Cheap flashlights to compare tints
A few years ago, when I was trying to learn about tint; I did like Zulumoose did. I bought three Convoy S2+’s.
  • S2+ color / LED / Bin / Tint / CCT (visual observation)
  • Red / XM-L2 / T4 / 7A / 3125K (very warm)
  • Green / XM-L2 / T6 / 3B / 5175K (fairly neutral)
  • Blue / XM-L2 / U2 / 1A / 6700K (very cool)
Then I bought some LED’s with different tints & swapped them around.
I came to the conclusion I like the tint from 2D (5700K) to 3A (5000K) the best in most instances. As far as High CRI goes, I can take it or leave it. Tint & beam quality are more important ’to me’.
Yeah, most likely I need a lot of education on Tint and CRI.
A lot!
I’m mostly looking for visibility.
Post #11 has some perfect examples to explain what I mean
The 3 flashlights:
The two flashlights on the left are best because I see structure in the wall. The one on the left has no such detail.
The light on the far right has a hot spot that washes out a lot.
In this situation the light on the left I certainly wouldn’t buy.
From the other lights I would pick the middle one purely based on the hotspot.
Winner Sofirn C01 5600 High CRI
On the colored sheet.
I would reject the Fenix E01 based on the hotspot regardless of the color rendering. The washed out hotspot, while very bright, hides all detail.
The other two are equally good for me. Good detail in both.
The skin is also equally good for me. Well perhaps the red is better because it might have more detail. But that depends on what the skin really looks like.
Back to the sheet.
I most certainly see a difference between the second and third picture.
What would I pick?
The answer to that leads me to the other part of my original post. Efficiency.
If efficiency was equal I would pick the light that looks most like daylight. But…I could be very wrong again, when reading specs it always CW with the highest lumen output. I’ve seen lights in with the high CRI version only outputs half the lumens compared to the 6500K version of the same light.
Why is that?
Is it because high CRI lights have half the efficiency of 6500K lights?
Is it because high CRI lights can handle less power.
To restate the same questions: Which led gives higest lumen/watt.
I prefer ‘real daylight color’, but not if it costs me half the runtime or half the brightness. But I might if it costs me 20%. But I haven’t really figured that number out for myself.
Contrast is a word that should have been in the above post.
I want to be able to read the label on a paint can. The text on those metal tags on an old rusty boiler in a basement.
Those things are more important for me that exact color.
How about a p60 host and 3 or 4 p60 drop-ins? They got them cheap nowadays.
@ZoomieFan
1. You will not easily notice a 40% difference in brightness.
You will usually get a 20-30% difference of brightness with same color temperature and 90CRI vs 70CRI, and that is hard to notice.
2. High levels of CRI is very important for color rendition and contrast.
So, for an inexpensive light, I would recommend the Convoy S2+ SST-20 4000k for absolute best color rendition.
that is a great suggestion!
The 5600k Yuji LED in the Sofirn C01 is more efficient (brighter) than the 3200k LED\
The 5600k has better CRI, and is closest to daylight.
I hope you enjoy it.
I think the 3200k is worth getting also, so you can form your own opinions about the differences.
I also think a set of convoys could be good,
for my taste, they would have to be High CRI, preferably 219b
I agree with your observations that High CRI is generally Less Lumens. You will want to form some opinions about what lumen levels you find practical for your needs. Indoors we use much lower levels, Im mostly indoors. The Sofirn C01 is an indoor, close range, light.
The Convoy is more capable at higher brightness levels, and outdoors where larger distance may be involved, its also bigger and heavier.
Always trade offs… which is why I have more than one light… each has something I like, none is perfect
I tend to group my lights by battery size…
AAA… Sofirn fits here
16340… Olight fits here
18650… Convoy fits here, there is also a short body option for 16340 size
Im personally not inclined to use 18650… its a great option, but a bit bigger than I choose to carry
I have a lot of AAA, I stopped using them when I dove into 16340 lights… Its my happy place at the moment.
which brings up another suggestion
1. Klarus Mi1C Cool White Aspheric, cool white low cri option only
2. Klarus Mi1C Cool White Ti and Copper reflector beam cool white low cri option only
and
3. Klarus Mi1C High CRI reflector beam
the third one is the best pick of the litter for my High CRI bias
but its a 4000k 219c, and will look a bit warm, or yellow, during the day… maybe not ideal… but, lights are full of compromises.
the first 2 Klarus are not High CRI, so for me, would only be acceptable as modding projects
regarding reading lettering on a plaque of label, an aspheric lens makes a more useful reading light than one with a hotspot
the Sofirn C01 produces a nice even beam, like an aspheric lens, its just not very bright… you will be able to read the label, but you will need to be within a few inches…
lights with hotspots have other strengths… you will probably discover that Get Both, is the Better answer :slight_smile:
True not in visibility. But I guess I would notice it in the time a cell lasts.
