I love Olight hosts and UIs, but their emitters make me want to ‘emit’.
I hate smooth hosts. My Thrunite T10ti would be a great EDC, but it’s like trying to hang into a fish. (P.S. Major scientific discovery - hockey tape won’t stick to titanium!)
Looking at that UI reminds me of another unpopular opinion of mine:
Depends what you need. Any light that has shortcuts to highest/lowest is useful, and memory can be used repeatedly for on/off use without having to ramp/step each’n’every time.
Eg, the way I use my MH20 is to be able to shortcut to lowest with a halfpress’n’hold, brightest with fullpress’n’hold, simple click to anywhere in-between.
One of the SP10s has press’n’hold to lowest, and N-click to brightest. Same dealy.
Other lights, I reset them to lowest if there’s no shortcut to lowest, then cycle through. Force of habit, not much effort to do it once it gets ingrained into you.
Seems like I did it right and it is an unpopular opinion.
That’s what I mean by working around. Single click is by far the easiest and most natural action on a flashlight. I don’t use single click on the Olight. I don’t use single click on the D4 either. Because it is just output lottery. So I use double click for turbo/high. And I am forced to press and hold the switch for moonlight on the Olight (for ages, it appears) and then have to press it again for ages just to enter low mode. Holding it for too long enters lockout mode btw. It’s kinda frustrating. If I could, I would just set it to always turn on in low mode. Press and hold would than be moon, single click low, double click high/turbo. Still love the M2R for everything else. But yeah. Unpopular opinion is unpopular. At least make it a configurable option. Which it is not in the vast majority of lights.
P.S.: I really like this thread. Many otherwise unvoiced opinions, ideas and flashlights.
Yeah, but I was saying that if you’re, say, looking under the hood of your car and only need the light every now and then, do you really have to choose between keeping it on all the time to stay at the same setting, or every time you use it, have to ramp-up to the brightness you want?
Unless I’m using a 1-mode light (like I have for ages, my trusty ’502), I’d prefer the flexibility.
For my Cometa, though, yeah, memory’s off, because most times I use it late at night when I only want moonlight.
NiMH is good enough for most flashlight needs.
Any light bigger than 1xAA/1xCR123 is too big for EDC.
Muyshondt lights are perhaps the most overrated flashlights in history and the cult of personality on non-budget flashlight forums around them is insane and approaches a level of fanboyism usually reserved for Star Wars and Apple products. They’re very good lights (Aeon owner speaking from experience) but they aren’t perfect, or even great, and they’re barely worth 1/3 of what they sell for.
The Nichia 219C has rendered the Cree XP series of emitters obsolete for EDC purposes.
1xAAA lights are too big to be keychain lights.
Friction fit clips are fine.
Buying primary lithium batteries is a waste of money when rechargeables are readily available.
People only use 10440s/14500s in their lights because they want to look like cool hotrodders, not because it’s any more useful than 1.5v or 1.2v cells.
If I can jump to the lowest and the highest setting from off, mode memory is a complete waste of time and battery life.
I love the designs of hanko's flashlights....
I still keep my unmodded NovaTac 120P by my bedside and put it to use periodically. I was tempted to mod it, but decided against it — it’s actually quite fine as stock. Doesn’t need to be super bright, or super efficient.
- Suppose you admit owning too much flashlights - which one(s) would you get rid of.
- Why be a color fanatic if you only once had a light that really was too fugly to turn on.
- You dearly wanted a BLF GT, but not for any practical reason.
- And are absolutely not in the market for the GT conversion kit from XHP35 to XHP 70.2
- But if it came in a complete “lightmachine”, you might be schlepping both of them around on every trip.
- AAA-lights are nice if you don’t have a smartphone. Like me. And cargo pants are not appropriate.
- A light feels nice if it protrudes just a bit on both sides of the fist, so a big 14500 or a small 18650.
- A strike bezel ads nothing if the rest of the light is smooth and slippery or made of paper-maché.
I don’t mind short turbo modes that last a few seconds, I think they are a nice option to have.
I would like flashlight makers to design “smoother” flashlights, just a simple cylinder without different radii or indentations, and with rounded corners, at least for smaller flashlights that are stored in pockets and are used mostly without gloves.
