5,69 |
FOLOMOV 18650S | drop directly | 20,50 |
IMALENT HR70 | JKLH1 | 53,00 |
LUMINTOP EDC05 | BGED5 | 22,00 |
Ultrafire 7W Zoomable | drop directly | 2,69 |
Nitecore EC4S | BGEC4S | 58,99 |
Convoy L6 | BGCL6 | 44,84 |
XTAR VC4 | drop directly | 14,80 |
NEW Convoy L2 | drop directly | 35,49 |
Astrolux MF02 CW | BGMF02 | 75,00 |
Astrolux MF02 NW | BGMF02 | 75,00 |
DQG Lighter 2.0 | BGDQG1 | 18,22 |
DQG 4th | BGDQG2 | 24,50 |
DQG Hobi 10180 | BGDQG3 | 16,99 |
DQG Fairy Brass | BGDQG4 | 16,99 |
DQG Slim | BGDQG5 | 23,75 |
DQG XP-G2 | BGDQG6 | 31,99 |
DQG Capsule Mini | BGDQG7 | 6,69 |
ThorFire VG10S | BGS70 | 15,99 |
ThorFire TG06S Upgraded Version | BGT6S | 11,90 |
ThorFire TK05 | BGTK05 | 14,99 |
ThorFire C8s Suit | BGC8S | 19,99 |
ThorFire 360 | BG360 | 6,99 |
5Pcs USB Mini Night Light | drop directly | 1,10 |
due to code stealing and brainless publishing of some 4$$holes i cannot get new Klarus deals atm
/\ … …. Utterly amazing what dipshytes a very few people can be…. but messing things up for Martin & everyone else.
Excuse my ignorance, but how the “drop directly” works?
Thanks!
i hope they fix those tomorrow - sorry
M4X: And what about that Astrolux MH10?
i ask for a new code
Many of you asked me where to get the RovyVon brand with "Member Benefits" - so i pulled some strings...
banggood listed at first 2 modells (the link in the pictures take you to the shop for detailed infos)
do not forget to check my list for the deals
RovyVon Angel Eyes E300S
Features:
- Rectangle EDC Angle LED Flashlights
- Made of aluminum alloy with Hard Anodization III finish
- Utilizes 3 x CREE XP-G3 S5 LEDs, max output 2000 lumens
- Uses replaceable rechargeable Li-polymer 2200mAh battery
- Max 5C discharge rate
- Micro USB charging and quick charge
- Breathing charging indicator and low battery indicator
- Overcharge and over discharge protection
- An internal thermal control sensor
- Ergonomic design for a comfortable
- Heat dissipation and anti-slippery grooves
- Strong detachable reversible pocket clip
- Stand capability
Parameters:
Body Material: 6063 aerospace aluminum alloy
Clip & bezel material: Stainless steel
Dimensions: L101mm x W36.7mm x H17.3mm
Package Included:
Accessories: 1 x 1m paracord, 1 x Clip, 1 x Micro USB cable, 1 x extra USB port cover
RovyVon Aurora A5
Features
- Semi-transparent luminous body glows in the dark
- CREE XP-G3 LED, max output 550 lumens
- Sidelight: White, Red, Red flash
- Built-in Micro USB charging port
- 130mAh lithium polymer battery
- Charging indicator & quick charged in 45 minutes
- Side switch prevents accidental activation
- Ergonomic design, one-hand operation
- Tail paracord hole
- A lanyard and two-way clip included
- IP65 water resistance
What's in the box
- 1*A5 flashlight
- 1*User manual
- 1*Beaded chain
- 1*Clip
- 1*USB cable
- 1*Lanyard
*The max output 550 lumens at High mode will step down to 65 lumens in 2 minutes to protect the user and the core components of the light from the heat produced by the light working at High mode.
Not a huge discount considering that banggood price is higher than MSRP and charges shipping
I was told they charge banggood rather high
banggood created a collection for the most wanted items paired with a nice discount:
also they added some additional promotions and deals for you!
Let me know what you scored ;)
edit:
the mobile webpage (m.banggood....) has a problem today
the link above does work
banggood tries to fix that asap
in the mean time use a pc or set your mobile browser to "desktop mode"
The link does not work Martin…. for me anyway.
just the mobile webpage (m.banggood....)
the link above does work ;)
Doesn’t work on my phone but works on my laptop.
[Edit]
Oops M4D M4X beat me to it and posted explanation
By the way, thank you for all the great deals M4D M4X!!
Oh… OK, thanks Martin. Sorry about the ‘false alarm’. .
BG is killing me with their great discounts on non-stock items though, then like what happened to my over the holidays, ordered 2 lights at a great deal, not in stock, asked to split the order, I did and chose to keep the order alive, then they cancelled it on me with no explanation, and of course, coupon codes expired, can't be re-ordered at the same price...
I'm seeing the same thing in those collections of non-stocks. Is it a teaser? Well, probably not intentionally but effectively...
I still get the big XMAS code discount on a couple lights though that are shipped, so it's not everything for sure, just some.
Make an argument that they are the ones who cancelled. They should reorder at the same price you originally paid. The fault is not on you.
Got a BG order in since Dec 31st for another SP36 at a great price, but shows expected Jan 28th. Wut?? I know they are gonna cancel this order on me too...
please do not post prices ;)
