There should be, but I’m not exactly sure.
Will check when I come home tomorrow.
thanks
Interested in 30 LH351D in a T2 or T4 bin.
Please disregard, I posted too quickly and didn’t see that only T6 is available…
Please put me down for:
10 of each spring,
6 sst20 4000k,
6 lh351d
1 3500k sst20
1 3000k sst20
So, for the SST-20 3500k early bird:
BlueSwordM 10pcs
rcywilly 10pcs
SKV89 20pcs
808Hi 15pcs
Tom E 28pcs
netprince 8pcs
dmsoule 10pcs
HONDARIDER 10pcs
Bob_McBob 10pcs
skinny_tie 10pcs
Pavlo 6 pcs
Total early bird: 142 pcs
Oh boy.
1560 large springs
1540 small springs
365 SST-20 4000k
282 SST-20 3500k
106 SST-20 3000k
So, djozz,
Lithium, how many early bird SST-20s 3500k GA3 J4 do you want?
I’ll be receiving them today in the afternoon, so I will try and ship everything tomorrow.
Hmm, how about 6 8 ? If they are available of course.
Excellent then.
Early bird SST-20 3500k GA3 J4:
BlueSwordM 10pcs
rcywilly 10pcs
SKV89 20pcs
808Hi 15pcs
Tom E 28pcs
netprince 8pcs
dmsoule 10pcs
HONDARIDER 10pcs
Bob_McBob 10pcs
skinny_tie 10pcs
Pavlo 6 pcs
djozz 8pcs
5 for me please!
Excellent. Will send a PM to both you and djozz.
Prepared all of the orders, and will ship tomorrow.
Will reflow the SST-20 in my EDC TK15 to see how much throw and how much better the tint is
Hank's (IOS) D4S listing page is a great reference to compare how the various LED's do in a real flashlight, though it's using just TIR optics:
https://intl-outdoor.com/emisar-d4s-26650-high-power-led-flashlight-p-932.html
Of course this depends on bins of the LED's used... Also what's missing is the amps these are pulling. You would assume the XP-G2's and XPL's would pull less amps.
Hi
SST-20 3000k and 4000k available ?
Please read the opening post, down there, it's accessible.
By the way, who else is noticing thread auto-subscriptions upon revisit to take a peek?
So, finally did the tests with the 3500k SST-20 vs the LH351D 4000k.
Picture of die size comparison
Tint comparison with SST-20 3500k and LH351D 4000k on similar reflectors at 1 amp.
And by god is the 4000k LH351D green compared to the 3500k GA3 SST-20!
I also got a significant throw increase by swapping in the SST-20 in my Thorfire TK15, and a nice increase in red color rendition, probably given by the lower CCT and lower duv. It’s a pure 3500k tint at 1 amp.
Nice! Thanx!!
I don't notice the green much in the LH351D's, but comparatively it could be lot more obvious. Also I got mine from Richard at MtnE - it's a P6 bin but that's all I know bout the tint.
Yeah.
Also reds look so much better.
Please add 10x SST-20 3000k to the interest list for me. Line 47 on the sheet. Thanks!
MikeMacD updated to the list.
Also, will send a PM to Britanny and djozz now
So, after seeing the reports of the small springs being a bit too big sometimes, I have made some tweaks to the design:
Material: Beryllium Copper C17530 38% IACS
Spring upper diameter: 4,5mm
Spring base diameter: 6,0mm
Spring thickness: 0,8mm
Spring height: 10,5mm
Total number of coils: 5
Plating: Silver electroplating
Same thing for the large spring:
Spring upper diameter: 6,50mm
Spring base diameter: 9mm
Spring thickness: 1,0mm
Spring height: 12,5mm
Those leds look really good, I look forward to trying them.
Blue, i’m happy about the spring changes. I agree the first batch was sometimes too big and sometimes just right. Even with the new dimensions the “just right” cases would still be good and not too small.
I do wonder though, instead of changing the height have you considered just removing a coil and letting them be wider spaced? Once compressed with the same number of coils the height change will not be very noticeable. However, if you keep the same height, remove a coil, then after the first compression they will be shorter w/ less material so possibly even lower resistance?