I think it would be very cool if piston drive flashlights returned.
seems like would love the wowtac UI
ZebraLights new UI does just that. I have one of my mode sets setup like that. It is very enjoyable to use like that.
Hockey tape sticks to itself, you need to make a couple layers that overlap and keep it tight.
Source: Am from MN lol
- Throwers are largely pointless. I have a C8 and I enjoy fiddling with it, and it’s fun to use and show off with, but it was cheap, and I wanted a thrower among my repertoire of torches. To me, the expensive ones (BLF GT, Astrolux MF04S etc) are a complete waste of money. They have very, very few practical uses beyond the initial ‘wow’ factor.
- I really like my 6D Maglite
- The build quality of Astrolux torches is way below par
D4 vs. PT16.
The MecArmy PT-16 triple, along with its interchangeable head, efficient, protected charging port siblings, represents an underappreciated and inspired design.
Ahead of its time, poorly marketed, it was initially priced out of line. Purchased via the ‘inside information coupon code’ provided to BLFers by IS, almost continually since its introduction, the price has been barely more than the D4.
Had the Emisar debutante included the far superior, larger than Carclo optics, protected self charging, circuitry, safety and heat dissipation, the flashaholic world could have different icons.
Had MecArmy asked for UI assistance from the Green Semi-Diety, instead of the team of young military equipment jewelry/outdoor sports enthusiasts taking over their design team, MecArmy would be more than a footnote in North America.
If IS had not straightened out their Military-tactical weapon UI for sales in North America, the PT 10,14,16 and 18 would have been burdened with the same sad sorry UI corporate parent company Altun has insisted on for their CooYoo and Blackwater quasi-clones of the PT-16.
To further demonstrate their lack of marketing acumen, the triple reflector version has only been made available in the exorbitant titanium, brass, and ‘rare’ copper, (not-for-carry) shelf queen editions.
Among the first to recognize, review, value, exalt, modify and carry the PT16, Dale (DB Custom) tricked his into using an 18500, and squeezed D4 level lumens from it. If he, the asteroid resident, and Illumination Supply had been calling the shots, Emisar could be playing catch-up.
Fireflies, Sorfirn, Lumintop (et. al.) learned to read English language flashlight forums that did not diss lights for supposedly copying pineapple/diamond patterns on flashlight tubes, as if proprietary
I do not like 14500 lanterns, which are big and heavy like some 18650 lamps.
The $ 15 light bulbs are WiFi, but the flashlight with a complicated UI for $ 100 is controlled by one switch.
I hate lights that can be accidentally switched on in my pocket. The electronic lock in FW does not cost any money, so why is not it there?
I hate yellow tint in flashlights. It reminds me of an old incandescent flashlight that’s in its final stages of dimming because its batteries are about to go dead, so I feel an impulse to turn it off so as to conserve battery power. Years of going on backpacking trips as a kid with incandescent flashlights and headlamps kind of traumatized me. Seeing any flashlight today that has a yellow beam is like being in the same room as an unflushed toilet. It just makes me uneasy.
Copper patina looks gross to me, like a penny that has been touched by thousands of people whose hands have been God knows where before they touched the penny, or like an alkaline battery leaked on it. Brass patina is fine.
Complicated UI’s are great for an EDC light because we’re all unique in our everyday needs, but an outdoor light should only ever have an intuitive, simple UI that can be operated with cold hands, gloved hands or adrenaline-shaking hands. Stop with the double freaking clicks!
Reversible pocket clips are needlessly bulky, and most people who whine to manufacturers to put them on their lights probably don’t even wear brimmed hats regularly. And the ones that do wear baseball caps around probably don’t wear them at night that often. Tail cap magnets are also terrible. Some people just need to learn how to use a headlamp.
The cyan Emisar D4 is one of the best looking lights I’ve ever seen, and I love the “chalky” texture.
I quite like my cyan D4.
I’m not a fan of the chalky texture, but on the other hand it does provide much better grip than the smooth D4, and the cyan D4 is much less chalky than the white D4.
Yeah, but if they have a magnetic head, the tailcap magnet is so much easier than those bulky sweaty elastic bands.
