Second Generation Silver Plated High Current Beryllium Copper Springs and 95+CRI SST20!
696 posts / 0 new
BlueSwordM
BlueSwordM's picture
Last seen: 5 days 23 hours ago
So, for the SST-20 3500k early bird:
BlueSwordM 10pcs
rcywilly 10pcs
SKV89 20pcs
808Hi 15pcs
Tom E 28pcs
netprince 8pcs
dmsoule 10pcs
HONDARIDER 10pcs
Bob_McBob 10pcs
skinny_tie 10pcs
Pavlo 6 pcs
Total early bird: 142 pcs
Oh boy.
1560 large springs
1540 small springs
365 SST-20 4000k
282 SST-20 3500k
106 SST-20 3000k
So, djozz, Lithium, how many early bird SST-20s 3500k GA3 J4 do you want?
I’ll be receiving them today in the afternoon, so I will try and ship everything tomorrow.
djozz
djozz's picture
Last seen: 2 hours 57 min ago
Hmm, how about 6 8 ? If they are available of course.
BlueSwordM
Excellent then.
Early bird SST-20 3500k GA3 J4:
BlueSwordM 10pcs
rcywilly 10pcs
SKV89 20pcs
808Hi 15pcs
Tom E 28pcs
netprince 8pcs
dmsoule 10pcs
HONDARIDER 10pcs
Bob_McBob 10pcs
skinny_tie 10pcs
Pavlo 6 pcs
djozz 8pcs
Lithium
Lithium's picture
Last seen: 1 week 2 days ago
5 for me please!
Want DC-fix? PM me!
BlueSwordM
Excellent. Will send a PM to both you and djozz.
Prepared all of the orders, and will ship tomorrow.
Will reflow the SST-20 in my EDC TK15 to see how much throw and how much better the tint is Smile
Tom E
Tom E's picture
Last seen: 57 min 55 sec ago
Hank's (IOS) D4S listing page is a great reference to compare how the various LED's do in a real flashlight, though it's using just TIR optics:
https://intl-outdoor.com/emisar-d4s-26650-high-power-led-flashlight-p-932.html
  • The 95+ CRI SST-20's seem to do about the same throw as XP-G2 S4's, little lower in lumens, nice upgrade in throw and CRI bump from 219C's
  • The 5000K SST-20 seems like a great compromise of excellent throw, lumens, and tint, if the lower CRI and tint is ok for you
Of course this depends on bins of the LED's used... Also what's missing is the amps these are pulling. You would assume the XP-G2's and XPL's would pull less amps.
Athlon2350
Last seen: 1 month 2 days ago
Hi
SST-20 3000k and 4000k available ?
Barkuti
Barkuti's picture
Last seen: 18 hours 39 min ago
Athlon2350 wrote:
Hi
Please read the opening post, down there, it's accessible.
By the way, who else is noticing thread auto-subscriptions upon revisit to take a peek?
Party
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
BlueSwordM
So, finally did the tests with the 3500k SST-20 vs the LH351D 4000k.
Picture of die size comparison
Tint comparison with SST-20 3500k and LH351D 4000k on similar reflectors at 1 amp.
And by god is the 4000k LH351D green compared to the 3500k GA3 SST-20!
I also got a significant throw increase by swapping in the SST-20 in my Thorfire TK15, and a nice increase in red color rendition, probably given by the lower CCT and lower duv. It’s a pure 3500k tint at 1 amp.
Tom E
Tom E's picture
Nice! Thanx!!
I don't notice the green much in the LH351D's, but comparatively it could be lot more obvious. Also I got mine from Richard at MtnE - it's a P6 bin but that's all I know bout the tint.
BlueSwordM
Yeah.
Also reds look so much better.
MikeMacD
Last seen: 4 months 1 day ago
Please add 10x SST-20 3000k to the interest list for me. Line 47 on the sheet. Thanks!
BlueSwordM
MikeMacD updated to the list.
Also, will send a PM to Britanny and djozz now Smile
BlueSwordM
So, after seeing the reports of the small springs being a bit too big sometimes, I have made some tweaks to the design:
Material: Beryllium Copper C17530 38% IACS
Spring upper diameter: 4,5mm
Spring base diameter: 6,0mm
Spring thickness: 0,8mm
Spring height: 10,5mm
Total number of coils: 5
Plating: Silver electroplating
Same thing for the large spring:
Spring upper diameter: 6,50mm
Spring base diameter: 9mm
Spring thickness: 1,0mm
Spring height: 12,5mm
netprince
Last seen: 28 min 12 sec ago
Those leds look really good, I look forward to trying them.
contactcr
Last seen: 3 hours 19 min ago
Blue, i’m happy about the spring changes. I agree the first batch was sometimes too big and sometimes just right. Even with the new dimensions the “just right” cases would still be good and not too small.
