I have two units and both make 360lm at start with NIMH, it’s a beast! and it gets very hot because there isn’t any stepdown
is it a typo that the output and runtime of Nimh is the same as 14500?
Good catch! Thanks for pointing that out. I’ve made the necessary edits now. Thank you.
Thanks for the kind words! I don’t see any visible PWM
I really like this light but the pocket clip is awful, does not work at all
Try pointing it at a spinning fan blade
I originally thought My Lumintop Tool AA 2.0 had no PWM either, even looking at some fan blades. But my phone camera is showing some kind of flickering on low, med, and high. Whatever’s happening must be very ultra high frequency PWM, or the driver isn’t fully turning off the LED. Whatever it’s doing is way better and almost undetectable compared to the 1st AA Tool, which had horrible PWM.
I’m a 18650, 21700 and 26650 freak but decided to buy the AA and AAA versions. I must say I’m pleasantly surprised. I only have the lights for less than a day so can’t say much yet.
Indoors they give more light than I would expect.
I also like the diffuser caps. A very smooth light, I don’t like hotspots of any kind. With the cap it’s zero
Yesterday I took my annual bath in pitch dark and read a book using the AA light with a cap standing about a yard away and a feet above me.
Must say it worked well. Very well.
Just as well as my regular 100 Watt bulb that’s positioned wrong for reading.
So if you take a bath once in a while and like reading get the light!
(a spark of insanity my be required for this kind of use,)
Best place to buy? (Probably a matter of opinion, but…)
I have the first version, and there’s nothing I dislike about it. Since this one’s an improvement over an already excellent little product, perhaps I should have one just to compare. (For scientific reasons only, you understand).
Too bad I missed the ultratac a1. This has no mode memory. For small edc lights with 14500 power and no shortcuts, I always prefer no mode memory now.
For the money I also prefer the convoy t2, which is available in warm white.
Both of these have the same mediocre clip as well. I guess I pass on the AA tool. I just bought a copper Tool AA which I kinda like. Except I also had to take of the clip. Also it is not CW.
Will the mode memory on the tool remember that it sits one position before strobe, or will strobe alwaysstay hidden behind 6 clicks?
D#rn, mode memory I just bought one and for some reason assumed it has no memory. Ok then, this one will get no use, I hate brightness lottery.
Why is it awful? Hope to hear from you, and pass your feedback back to Lumintop
Same! I did both and just couldn’t notice it with my eyes. However, I could notice PWM on the Tool AAA on low mode. The Tool AA must have very unnoticeable PWM if it has it.
Way too thin IMO. The clip is easily detachable from the flashlight, plus it’s too narrow so it won’t accept a jeans pocket for example.
Here is what I’ve done to mine :
I also like the diffuser caps. A very smooth light, I don’t like hotspots of any kind. With the cap it’s zeroYesterday I took my annual bath in pitch dark and read a book using the AA light with a cap standing about a yard away and a feet above me.
Just as well as my regular 100 Watt bulb that’s positioned wrong for reading.So if you take a bath once in a while and like reading get the light!
Yep, I love the soft white light that the diffuser gives out. Although I use it more frequently than an annual bath
Amazon or AliExpress but that’s dependent on a lot of factors.
I think we can all understand that you need to have the updated version for scientific comparison purposes. Go forth!
Thanks for your comments! Seems like the clip is an issue for quite a number of people. I put it in my jeans pocket and it fits fine and hasn’t come off once.
I also don’t like mode memory (I wonder what’s the logic behind manufacturers including it??) but thankfully, strobe is properly hidden and will not be memorised.
I’ve got one coming and need to get a couple of high mAh protected batteries for it. Any fit problem when using a protected 14500, like the Orbtronic or Keeppower 840 mAh?
Thanks for doing this review. I have a version 1 on the way.
Hey hi, I cannot say for sure because I don’t have those exact batteries to test it out but I believe the Lumintop 14500 that was sent together for the purpose of this review is protected so I believe you won’t have a problem with protected cells.