That means the 90CRI is 20-30% less efficient. Right?
I think I can best explain this with an example. Set a flashlight with ramping at the exactly the minimum brightness needed to see. While perhaps only possible in theory and a totally useless test I think it means the 90 CRI uses 20-30% more power to reach that minimum visibility level. A 20-30% shorter runtime?
Is that correct?
Contrast. That’s a very important thing for me.
I have a S2+, somewhere….
Not sure it’s exactly that one, but I usually buy NW.
@ZoomieFan, yes the 90CRI one will usually be 20-30% less efficient.
So، at low power levels, you will need to boost power by 20-30% to get 20-30% more brightness.
You won’t really need to though, since you won’t notice the difference.
@jon_slider
Yeah, get them all! :slight_smile:
Are you a flashlight salesman? lol.
Seriously I’m fully aware a lot of things are a matter of taste.
Likely also ‘medical conditions’ should be figured in. Good or bad eyesight. It seems that hardly anyone has perfect color vision.
So yeah, I have to buy several to test, but I want at least avoid buying what I very likely dislike….
Understood, but there comes a point I see the diffrence because that 30% makes the difference between seeing nothing and barely seeing something.
I’m very well aware that walking trough the woods is way different than measuring something in a lab with calibrated equipment.
Some on this forum call themselves tint snobs.
Others are brightness snobs.
I guess I’m a runtime and contrast snob.
When I read ‘20-30% less bright’ I’m not thinking about dim lights but reduced runtime.
It’s all about finding a balance between things. You cant have a 10,000 lumen light that runs 5 hours on a AAA cell.
I just keep asking all those seemingly useless details to make a less uninformed decision on my next flashlight buy.
Will it be perfect? Likely not. But hopefully it will be closer to perfect…
Makes me think about another aproach. A general purpose light that’s fine for most tasks. A 18650, 21700 or 216650.
But as an extra a AA or AAA that’s really great for reading labels. Just close range. No high lumens. I’ve once read that blue is best for high contrast (map reading) so for that light I would even consider a blue light. Even if it only has 30% efficiency of white.
Efficiency is only part of the equation for me
I agree that Low CRI is going to be more efficient, but, for me, Low CRI is not acceptable
so my math says
a 90 CRI light has 29% more CRI than a 70 CRI light
and yes
the 90 CRI light will be 29% less bright, for the same runtime.
I wont accept 29% more runtime from Low CRI
since Low CRI is simply not acceptable, for my snobby self
what I see is essentially a direct tradeoff between CRI and runtime… I will take the CRI over the runtime, every time. Thats just my personal preference… Low CRI need not apply :slight_smile:
I wish I had such a strong view as you have Jon. Then I could sleep tonite :slight_smile:
Seriously, I have preference and more strongly dislikes. I can indeed buy a dozen lights and just check them out.
But I don’t want a dozen S2+’s one is enough.
Besides of that I want to learn. Even if it’s mostly useless theory, I want to learn.
And I did learn from the answers.
Done learning? Far from. But at least I know in which direction to look.
So I keep asking……
If my only use for a light would be reading tags like below. Both new and old. What tint or color would be ideal? When I write color I also include for example blue and red.
I would recommend the 5600k Sofirn C01 for those label reading tasks, because the Tint is not too green, not too blue, not too yellow, its just daylight white.
The most important factor is beam distribution, so I would want a beam with no hotspot
imo the Aspheric beam of the Yuji LED in the Sofirn is ideal for label reading, I like it even better than a Mule. I dislike beams with a hotspot for reading labels, because of the need to avoid glare, it tends to force me to move the light around more, to find a balance between the hotspot and spill, in order not to be blinded by the glare, caused by the difference in brightness between hotspot and spill
otoh, outdoors, looking down a path, trail, sidewalk, a beam with a hotspot is much better, it projects into the distance in a way that an Aspheric or a Mule simply do not.
Aspherics an Mules are better for reading, beause the beam is excellent when illuminating a flat surface at an equal distance from the observer, such as when reading a plaque or label.
beam examples:
imo the Yuji LED lens is Aspheric, and I personally find that more useful than a mule.
l-r Aspheric lens, 47s Mule, Sofirn C01
l-r Aspheric, Sofirn, Mule
imo the Yuji LED is fantastic indoors, and at close range
I do not consider it an outdoor walking light, but it does work great for seeing food while sitting at a picnic table :slight_smile:
Besides the little AAA Sofirn C01, I like the aspheric lens in the Aluminum version of the Klarus Mi1c.