I do wonder though, instead of changing the height have you considered just removing a coil and letting them be wider spaced? Once compressed with the same number of coils the height change will not be very noticeable. However, if you keep the same height, remove a coil, then after the first compression they will be shorter w/ less material so possibly even lower resistance?
BlueSwordM
Can’t really do this without making the spring quite a bit smaller, or affecting mechanical properties.
Did the math using 4 active coils instead of 5(the ones that affect conductivity in a flashlight spring), and it would make the spring deformation much higher. Instead of being 1mm of plastic deformation, it could easily go at 3mm, or even higher theoretically.
Even the manufacturer warned me about it, and recommended me to stay with 5 active coils.
You can do this easily with a steel spring of thinner wire, but not with a 1mm thick BeCu spring wire.
TLDR: Tried already, but the real world consequences would be too great to consider changing the design too much.
Tom E
Tom E's picture
For my use in lots of different lights, I do have to be conscious of clearances, because many of the stock springs will compress flat into the thickness of one coil because of the conical shape where these don't because they are more cylindrical shaped. So the stock springs could probably handle longer cells. Of course if I used inner bypasses, I sabotaged the collapsing down of the spring anyway.
Also these springs are mostly stiffer than typical stock springs I see. But of course, a lot of my lights are true "budget", UltraFire and other no name brands. For ZY-T11 clones I'm working on, I'm cutting the small springs down to reduce the height of the compressed state of the spring. Should reduce resistance as well.
Not suggesting any changes, just have to bare in mind this stuff.
contactcr
Even with 3mm plastic deformation it puts it from 13mm to 10mm, which is right where most medium/large sized springs are at. I’m no expert though. I think only the large spring could afford to lose this much height though. I’m biased since I (will) have both though.
contactcr
Tom E wrote:
For my use in lots of different lights, I do have to be conscious of clearances, because many of the stock springs will compress flat into the thickness of one coil because of the conical shape where these don’t because they are more cylindrical shaped. So the stock springs could probably handle longer cells. Of course if I used inner bypasses, I sabotaged the collapsing down of the spring anyway.
Also these springs are mostly stiffer than typical stock springs I see. But of course, a lot of my lights are true “budget”, UltraFire and other no name brands. For ZY-T11 clones I’m working on, I’m cutting the small springs down to reduce the height of the compressed state of the spring. Should reduce resistance as well.
Similar issues here. I find I can typically use 1 Blue spring on either end but then I have to bypass a stock spring on the other end to make up for the size/compression differences. I can rarely use both a large and small spring together as is.
BlueSwordM
Yeah, that’s why there is going to be a second revision Smile
So, I’ve shipped all of the 3500k SST-20 GA3 J4, except for Lithium, since he/she didn’t send his payment yet
Hope you will love the LED as much as I do.
Also, here are the revised measurements again:
Spring upper diameter: 4,25mm
Spring base diameter: 5,5mm
Spring height: 10,25mm
Spring upper diameter: 6,25mm
Spring height: 12,25mm
Lithium
Lithium's picture
Payment sent Wink
Want DC-fix? PM me!
BlueSwordM
Excellent. Will send it tomorrow.
Spring height: 10,50mm
Spring upper diameter: 5,0mm
Spring height: 12,50mm
contactcr
I dont see how keeping the coils and thickness the same will change the overall height much? Since the coils stack aren’t you just making it less springy and more stiff? The depth that it bottoms out wont change much will it?
BlueSwordM
Now that’s where the difference is.
By making the top spring diameter smaller, each coil’s diameter will get smaller as the delta h goes up, which will form a conical shape.
That will allow for higher spring compression, down to about 1,00-1,50mm, which will make battery fitment much easier.
Sorry if I’m changing the values constantly. I’m just inputting values in my calculator to see what could fit best.
BlueSwordM
So yeah, it is a possibility to remove a coil, but we’ll have to make the spring quite a bit smaller.
I’ll do some more calculations tomorrow to see what comes up.
BlueSwordM
Ok I redid some math.
It should be possible to reduce the number of total coils to 4 if we reduce the height by 1mm down to 12mm.
I did not take into account the 0,2mm delta between 0,8mm and 1,0mm wire, and the difference of yield strength between BeCu C17530 and C17500.
Basically, I was doing calculations with 0,8mm wire and BeCu C17500’s yield strength(for some reason…), so it should be possible to remove one coil off of the large spring and reduce the height to 12mm.
I will not be able to do this for the smaller spring though, since even if it uses BeCu C17530, the 0,8mm wire would make collapsing worse as it already is, so not really possible.
djozz
djozz's picture
You are getting quite the spring expert here, Blue! BLF knowledge for the win! Cool
Barkuti
Barkuti's picture
djozz wrote:
You are getting quite the spring expert here, Blue! …
Gotta change his name into BlueSpringM LoL! Big Smile
Party
JasonWW
JasonWW's picture
Last seen: 1 day 6 hours ago
I always prefer a more conical shape. You get more usable compression range and less coil binding. Wink