I also like the McGizmo Sundrop with High CRI LED, but, thats not in my budget.
I would use a beam with a hotspot to see down a tunnel, but when looking at cave paintings, I would want an Aspheric.
was watching Netflix the other night, like most nights, and noticed these beams:
can you see why I like the Aspheric, top, better than the little hotspot, on right?:slight_smile:
Probably you’d be better of with a TIR.
Recently, i have replaced the reflector of an S2+ with a 60 degree TIR, which gives a nice widely spread uniform beam. (The 4C tint looks great now)
If you want to read tagplates, you do not want a very bright hotspot which makes them unreadable, it will reflect too heavy. (Believe me)
Besides that, only the side will be readable with a bright hotspot.
Agree. And if you want it cheap get them even in parts, you cannhave them probably below $10 per dropin. Less space and waste.
about CRI, the benefit and advantages are mostly about reds
However, I will add that it is also about CONTRAST!
which light makes the orange leaf POP?
compare 325 lumens w 70 cri, to 170 lumens w 90+ CRI
thats almost double the lumens and almost 30% less cri
if you were looking for orange leaves, which one would you want?:
some people dont care what color the leaf is, as long as they can see its there… but for times where showing reds matters, such as cooking, intimacy (Sex is more fun in High CRI), seeing colors other than green and yellow… why settle for low CRI?
note both lights show the leaf… even though the low cri light is brighter, hence “more efficient”, is it really more efficient at finding orange and red leaves… nope
see what I mean?:
here is a typical Low CRI LED, focus on the red bar
here is a Yuji High CRI LED, and a typical 4000k Nichia 219b
oh, and before anyone tells you that Neutral White has better color rendering, it does not… Low CRI is Low CRI
Friends dont let friends buy Low CRI… LOL!
Which one? Not an easy question, because it’s hard for me to make that choice without seeing the same in daylight. The leave looks unnaturally red to me, but then I know some leaves can have a very bright color.
The pole in the background on the 170N looks brighter. Why is that? Has it reflective material on it. The 170N leaves look far more blurred than the 325 leaves. Is that because the camera has trouble with almost half the brightness?
For me, Nichia was a synonym for high CRI. Yuji scores even better. If blue could be ‘fixed’ it will be very close to daylight. Is the difference really visible in real life? I guess the answer is something like “depends on which color you are looking at”.
I must admit I don’t fully understand the graphs. It would be my guess that if all colors bars are equally high the light would be CRI-100.
If so I would expect that all lights have at least one bar being exactly 100. For the Olight that would be R14/green. In other words I would expect relative values in the graphs, but they seem to be absolute values.
Back to reading tags again. If the tag would be the leaves and the letters that red leave then then high CRI would make the tage more readable because the red jumps out more.
I wonder if low cri in some situations (colors) increases contrast. For example I’ve read that blue lights, really blue not just blueish, are best for map reading. Likely because black lines pop out?
Or hunters following a blood trail best use blue or ultraviolet. That while from looking at the picture with the leaves more red would highlight red/blood.
Let’s say for whatever weird reason I want to read a book (just text no pictures) in pitch dark. I only have a small flashlight. Would high cree best for this situation?
Now assume the book has white paper and R14/green letters. Would the Olight give the best readability because it peaks at R14/green? Or would it just turn the whole book green?
I’ll stop (for) now, because I might have started over-analyzing again :slight_smile:
I use P60 hosts and drop-ins for that purpose. Right now I have (6) solarforce hosts with newly built drop-ins that I’m comparing.
I’m searching for my favorite high CRI LED. Currently have several drop-ins with ~4000k high CRI LEDs to compare.
Check with SBFlashlights.com for closeout deals on solarforce hosts. Drop-ins can be made yourself for quite cheap. I use linear 7135 drivers so LED comparisons are done at known currents.
Making them yourself is the only way to control which LEDs and drivers you test.
The Convoy S2+ would be another great option.
Good luck and have fun! There are a lot of good LED options out there!
FB
mine is the 219b 4500k 9080, at the moment
I like warmer when its full darkness, but cooler during the day, so its a good compromise for a multi ambient light environment, with a bias towards daylight.
High CRI is a subtle variable, and some people dont prioritize it, because of an interest in efficiency. But, a more efficient light, is not a High CRI light… Efficiency favors quantity over quality of light.
Let me try to drive the point home… for the OP
I like a flashlight that can show red colored things, I find red food appetizing…
I can imagine that when a mechanic is looking at different colored wires, it helps to see the Red Pop!
Or, imagine Im grilling steaks after dark, would you like yours yellow or pink?:wink:
